Go Back   HeliFreak > R/C Helicopter Support > Turbine Helicopters
Turbine Helicopters Turbine R/C Helicopters
Closed Thread
Old 03-16-2009, 01:14 AM   #21 (permalink)
Combustion Chamber secured
-Kevin
Skiddz is offline        Quick reply to this message
Old 03-16-2009, 01:15 AM   #22 (permalink)
Showing three screws securing Combustion Chamber to Diffuser:
-Kevin
Old 03-16-2009, 01:15 AM   #23 (permalink)
Installing Nozzle Guide Vane
-Kevin
Old 03-16-2009, 01:16 AM   #24 (permalink)
Getting Ready to attach Festos to service pipes:
-Kevin
Old 03-16-2009, 01:17 AM   #25 (permalink)
Snugging up "T" fitting to Kero inlet:
-Kevin
Old 03-16-2009, 01:17 AM   #26 (permalink)
Festos all snugged up:
-Kevin
Old 03-16-2009, 01:19 AM   #27 (permalink)
Attaching restrictor to Air Pipe:
-Kevin
Old 03-16-2009, 01:19 AM   #28 (permalink)
Plumbing connections installed:
-Kevin
Old 03-16-2009, 01:20 AM   #29 (permalink)
Teasing the element out of the Glow Plug with a dental pick:
-Kevin
Old 03-16-2009, 01:20 AM   #30 (permalink)
Front connection points all done and Turbine Shaft reinstalled:
-Kevin
Old 03-16-2009, 01:21 AM   #31 (permalink)
Turbine wheel showing balance mark:
-Kevin
Old 03-16-2009, 01:22 AM   #32 (permalink)
Yep, it's spins freely!
-Kevin
Old 03-16-2009, 01:22 AM   #33 (permalink)
Let us plumb: Clockwise from turbine:
3mm blue tubing with restrictor installed internally
Festo "Y" fitting
3mm green tube for propane
3mm clear tube for fuel supply and lubrication
4mm clear tube for gearbox lube tap
-Kevin
Old 03-16-2009, 01:25 AM   #34 (permalink)
Festo "Y" fitting connected to air and lube pipes
-Kevin
Old 03-16-2009, 01:26 AM   #35 (permalink)
Single end of Festo "Y" connected to kero pipe "T" fitting and "Y" secured in place
-Kevin
Old 03-16-2009, 01:28 AM   #36 (permalink)
3mm green conected to propane pipe and routed around intake to Wren specified exit point*
*which will be changed later
-Kevin
Old 03-16-2009, 01:29 AM   #37 (permalink)
Almost done:
-Kevin
Old 03-16-2009, 01:29 AM   #38 (permalink)
Connecting 4mm clear tubing to Air Pipe Lube Restrictor
-Kevin
Old 03-16-2009, 01:30 AM   #39 (permalink)
Test fitting RPM Sensor to make sure no tubing is in the way
-Kevin
Old 03-16-2009, 01:31 AM   #40 (permalink)
FOD Screen installed per Wren's instructions - which need to be changed per Bergen for their airframe.. Grrr...
-Kevin
Closed Thread
