550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
09-09-2015, 04:34 AM | #22 (permalink) |
http://www.hobbyking.com/hobbyking/s...A_60A_ESC.html
Works fine with Hobbywing Platinum 100A and 50A V3. You need also a male to male Servo cable.
Goblin 700C Red Carbon, Kosmik 200 Cool, Pyro 800-48, MKS X8 HBL 950/980, Spirit-Pro, Jlog2.6, GPS-Logger2 Jeti DS-16 Red Carbon + REX7 |
04-24-2016, 11:38 AM | #23 (permalink) |
Hi guys
This thread is so re assuring . Actually i am very dissapointed from talon 90. Well partly it was my fault too i was running at 2500rpm on stock 550dfc . It just shut down on me and heli came straight down . Luckily nothing fot damaged. I then lowerd max HS to 2100 rpm governed. Heli motor just turned off during a loop and it came down like a brick. Got some damages . I found out that black wire conmector solder joint inside the esc was loose. Not sure it was loose after the crash. But weired esc behaviour suggested that it could be previous issue. Im thinkin of 100amps hobbywing platinum v3. As talon becomes c hot and motor too. |
04-24-2016, 03:04 PM | #24 (permalink) |
I just switched to HW 100A v3 today running with Spirit GOV. It performs way better than Talon 90, I can do tik tok constantly for 1 mins without losing power while Talon 90 starts losing HS after several tck toks! The ESC is barely warm after 4 mins of smack 3D. The temperature here is 11 degrees.
04-25-2016, 12:14 AM | #25 (permalink) | |
04-25-2016, 12:39 AM | #26 (permalink) |
Guys i am now waiting for Hw 120a platinum which is 20usd extra than 100a. But issue is its not in stock at the moment. What do you guys think? Should i go ahead with 100a if i need to do hard 3d in my stock 550dfc or 120a is worth the wait .
04-25-2016, 03:25 AM | #27 (permalink) |
guys i decided and went ahead with HW 100a esc v3 as HW 120a esc v4 will take few months to be restocked in banggood. so i thought i would give this one a try.
04-25-2016, 06:56 AM | #28 (permalink) | |
Location: Perth, Western Australia (the most isolated (AND COVID FREE!) capital city on earth!)
Paolo
XLPower 700, ALIGN 550L (beater), Prôtos MAX V2 Leggero 700 & Evoluzione 800 (RCHN #803 - joined just before they shut up shop!) |
04-25-2016, 09:26 AM | #30 (permalink) |
Oh ok bro. I just ordered, i will rebuild my 550 and see how it lerfomrs. Here temps are between 30-35. Could go upto 45 in hot summer too.
04-25-2016, 11:12 AM | #33 (permalink) |
Yes bro . Are you using programing card aswel . Can we use simple usb to micro usb cable to connect it to pc or do we need a special cable for that?
04-25-2016, 11:17 AM | #34 (permalink) |
550L question
Will the HW100 fit in the nose of the 550L directly in place of the Talon 90? with or without the fan?
Anybody have a few pics of the installation in the nose or in an alternate location? I was going to use a YEP 120HV I had as a spare, but the only place that would fit would be under the main gear and attached to the mid lower frame support. Wiring is ugly and I would have to make a tray for it. Not the cleanest or easiest option. |
04-25-2016, 01:54 PM | #36 (permalink) | |
04-25-2016, 02:12 PM | #37 (permalink) |
731 flights on mine. HW 100a LV. You won't be disappointed. I'm running with the fan and using internal BEC.
04-26-2016, 03:22 AM | #38 (permalink) |
wow thats cool bro. but what about smack 3d. liek strong collectives and rainbows? its it good on stock 550 dfc. ?
