Go Back   HeliFreak > R/C Helicopter Support > 700 Class Nitro Helicopters
700 Class Nitro Helicopters 700 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 10-03-2016, 07:53 PM   #1 (permalink)
Default Installing 700X head onto a 700N DFC
Hey, any chance I can put a 700X head onto a 700N DFC?? I can see Align releasing a new 700N without the dfc head in the coming months but wondering if possible I can use a 700X head for now...
Tron 7.0 Tron 5.5 Tron Nitron Tron 5.8
VTouch/Neo
Locktite is offline        Reply With Quote Quick reply to this message
Old 10-03-2016, 08:18 PM   #2 (permalink)
dont see why you cant 700x use same main shaft than 700l dfc.to me it should be 100% compatible.
trex 800e pro dfc, trex 700n dfc, trex 450l 6S, trex 150
darknight736 is offline        Reply With Quote Quick reply to this message
Old 10-03-2016, 08:25 PM   #3 (permalink)
Just wondering why I haven't seen any of the team pilots do it...I think it would be nice to give it a try..Plan on eventually getting another 700X and making it a 3 blade and slaping the 2 blade head on a 700N
VTouch/Neo
Old 10-03-2016, 08:36 PM   #4 (permalink)
I you try it give me an update, need new swash on mine a think about convert it to fl and keep the dfc head spare for the 800
Old 10-03-2016, 08:39 PM   #5 (permalink)
Hoping one of the Align guys sees the thread and has some answers..
VTouch/Neo
Old 10-03-2016, 08:49 PM   #6 (permalink)
Responded to your PM, ultimately it should fit without issue given as the same DFC shaft is used. I also gave you a few options regarding parts and alternative as well.
nynextel88 is offline        Reply With Quote Quick reply to this message
Old 10-03-2016, 08:52 PM   #7 (permalink)
I plan to, eventually. I don't really like DFC and the EFL head currently on my 700N is way too tall.
Keith - FrSky | OMP | KST | KC3D
Protos 800X Evo | OMP: M7, M4 MAX | M4*2 | M2 EVO*2 | M1 EVO | So Many Airplanes
KC3D LLC - Charge Cases, Starter Adapters, Heli Upgrades, and More
Number is offline        Reply With Quote Quick reply to this message
Old 10-03-2016, 09:04 PM   #8 (permalink)
I was hoping to see a new 700n as well but don't think one is in the works for a while.
I'm hoping I can catch a deal on a 700n because that's the next heli I'm after. I wish I could wait for a redesign before getting one but it's just too far away. I'm going in on one for a winter project.
Helis: Trex 250, Oxy3 +, 450 se v2, 450 pro, 470, 480N, 500 ESP, 600N, 700N
HeliLust is offline        Reply With Quote Quick reply to this message
Old 10-03-2016, 09:44 PM   #9 (permalink)
Here is the PM for those interested. Thanks
I suppose it would work no problem. It's the same height as the current DFC head.
These parts should get you started
http://aligntrexstore.com/700FL-Main...FC_p_2862.html
http://aligntrexstore.com/700-CCPM-M...XX_p_2857.html
http://aligntrexstore.com/700E-Main-...3A_p_4530.html
http://aligntrexstore.com/700X-Contr...XX_p_4508.html
http://aligntrexstore.com/700X-FL-De...AX_p_4569.html
Or you can just get this http://aligntrexstore.com/700FL-Flyb...XX_p_2832.html and http://aligntrexstore.com/700FL-Main...XX_p_2831.html
That has everything you need and it'll pretty much be the same thing, just a little taller. That's what I use on my 700N.
VTouch/Neo
Old 10-03-2016, 09:48 PM   #10 (permalink)
Who knows when but Align has been pretty quick with the release of 3 new helis in the past month..Who knows, next week we can see a 700NX
VTouch/Neo
Old 10-04-2016, 12:41 AM   #11 (permalink)
I was thinking the same thing but my dreams have been crushed lol. That's not to say one won't be in the works I the future nut not right now to my knowledge.
Old 10-04-2016, 02:23 AM   #12 (permalink)
The 700N DFC really doesn't need a redesign imo. Especially now there is an alternative head that is reasonably low. I won't be switching though as I prefer the rigidity of DFC - I run DFC on all 12 of my machines.
abit late is offline        Reply With Quote Quick reply to this message
Old 10-04-2016, 07:14 AM   #13 (permalink)
Direct to swash would be nice to eliminate some slop, but yeah, it's not really needed. The 700N is a solid machine.
Old 10-04-2016, 08:17 PM   #14 (permalink)
http://customheliparts.com/store/ali...t-rex-700-n-dl
Dawiev is offline        Reply With Quote Quick reply to this message
Old 10-04-2016, 08:41 PM   #15 (permalink)
Yep, but it's expensive. Like I said the stock frame is good enough by far. If Align released a direct to swash frame I'd be all for it, but you can only get parts for that CHP from that one shop, and if they go under or stop making them, you're screwed...
Old 12-05-2016, 09:37 AM   #16 (permalink)
Finally got around to installing the 700X head of my 700N DFC
VTouch/Neo
Old 12-05-2016, 10:12 AM   #17 (permalink)
Very nice on the nitro. I hope the recent trend on FBL heads, tilt skids, and belted tails continues. I like the way the low EFL heads fly and have been slowly changing all mine over even though setup is kind of a pain.
Old 12-05-2016, 11:59 AM   #18 (permalink)
Nice, I'm glad the list of parts I gave helped. Flight report next!
Old 12-05-2016, 04:21 PM   #19 (permalink)
Yes it did. Thanks...not a big fan of cold weather flying so flight report will come when it warms up a little.. which may be in a few months..
VTouch/Neo
Old 12-07-2016, 03:40 AM   #20 (permalink)
I have a 700N DFC , last version. narrow frames.
Do you use the standard main shaft?. I have a issue with the standard dfc main shaft.
I can't fit the screw with nut in the top hole of the new hub
In the top hole ... do you use the OEM two screws or use one screw with nut?
Thanks in advance
Align 800e PRO DFC // KRAKEN Yellow // RAW Nitro // Align 700N DFC // RAW Yellow // 2x Goblin 420 // RAW 420 // RealFlight 7.5 // neXt // AccuRc // Tribunus - Vbar Control Touch - Vbar Neo
msallua is offline        Reply With Quote Quick reply to this message
