Go Back   HeliFreak > R/C Helicopter Support > Compass Helicopters > Compass 7HV, 7HVU and Chronos
Compass 7HV, 7HVU and Chronos Compass Compass 7HV, 7HVU and Chronos Model Helicopter Discussion
Old 03-07-2012, 09:26 AM   #1 (permalink)
Default squeak and clicking noise
i just noticed this today with the blades off. was checking for vibrations on the vbar. and i notice i had alot more than i did when i first setup the helicopter. i tried my best to record the sound....but its not very loud...well it is on mine since i have good speakers....but..here is the video for whoever can make out the sound
[ame]http://www.youtube.com/watch?v=KM-O7MfUZI4&context=C3745549ADOEgsToPDskJXNxfJWVFo3b4 XJX8EKU3C[/ame]
Compass 7hv - Fusion 50 - Trex 550 Stretched
Scured is offline        Reply With Quote Quick reply to this message
Old 03-07-2012, 09:29 AM   #2 (permalink)
Did you lube the belt and the idler bearings?
My Atom developed a similar squeak-it was the dry belt rubbing the flanges on the idler pulleys.
Old 03-07-2012, 09:48 AM   #3 (permalink)
i did before i first flew it =\. only flown it 4 times. i can lube them again and see. is that also the clicking noise? if you can hear it
Old 03-07-2012, 09:51 AM   #4 (permalink)
I could hear the clicking, but could not identify the source-my apologies.
Make sure all the bearings are lubed, for the squeaking issue.
Old 03-07-2012, 09:52 AM   #5 (permalink)
i also have one more quick question. how do i prevent my flight pack wires from getting cut on the frame? this happened twice already. first time i heat shrinked it. second time i plug up and see smoke and unplugged it fast...pulled out the battery tray..and its cut again. im trying my best to be careful when loading and unloading...but i just dont know
Old 03-07-2012, 10:10 AM   #6 (permalink)
The first thing everytime I receive a new model is to sand the edges of the frame to prevent any cutting of wires, lipos etc. I presumed you sand your frames.
Gaui X3 Fubar Trex 500 Vbar
Trex 550 Vbar Compass 6HV BD3SX
Compass 7HV HC3SX Compass Chronos HC3SX
chucky21022002 is offline        Reply With Quote Quick reply to this message
Old 03-07-2012, 10:15 AM   #7 (permalink)
meh no i did not sand them =\ i forgot about that honestly lol...ive never done it before on my other helis =\ guess ill do that and see if that works, didnt think it was that sharp
Old 03-07-2012, 10:16 AM   #8 (permalink)
Mine had the klicking noise develop too! its something to do with the one way bearing. I found that if I pulled the tail pully gear away from the main gear on one side it would go away. I took the hole gear assembly apart but I couldnt find any obvious issue so I put it back together again and the click was gone! I think it had something to do with the lateral load from the belt. If I took the belt off there was no click!
6hv (fb)
7hv
DX8
snaaakeey is offline        Reply With Quote Quick reply to this message
Old 03-07-2012, 10:50 AM   #9 (permalink)
thanks a lot guys! quick responses. will check this thing out now
Old 03-07-2012, 11:17 AM   #10 (permalink)
well i took out the main gear/auto gear...and the noise is coming from these gears when i spin em by hand i still hear the squeak and the clicking
edit: ok. i cleaned out the one way bearing. (was really oily and black stuff all in it) and put in some grease. and closed it back up...squeak is now gone. i still get a click noise, but not as bad as before. i did notice i can get one of the bearings in the hub to click but turning it back and forth over and over and ill hear it every once in a while...but it feels pretty smooth...maybe i need to replace that bearing
Old 03-07-2012, 01:11 PM   #11 (permalink)
May I suggest the neoprene tubing used as moulding on the edge of the frames as pic below:
= Rb43 =
Old 03-07-2012, 01:44 PM   #12 (permalink)
thanks, do you have a link to the tubing that you used? thats a good idea.
i still have the clicking noise even with the main gear assembly out of the helicopter. the squeak is still gone....but..click...i have no idea
Old 03-07-2012, 02:34 PM   #13 (permalink)
Check each bearing individually.
ochants76 is offline        Reply With Quote Quick reply to this message
Old 03-07-2012, 09:11 PM   #14 (permalink)
Formerly BarnStormer
Link please!
Scorpion Power Systems
Jason O'Connell is offline        Reply With Quote Quick reply to this message
Old 03-07-2012, 11:15 PM   #15 (permalink)
I think it's called haye's, black obviously. Works great, I use it too sine I have no more nitros.
Cullen Colapietro is offline        Reply With Quote Quick reply to this message
Old 03-10-2012, 08:45 PM   #16 (permalink)
I just noticed on the click noise? On mine I can hold the main gear with my hand then grab the head and move it back and forth I noticed a slight gap in the bolt that holds the main gear to the main shaft? I mean the main gear moves side to side on the main shaft. Like the bolt holding the main gear is to small in diamiter is this normal with the 7hv? Or could I have gotton my main shaft upside down? I was thinking this could be the click your hearing??
"Quit crying about your airplane and fly it already!"
weaselbean is offline        Reply With Quote Quick reply to this message
Old 03-12-2012, 03:01 AM   #17 (permalink)
mine doesnt seem to have any play like that
Old 03-12-2012, 09:01 AM   #18 (permalink)
Thank you for the reply, I will be looking in to my problem. I have not maiden it yet maybe this is why I hear of people shearing of their lower Jesus bolt?
Old 03-12-2012, 03:03 PM   #19 (permalink)
There is play on the bolt through the main shaft if there isn't a tiny bit, something is wrong. You should not crank down on that bolt of or the grub screws that go into the OWB as it will warp the assembly a bit making OWB failure or wear more likely. I found that the squeak on mine was coming from the tail older pulley on the tail case You don't want the idler touching the belt as it can wear prematurely and start to squeak.
SAB USA Factory Pilot/Field Rep. Pulse Battery USA Field Rep. BK Servo Team Pilot. Team Spartan USA. Canomod USA Field Rep.
alexmit is offline        Reply With Quote Quick reply to this message
