Go Back   HeliFreak > R/C Helicopter Support > Miniature Aircraft Helicopters > MA Whiplash
MA Whiplash Miniature Aircraft Whiplash Helicopter Support Forum
Old 12-21-2012, 09:50 PM   #1 (permalink)
Default MA releases new clutch
Just seen this today;
MA131-11 Whiplash Nitro Sealed Clutch Bell Complete with Sprag
MA131-12 Whiplash Clutch Bell Brass Bushing
MA133-11 Whiplash Sealed Gas Clutch Bell Complete with Sprag.
Reason is: The clutch bell stays approximately 40 degrees cooler and less maintenance since the seal keeps the grease within the sprag.
Wonder if I need to get the clutch bell brass bearing along with the sealed clutch bell?
777ER is offline        Reply With Quote Quick reply to this message
Old 12-23-2012, 09:38 AM   #2 (permalink)
Which one for the electric version?
Daniel tengvall is offline        Reply With Quote Quick reply to this message
Old 12-23-2012, 09:53 AM   #3 (permalink)
Lets see, one says Gas in the name and another one says Nitro in the name. That leaves one left for electric.
We had a great country once. You know what made it great? “I can.” Then the weak came along, “the I cant’s” and destroyed it.
Rudy is offline        Reply With Quote Quick reply to this message
Old 12-23-2012, 01:07 PM   #4 (permalink)
Default Is MA going to swap out With present owners??
Is MA going to swap out this updated clutch bell with all current Whiplash owners?
Peace Out, Bobby D.
" PRo Gas 700 GOBLIN "
G290Rc. HC3-SX, 8-FGH, MKS.
Flights 141
DEDO is offline        Reply With Quote Quick reply to this message
Old 12-24-2012, 11:35 AM   #5 (permalink)
Pics of the new setup?
Fighting through my sprag setup issue here with engagement issues.
X-Cell Whiplash, Konk 700-45, Skook 540, Mav 710's, YGE 160HV...
itbvolks is offline        Reply With Quote Quick reply to this message
Old 12-24-2012, 12:40 PM   #6 (permalink)
None of the above is for the electric, it is to be released at a later date.
Got this info after asking Ma.
hlager is offline        Reply With Quote Quick reply to this message
Old 01-02-2013, 06:06 PM   #7 (permalink)
I can't find it on MAs site. Do you have a link?
CFHeli1 is offline        Reply With Quote Quick reply to this message
Old 01-02-2013, 07:45 PM   #8 (permalink)
http://www.heliwholesaler.com/131-11...fo/MA131%2D11/
http://www.heliwholesaler.com/133-11...fo/MA133%2D11/
Old 01-19-2013, 12:24 AM   #9 (permalink)
Still waiting on them to hit the retail market.
Old 01-20-2013, 10:55 PM   #10 (permalink)
Default CFHeli1
Heli wholesaler sells retail also...
They are in the same building as Min Air
Peace Out, Bobby D.
Flights 141
Old 01-21-2013, 03:39 PM   #11 (permalink)
No news about the new E sprag cup ?
Old 01-22-2013, 10:43 AM   #12 (permalink)
I just built a Whiplash gasser, haven't flown it yet...so, do I need to swap out my clutch bell and sprag with MA?
"I love the smell of Nitro/Gas in the morning!"
Citizen 654
rcnut is offline        Reply With Quote Quick reply to this message
Old 01-22-2013, 04:13 PM   #13 (permalink)
Default clutch
No you do not have to go and buy the new clutch.
frito169 is offline        Reply With Quote Quick reply to this message
Old 02-03-2013, 02:20 PM   #14 (permalink)
I have the nitro, is this a straight drop in?
Where can you purchase this?
Thanx
zaboaa is offline        Reply With Quote Quick reply to this message
Old 02-03-2013, 04:52 PM   #15 (permalink)
There's two choices to do this bell upgrade:
You can purchase the complete Bell assembly w/Sprague bearing pre assembled.
This is a simple drop in replacement for the existing.
OR, you can purchase the Brass Bushing and the new clutch bell housing, and reuse the sprague out of your existing clutch bell.
You will need an Arbor press to press the brass bushing into the new bell if you choose the latter option. Obviously, you will want to make sure you have the sprague orientated correctly before you press the brass bushing in
dchekas is offline        Reply With Quote Quick reply to this message
Old 02-03-2013, 10:57 PM   #16 (permalink)
What is the advantage of this upgrade? Thanks
Old 02-04-2013, 07:54 AM   #17 (permalink)
The new bell retains grease in the sprague much better.
Old 02-04-2013, 09:52 AM   #18 (permalink)
The brass bushing also acts as a support bearing for the pinion. My original OWB/pinion kept locking up, the new design fixed it.
My gasser clutch kept getting lube from the OWB running into the clutch bell causing the clutch to slip. There is a direct leak path from the starter shaft into the clutch bell. A very simple solution that seems to be working well is to to first install starter shaft with the pinion removed from the assembly. On the small end of the start shaft, install a small o-ring. Install the pinion over the starter shaft and into the sprague, this also pushes the o-ring into position to deflect the lube for contamination the clutch bell.
fastflyer20 is offline        Reply With Quote Quick reply to this message
Old 10-10-2014, 10:42 AM   #19 (permalink)
I cant find a 133-11, did you have a link to a webshop thats it is in stock?
PeterW is offline        Reply With Quote Quick reply to this message
