Old 05-13-2012, 04:41 AM   #21
Groucho_
Originally Posted by Stolla View Post
I did not change anything on p and I just running default mode 6, why did you feel the need to change p value?
From what I could figure out from the terrible instruction manual, this P-value has to be set lower if you are using lower RPM values.
Now it doesn't specify what 'lower' RPM values are - which is not very nice of them...
From the manual -
'To realize a smoother RPM control at lower RPM, the P- value [Default 50%] of the ESC is reduced below the point X (adjustable via PROGDISC).'
Groucho_ is offline        Reply With Quote
Old 05-13-2012, 04:49 AM   #22
Stolla
it can be adjusted if you feel the need but default is already adjusted for low rpm so set it back to default, you'll be ok running under 50% no problem
Stolla is online now        Reply With Quote
Old 05-13-2012, 04:51 AM   #23
Groucho_
Thank you Stolla. I will do that then...
Is there anything else I should know about mode 6?
I'm running it with a Pyro 700-52.
Old 05-13-2012, 06:26 AM   #24
Stolla
no, only thing to keep in check is to make sure you have enough headroom, at the lower percentage of course no problem but at max you need to be sure, usually you may need one size pinion bigger keep in mind mode 6 shows lower rpm at same thr percentage than m4, doesn't matter they give same max so its only a tx thing
Old 05-13-2012, 06:47 AM   #25
Groucho_
Shouldn't be a problem then. I'm not planning to use high headspeeds.
I've also set the helijive spool up time to 16 or 20 seconds - This for the TDR. Would that be OK?
Henseleit TDR
Trex 550E
Trex 450 Pro
Blade mSR
Old 05-13-2012, 09:05 AM   #26
Stolla
sure! Too slow maybe
Old 05-13-2012, 09:14 AM   #27
Groucho_
What's the ideal spool up-time without having the tail swing out on the ground?
I only ask because I can clearly hear two quick-sounding speed changes in this spool up - Wouldn't want a faster setting to make the heli spin.
Old 05-13-2012, 11:05 PM   #28
Stolla
Don't worry it won't spin at default, however there is a jump in mode 6 on spoolup, nothing to be concerned about, it's normal and won't spin heli around.
Old 05-13-2012, 11:41 PM   #29
Joectls
Originally Posted by justindewoody View Post
I have a Goblin 700 with the Heli Jive 120 and the Scorpion 4525 LE motor. I run governor (RPM Control via ProgDisc) at 2150 head speed. I have about 80 flights with no problems at all. On the other hand, I have a Trex 700E V2 with a Heli Jive 120 and a Quantum 4530 motor. I'm getting shutdowns with the Heli Jive and 8 blinks on the LED(over current protection). So MrMel is right about not using governor in the Heli Jive with a big powerful motor, but I have no problems with the Scorpion 4525 LE. So I don't really know what to tell you. But hopefully this helps you a bit.
Justin how you run the governor via ProgDisk? Does the ProgDisk has a option that you Manually input the RPM?
I also have a Goblin and will like to have a startup point before I tach the heli. So can you please tell me What % you have your tx on each mode and what RPM's are you running beside the 2150?
[SAB Goblin 700] Scorpion4525-520LE • Helijive 120• VBar • JR8917HV / 8900JR
Best place to buy : rcgalore.net
"No Crash , No Gain"
Joectls is offline        Reply With Quote
Old 05-15-2012, 05:43 PM   #30
Joectls
Old 07-08-2012, 04:10 AM   #31
CraneGrus
I have a friend with a x7 and stock motor, wanting to use the helijive's governer;
I get from this thread he should use mode 6 and possibly should use ksa mode afterwards?
TDR, X7, X5, 450 Pro, 130X
CraneGrus is offline        Reply With Quote
