Go Back   HeliFreak > R/C Helicopter Support > 550 Class Electric Helicopters
550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 06-06-2012, 07:59 PM   #1 (permalink)
Default Trex 550 Clone?????
I just ordered a HK550 gt. My first clone. Im wondering what motor and esc your use aside from align. Also I heard there are some parts from the 600 the interchange with the 550. If so which ones?
crashingrc is offline        Reply With Quote Quick reply to this message
Old 06-06-2012, 08:43 PM   #2 (permalink)
Exclamation HK now has a 550
https://www.helifreak.com/showthread.php?t=415051
I would stick with with the Align motor and servo's.
Take at look at any of the online shops and in the 550 section you'll see that many of the parts are listed 550/600
SAB Goblin 700 - CCHV120 - BEC Pro - AR7200BX - TM1000 / 450 Pro - GT5 - Tarot head / T-Rex 550 V2.1 - CC100 - BEC Pro - AR7200BX - TM1000 /
1004ron is offline        Reply With Quote Quick reply to this message
Old 06-07-2012, 12:27 AM   #3 (permalink)
i don't mean to be rude, but this is an Align forum and you are asking questions about a non align product. I realize that it is a clone, but you made a choice to buy a clone and it's a bit tacky (imo)to solicit advice from those that have purchased through align.
if you google align 550 there are numerous compatibility threads between the 550 and 600 parts. Also, if you read the Align threads you will see previous discussions of what options there are for ESCs.
good luck with your build.
Paul
2 Align 550s with stock ESCs
koppterx is offline        Reply With Quote Quick reply to this message
Old 06-07-2012, 01:53 AM   #4 (permalink)
Motor and esc are a up to you, neither of mine are Align, in fact most of everything that was Align besides the cyclic servo's have been swapped out, so I guess mine's a clone too now
"Sort your head out and fly with your heart"
Trex 450 SE V2: 9257 tail, Spartan Quark, HS65mg cyclic, DX7-AR7000, NEU 1107h/2y, Jazz Esc,
Trex 550 FBL: Jive 100+LV, KDE/NEU 1907H/1/N42, Vbar 5.3, Futaba BLS 251
markleyland is offline        Reply With Quote Quick reply to this message
Old 06-07-2012, 03:21 AM   #5 (permalink)
Made my day
My 500 is the only one in my collection that has mostly align parts, sans fbl.
For a hk550 build I would source esc/motor from HK as well, they even sell scorpion now. Align does have some good servos though,
honey bee king II
andersn is offline        Reply With Quote Quick reply to this message
Old 06-07-2012, 08:41 AM   #6 (permalink)
Originally Posted by koppterx View Post
..... but this is an Align forum and you are asking questions about a non align product. I realize that it is a clone, but you made a choice to buy a clone and it's a bit tacky ......
Agree....
Bravo52
Jerry Little
T-Rex 600, T-Rex 600ESP, T-Rex 550, T-Rex 450
Bravo52 is offline        Reply With Quote Quick reply to this message
Old 06-07-2012, 09:25 AM   #7 (permalink)
Hmm,
This makes me thinking. Mine has some none align parts, e.g. ESC is CC ICE2 HV 80 (used to be Hobby Wing), KDE motor, tons of KDE upgrades, Savox HV tail servo, SK720 FBL, Tarot 2mm frame, EDGE main blades. Oh, none of the bearings is from Align. It is no longer a pure breed anymore
The majority of Align heli has upgrades with other after market parts. Do those qualify as Align? If mine still qualifies as Align, how about a HK 550 with Align tail fin?
I see nothing wrong with a clone heli asking question here. The moto of HF is to respect and help fellow heli pilots.
As to the motor options, the common ones are Align 600mx, KDE XF, Viper, and Scorpion. You may need to modify the frame to fit Scorpion HK4025-1100kv. On paper, the scorpinion is a down grade from 600mx. Thunigy has 600 class motor but I am not familiar with them to say anything.
Many choices on the ESC too: Align, Castle, Hobby Wing, Kontronik,... They all works. If you plan to swing 550 blade, you probably want to stay away from Align ESC. The V1 manual clearly stated not to run 17T pinion with 550 blades. Unless you are using Kontronik, external BEC or Rx battery pack is highly recommended to power your servos. If you choose this route, disable the red wire from the ESC plug.
Good luck
Cheater
HD750, TDR II, TDR, Logo 700, Logo 700 XXtreme, Logo 550SX V2
taoY is offline        Reply With Quote Quick reply to this message
Old 06-07-2012, 10:11 AM   #8 (permalink)
i run 553s on one and 550s on the other with stock esc and stock pinion.
Old 06-07-2012, 04:32 PM   #9 (permalink)
I understand this is an align 550 thread. I would have posted in a HK thread but i didnt see one. All of my Heli's are Align 450- 2 500 and a 600. I am a strong supporter of align.
How are the HK motor and esc? Also how are the Hobby wing esc?
I dont know if i will try to use 550 blades. I see someone on ebay selling a 70a esc and 1200 kv align motor. From the spec it looks like it would smoke the esc. Anyone have this setup?
Thank you for everyones input
Old 06-07-2012, 04:52 PM   #10 (permalink)
Paul
Originally Posted by Bravo52 View Post
Agree....
I don't agree at all.
If the heli is a true clone of Align then users will get the most help in Align forums.
We can't possibly have a dedicated forum for every clone, and why would we if they are the same or very similar and parts compatible?
Most Trex 450 clones are supported in the Trex 450 Forum and most members are happy to help there.
I have no experience with HK motors and ESC's but my guess is that they would be hit or miss on materials and QC.
Hobbywing ESC's seem to have a decent reputation, but again I have no personal or specific info on them.
I run the stock 70A ESC and 600MX motor with zero issues using 520mm blades on my flybar 550E.
Jonathan Livingston Helicopter
Blade 400: E-flite 420H/35X ESC, AR6100e, HS65HB x 3, G401B/DS290G. (Ret.)
CopterX 450AE V2: 430XL/35X ESC, AR6100, HS65HB x 3, LTG2100T/HSG-5084MG.
T-Rex 550E V1 Classic Flybar: 600MX/BL70G, AR6200, DS610 x 3, Quark/DS650, 16t/520mm blades.
Wolfpackin is offline        Reply With Quote Quick reply to this message
Old 06-07-2012, 05:00 PM   #11 (permalink)
Thank you! Do you know which 600 motor you have? Is it the 510 or 1220kv?
Old 06-07-2012, 05:10 PM   #12 (permalink)
A lot of the hk600 used this motor with decent results.
[url]http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=11980
I had good experience with they turnigy 500 heli motor in my Align 500.
I am with the other guy. This forum is about helping fellow freaks, not turning up our noses at something you consider, "not worthy".
We align users get the same thing in some other forums, so why turn around and do the same to someone with a clone.
I would buy ds610's for cyclic, as it is a very good servo with a great price for the 550. I am very pleased with mine.
Hobbywing esc's are very good for the price and the turnigy k force are rebranded hw.
Also I've heard the turnigy superbrain is pretty good, complete with data logging like castle.
Learning to walk was so much easier than learning to fly.
Hoosiermo1 is offline        Reply With Quote Quick reply to this message
Old 06-07-2012, 05:11 PM   #13 (permalink)
I am using the align motor and Hobby Wing 100 amp esc with the red wire disabled as mentioned and they work great.
rdmanone is offline        Reply With Quote Quick reply to this message
Old 06-07-2012, 05:14 PM   #14 (permalink)
just bought a hobbywing HV 120A for my 700
honey bee king II
Old 06-07-2012, 08:24 PM   #15 (permalink)
I have the 1220KV motor since I run one 6S battery.
The 510KV motor is for a high voltage setup.
Old 06-08-2012, 06:22 AM   #16 (permalink)
Really. The spec show it draws 90amp. You have no issue on a 70 esc? What is your setup for the stock esc?
Old 06-10-2012, 05:38 PM   #17 (permalink)
I think the most important things contributing to my success with the stock ESC is that the heli is flybarred, I'm sticking with the 16t/520mm blade combo and I don't fly hard 3D (just basic circuits with flips, loops, rolls, piros and limited inverted).
Oh, and maybe a little luck.
Also consider that when this heli first came out Bert Kammerer also claimed to have no issues with the stock 70A ESC.
And I think he flys slightly harder than I.
