Old 03-13-2009, 09:15 AM   #21 (permalink)
My first heli, Belt cp, was already put together and was pretty much ready to fly. Didn't get to learn any of these tricks.
Thanks for your help guys!! More pics coming soon...
By the way, I downloaded the trex se v2 manual from the top of this section. The manual I recieved with this kit is exactly word for word with the exception of any "align" wording.
Belt CP/ cnc head and tail/ esky HH gyro/stock servos/1800m stock battery/Dx6i
Flasher 450 (trex Clone) hb65mg cyclic/align 750 & 9257/align 325 cf blades/zippy 2200
GL500/9650 cyclic/401 & 9650/ align 430 carbons/zippy 6s 3300/ar6200/trex 500 canopy and gear
Eflight MCX
My wife is going to kill me if I bye another Heli!!
tig1142 is offline        Reply With Quote Quick reply to this message
Old 03-14-2009, 02:26 PM   #22 (permalink)
Glad to help. Considering I bought my first heli in Feb, I think I'm doing ok
600N, DS760, 500ESP vbar 5.0pro, 450SEV2 DS-760, 450Pro vbar 5.0pro, 250SE vbar 5.0pro
MAAC 43005
cd_edwards is offline        Reply With Quote Quick reply to this message
Old 03-22-2009, 11:59 AM   #23 (permalink)
So the bird is all together and I plan on maidening her night when I get out of work. Wish me luck!!
Name:	Media CardBlackBerrypicturesIMG00326.jpg
Eflight MCX
Old 03-22-2009, 02:44 PM   #24 (permalink)
Hello Tig, I too have recently purchased a flasher heli. Great flying unit I had some tail troubles. It turned out to be the gear came loose from the shaft on the tail causing wag. Then the tail grip screw kept loosening add that with the slipping gear it was a fight for a while. Now it's all good, align 450se v2 and copterx parts are interchangeable. Have fun!
Rustynail is offline        Reply With Quote Quick reply to this message
Old 03-22-2009, 04:13 PM   #25 (permalink)
This is good news, guys! I bought this heli before seeing this thread. It should be here later this week. If this works out well, i will sell my blade, and buy another one of these! Can't beat the price from SN hobbies! Too perfect!
Specter 700 V2- Pyro 750-56, Kosmik 200HV, Torq servos, CGY760R
Tron 7.0 - Pyro 750-56 Comp, Kosmik 210 HV-I, Torq servos, CGY760R
Dirtmagnet400 is offline        Reply With Quote Quick reply to this message
Old 03-27-2009, 08:06 PM   #26 (permalink)
I also bought this Helli as a combo from a shop local to us around a month ago.. he did have it as complete with radio but opted out of that due to the radio that came with it..
Ive just now got hold of the DX7 tx with the AR700 rx & have started to reading up on the installation of everything....
I'm hoping to have it in the sky by next weekend (if all goes well) if so, then i will have a trex 450 & a pretty good radio all in for not much more than the trex 450 se price...
Here's hoping
BaRoN30s is offline        Reply With Quote Quick reply to this message
Old 03-27-2009, 10:47 PM   #27 (permalink)
Going to test fly it for the first time tomorrow. Wish me luck!!
Eflight MCX
Old 04-01-2009, 08:35 AM   #28 (permalink)
tig did you get to fly it.? if so how did it go..
Old 04-02-2009, 01:04 PM   #29 (permalink)
just a quick warning I have the same heli it is one hundred % trex compatible but keep an eye on motor mine froze up in flihgt major prob it ended up burning up servos esc and reciever . not that all will do this but beware. flywell and good luck helibrit. Oh also watch tail hub they are known to blow apart, I replaced mine with the trex hub assembly ..
helibritUSA is offline        Reply With Quote Quick reply to this message
Old 04-02-2009, 01:26 PM   #30 (permalink)
Good luck tig.
electricdurango is offline        Reply With Quote Quick reply to this message
Old 04-02-2009, 03:11 PM   #31 (permalink)
Don't know if anyone else noticed this with the Flasher, but the stock tail belt is too stiff! It appears to be made made real rubber, and actually looks to be higher quality, but it is not flexible enough. When i assembled mine, the head didn't spin very freely at all even after a few times of heavy lubing! I replaced the belt with the OE Align belt... and it is MUCH better! It really free'd things up. I highly recommend this!
Old 04-02-2009, 06:27 PM   #32 (permalink)
this happens to my copterx 450, the belt was real rubber and more stiff than aling, just swap the aling that i have on my box and works perfect.
T-REX 500 ESP -- 510, 750 GYRO AND 520, T-REX 450X -- HS55, 401 GYRO - S9260, ALL METAL (R.I.P), COPTERX 450SE V2 CF -- HS65MG, 401 GYRO - S9260(SOLD), AEROWORKS EXTRA 300 50CC -- DLE55, 7955TH, FROMECO, EDGE 540 -- .81 ALFA, S3305,
f5air is offline        Reply With Quote Quick reply to this message
Old 04-03-2009, 12:18 PM   #33 (permalink)
tig, i have a question for you seeing as your the only other guy i know with a flasher 450 se.
when you go full pitch & then put forward elevator in on your radio. does your back servo arm catch under the plastic anti rotation bracket stopping it from going fully up..
im having this problem with mine & when it stops the front 2 are still coming down which is then pulling down swash plate instead of it staying where it is & tilting forward
when using back elevator at full pitch it seems fine...
thanks.
Old 04-04-2009, 09:42 AM   #34 (permalink)
Hello Baron, mine gets very close but does not touch, at full pitch I'm at 11+, 11- I could slide a piece of paper between the servo arm an the anti rotation bar.
Old 04-04-2009, 08:34 PM   #35 (permalink)
thanks.
Yes...I moved the bracket back a few mills
Eflight MCX
Old 04-05-2009, 12:57 AM   #36 (permalink)
So I finally got around to putting my Flasher together.
First thing I do is rip open the box like a kid at christmas.... Then the smell hit me.
Smelt like Kid Rock and Willey Nelson had a party and invited all their friends over for bong hits and blew it directly in the box. I thought it was just in my head. Took it to the local indoor fun fly and someone else said the same thing so I know it wasnt just me. Must be why the main shaft was put on upside down...
Started putting it together.
Frame, re-applied threadlock on everything, good thing I did as most were untouched.
Tail, looks very similar to the Align, only thin I noticed is the middle hole on the tail fin where you would put a screw in to the boom does not exist (not sure if Align has one but my EXI does.)
Head, very tight...too tight. Upon inspection, one of the SF Mixing Arms felt like it has some bearing issues as it is notchy feeling will need to go through and replace bearings me thinks...
Came with a shorter flybar, put on the 220.
Still need to go through and replace all the screws with button head or socket screws as the quality of the phillips head are under par at best. Some even had some cracks in the head of the screw.
I noticed the same thing about the blet being stiff. Going to soak it in some silicone to see if it loosens it up at all.
Didnt expect alot out of a $130 heli but well worth the money IMO.
I personally would not recomend it for a FIRST heli but once you get comfortable with building and fixing, by all means. I already have most of the parts for spares anyway. Wanted this bird as a beater to take the big hits when trying new tricks. WIll probably set it up as similar to my current one as possible.
UPDATE: Replaced the bearings in the mixing arms and all is running smooth now.
TREX 500ESP,Scorp 1400/15t, ICE100, AR6200, 510, 3G + 520,EDGE FBL main
Coptex 450pro, Scorpion -8 w/13t, -8 CC45, AR6100, 65MG, GP8750 + 9257
Copterx Black Angel 450, Scorpion -8 w/13t, AR6100, 65MG, GY240, DS520
Rosebud6 is offline        Reply With Quote Quick reply to this message
