Go Back   HeliFreak > R/C Helicopter Support > Antique Out of Production and Vintage Helicopters > Outrage Fusion 50
Outrage Fusion 50 Outrage Fusion 50 Electric Helicopter Factory Support Forum
Old 05-08-2012, 11:28 PM   #1 (permalink)
Default who do i need to thank? Bert?
i just got my f50 back together with the newly restocked parts from helidirect and the tail gears didnt need any shimming or "making" them tight. they just were by default. is this a result of bert nocking some heads around or did i get some "freak" parts? regardless im just happy to have the war wagon back in the air.
"just let it happen"
ragtop01 is offline        Reply With Quote Quick reply to this message
Old 05-09-2012, 07:24 AM   #2 (permalink)
i just put togther my new kit a few weeks ago and didnt have any issues at the tail end with gear mesh or the front of the boom with a sloppy gear in the boom housing. i didnt have to sand the housing, or put tape on anything.
the kits did come with all black gears, dont know if that means anything or not.
Empire Hobby/ Team Gaui USA -- Rcbearings.com
-- Cyclone Blades -- Team KDE -- A-Main Hobbies -- OMG servos
dodgeboy is offline        Reply With Quote Quick reply to this message
Old 05-10-2012, 11:25 AM   #3 (permalink)
This is how ALL my gears have been for the past few years..
never have seen first hand the issues others report..
mine were always perfect.
CeeveeSiN is offline        Reply With Quote Quick reply to this message
Old 05-11-2012, 10:26 AM   #4 (permalink)
mine had no play either.. so ya seems to be the luck of the draw.. OR maybe they did address the issues in the latest inventory
Team Fun / Heli Canada
**When you start to be in complete control reflexes are not a requirement.**
s0laris is offline        Reply With Quote Quick reply to this message
Old 06-04-2012, 08:15 PM   #5 (permalink)
Got mine in November and no slop here. I tried a black auto gear last week but it was to tight and overheated. It sounded like an old creaky door after flight, so I put the white gear back in.
Goatkeeper is offline        Reply With Quote Quick reply to this message
Old 06-05-2012, 09:50 AM   #6 (permalink)
so you are luky,, depence wich bach you get,, my one is stripping every 2 end flight,, juse black gears,, all perfect adjusted,, the issue is the quality of the gears,, 4 are ok, 4ore not ,,
thinking to leave the brand soon,;(
silverbullet is offline        Reply With Quote Quick reply to this message
Old 06-05-2012, 10:20 AM   #7 (permalink)
if it is happening that much that sounds like a govenor gain problem. or you have the stopping power on the tail set too high
Richard Zappe
Team Kontronik USA PeakAircraft
Wh1teAfr1can is offline        Reply With Quote Quick reply to this message
Old 06-05-2012, 01:54 PM   #8 (permalink)
I still have yet to strip a single gear in flight on this heli... my fusion has 38 flight hours (over 400 flights) on it. The only gears I have stripped were front and rear TT gears, a few times... due to plowing the tail while practicing autos.
Also, went back to white gears 150 flights ago.... simply because I had them.
~SAB~ Goblin 700 ~Compass~ Warp 360 ~Blade~ mCP X (BL)
AMA# 977012
**Team BOCA Bearings**
BaconRaygun is offline        Reply With Quote Quick reply to this message
Old 06-06-2012, 02:31 AM   #9 (permalink)
At 2300 RPM my tail gears lasted 10 flights before I had to change them. At 2200 I can get about 60 before I swap them. I also found that if you fly off dirt the tail gears wear 10x faster and require rigorous maintenance.
Old 06-06-2012, 04:58 AM   #10 (permalink)
My orginal white tail gears lasted 300 or more flights before a tail bump striped them, Still have the white main gears on the shelf as spares, put the black ones in just because it looked good. I have done a few sets of tail gears due to contact with the ground, some of the front gears do not mesh well with the big tail gear, I had to try a few to get a real smooth one
rex09 is offline        Reply With Quote Quick reply to this message
Old 06-06-2012, 10:02 AM   #11 (permalink)
Default Fusion Gears....
I stripped a front bevel gear in flight last week. I guess I got away with it for so long because I didn't put enough load on the gear until that day.
All the TT gears were damaged so I changed all 7 gears. The front gear case had to be replaced too because it was in 4 pieces. I was running the kit white gears and now they're all black. I'm having to shim the tail rotor shaft to eliminate end play there and had to add shims on the front TT bearings to eliminate the left/right play in the front bevel gear. I have it together but I think the auto gear is meshed way too tight with the small TT transfer gear. Something is causing way too much drag with it all together when I turn the head. The gears are very noisy too. I've spun it up and the Vbar vibe analysis reads 174 with all the new parts. I guess I'm going to have to go back and pull it apart and look at each mesh until I find the problem. I'm not sure I'm liking these black Outrage gears right now.
nickt919 is offline        Reply With Quote Quick reply to this message
Old 06-06-2012, 10:37 AM   #12 (permalink)
Be aware a number of us filed the 12 tail block holes so we could adjust our own mesh from the big tail gear to the small tail gear. After putting on all new gears... and after 5-10 flights... you should get at least 20 rotations if you spin the main blades by hand as fast as you can. Otherwise your mesh is too tight somewhere.
Old 06-06-2012, 02:42 PM   #13 (permalink)
After reading this you gave me an idea....I loosened the 12 SHCS on the tail bock and horizontal fin mount then found the tightest spot in the mesh. Then I ran about 6 layers of plastic from a spare parts bag in between the gears and tightened everything back down. When I pulled the plastic from between the mesh it was set just about perfect. I'm sure a flight or two will have it loosened just right.
Old 06-06-2012, 02:48 PM   #14 (permalink)
what is a SHCS?
Old 06-06-2012, 03:05 PM   #15 (permalink)
socket head cap screw...
http://www1.mscdirect.com/eCommerce/...id=12527441584
