Old 07-10-2015, 03:02 AM   #1 (permalink)
Default Servo decisions for cyclic on 450
I'm looking for a digital metal gear servos for the cyclic on my 450 I can't decide between hi-tech or savox. I'm currently looking at the savox sh-0255 <----- would this be a good choice?
ricky.davis.129794 is offline        Reply With Quote Quick reply to this message
Old 07-10-2015, 08:11 AM   #2 (permalink)
I just spent a lot of effort researching cyclic servos for a 450 and kept coming up with the same finding: The TGY-306G Ultra Fast / High Torque MG Digital Alloy Cased Servo seems to be the best value (performance vs price). They also offer a High Voltage version.
Walkera 4#3B, 4G6
Align 250SE, Gaui 200
Tarot 450PRO
Align 550L Dominator
Steve Joblin is offline        Reply With Quote Quick reply to this message
Old 07-10-2015, 09:19 AM   #3 (permalink)
I have researched also and came up with the same conclusion. THey are the same specs as the KST's. However, my budget is really really low and went with cheap cheap cheap Emax ES08 metal gears. I may regret the choice in the future but for now they work for me. I also found that Emax has copied the KST/Turnigy versions as well. The specs look similiar and the price is similiar. $25/servo.
weav01 is offline        Reply With Quote Quick reply to this message
Old 07-10-2015, 12:21 PM   #4 (permalink)
Def go w kst 215 or the 315s but if you do then make sure you've got a good bec cuz they're power hungry and will def brown out thr vbar.
(I.Y.A.O.Y.A.S.)
Old 07-10-2015, 01:44 PM   #5 (permalink)
Though the ds430m are pretty good too but cost just as much if not more than the ksts but they wont brown out your esc. Atleast they haven't browned out my stock align esc.
(I.Y.A.O.Y.A.S.)
Old 07-10-2015, 04:05 PM   #6 (permalink)
Are they hv? Not looking for high voltage at all. just fast, digital, good, metal gear servos
Old 07-10-2015, 04:16 PM   #7 (permalink)
BK Servo 3001s. Very high quality, fast, strong, and the best customer service you will ever find.
Goblins - Mini Comet, 380, 500, 700
BK Servos, Spartan vx1e FBL units, Switch Blades
Jeti DS-16
TORCHS member, AMA 64878, Citizen 690
Mattinfla is offline        Reply With Quote Quick reply to this message
Old 07-10-2015, 09:18 PM   #8 (permalink)
Yes kst 215 are, the 315s or the daviga 313 (same servo) are not. Check them out at alofthobbies.com
Ds430m are not hv.
(I.Y.A.O.Y.A.S.)
Old 07-10-2015, 09:49 PM   #9 (permalink)
i'm running KST servo's on all my machines now
even my 750's and have zero issues
4 x Rush 750/stretched V-bar KDE 700XF-495 HV servos Greys reactor CC 160-HV
Trex 600EFL V2 V-Bar ds610 ds650 CC bec/pro Scorpion 130a HV KDE 600XF-530
450L KDE 1750 cc50 4xDS215MG k-bar
X-8 FPV Wing, TBS Discovery FPV, TBS Caipirinha FPV
satgod is offline        Reply With Quote Quick reply to this message
Old 07-10-2015, 11:09 PM   #10 (permalink)
I'm running the 315's on my 450, great servos, highly recommend them. Been very reliable, no slop in the gear train.
Team Synergy
Dylan Hudock is offline        Reply With Quote Quick reply to this message
Old 07-12-2015, 12:05 PM   #11 (permalink)
Just found some ds430m on ebay for 15 bucks! That's almost half the price of full retail. I bought one for a spare.
(I.Y.A.O.Y.A.S.)
Old 07-12-2015, 02:56 PM   #12 (permalink)
Ya I saw that only two left. argg!!!
Old 07-12-2015, 05:46 PM   #13 (permalink)
If you were looking at getting a set im sorry... : )
(I.Y.A.O.Y.A.S.)
Old 07-15-2015, 07:30 AM   #14 (permalink)
Well ended up getting some hi-tech HS-5065MG+ at my local hs around 33 bucks a peace
Old 08-15-2015, 08:17 PM   #15 (permalink)
Default Made a mistake...?
Hi Guys,
today i've ordered three KST DS215MG servos for my Tarot 450 pro, because my Turnigy servos are too slow (and one of them dead in a crash on this week... ) But i think i've made a mistake: theese are HV servos.
http://www.kstsz.com/threestyle/ksts.../13531946.html
And my heli is running with 3S... What should i do? Cancel the order, or it is possible to connect the servos direcly to the BeastX? Thanks for the answers!
L-Zo is offline        Reply With Quote Quick reply to this message
Old 08-16-2015, 06:55 AM   #16 (permalink)
What tail servo do you have?
Do you have a BEC or is the voltage in you ESC adjustable?
The kst215s work from 6.0 to 7.4 volts. If your tail servo works somewhere in that range you should be ok.
It's fine to run these on a 3s setup. You can run these on the beastx.
CrashNburn420 is offline        Reply With Quote Quick reply to this message
Old 08-16-2015, 08:14 AM   #17 (permalink)
Originally Posted by L-Zo View Post
Hi Guys,
I have these servos running with my YEP40A ESC which BEC delivers 5.5V to these servos, no problem at all. If you are worry then you need to order KST115MG instead.
Nano CPx, Hirobo Quark
250 SE, Pro Upper Frame, Talon25, KDE, KST215, DS95i, Mini Vbar
450 Pro (6s), KDE, Lynx, Tarot, RJX, YEP40, KST215 & 515, SK540
465 (6s), Align DFC, HW50AV3, KST315 & 8910A+, SK720BE
lcc014 is offline        Reply With Quote Quick reply to this message
Old 08-16-2015, 10:10 AM   #18 (permalink)
Thank you for the answers. I've cancelled the order before reading them . I' m sure that it would not have been a problem, but saw my money refunded, i will sleep more calmly... I will order the KST ds115mg.
CrashNBurn: my tail servo is an Align DS525M.
Old 08-17-2015, 01:04 PM   #19 (permalink)
I'm running the KST 115 servos on my Trex 450 Pro. Mechanically, they're the same servo as the 215, just not HV. You'll be happy with these. May I suggest getting a set of breakaway servo arms. I'm running the original motor and ESC and one Sat receiver and have had no brown out issues.
Helique is offline        Reply With Quote Quick reply to this message
Old 08-17-2015, 01:17 PM   #20 (permalink)
I'm running the 215's on my Oxy 3 and Goblin 380 at 6v. Very nice servos. The oxy 3 is just using the weak edge 50 lite internal bec and the goblin a CC10 bec no issues.
I had Align 430M's on the 380 before this and they would get a little hot flying around. These are nice and cool when I come down.
__________
Goblin 380, 500, 570, Mikado 690SX, 480Xx(Stretched 500) , Protos Mini, Max V2 , Oxy 3, Vbar Control/Neo Vlink (Citizen 758)YouTubeProgress:http://tinyurl.com/oliver1071
oliver1071 is offline        Reply With Quote Quick reply to this message
