HBFP V1/V2 E-Sky Honey Bee V1 & V2 Fixed Pitch |
11-07-2011, 06:11 AM | #201 (permalink) | |
Well done mate You were holding her in there pretty well a few times. Keep it up and it wont be long before you will get through a pack with no crashes.
T-Rex 700E Pro DFC HV Brain | T-Rex 600E Pro DFC V-Bar Silverline 5.3 Pro |T-Rex 500 DFC Pro mini V-Bar T-Rex 450L Dominator | JR DSX9 9503 Mode 2 |
11-07-2011, 06:12 AM | #202 (permalink) |
Roflmao....I love the ending!
FWIW, I think you are passed the training gear stage now. When you are learning to get a stable hover, as you are, the training gear can be more of a hinderance than a help, as it swings around like a pendulum and makes the heli sluggish. Once the heli starts to drift, with the training gear on, you need a bigger correction to stop it. Then the heli swings back the other way, and you need an even bigger correction as it builds up momentum. Without the gear on, that momentum build up is smaller and you need smaller corrections, meaning you are less likely to over-correct. Just a thought....it's entirely up to you.
450 Bell 222, 450 Jet Ranger, HBFP Redbee Extreme, 500 size Blackhawk MH-60, 600 EP Spitfire, Sebart 342 30e, Davy Systems Flybaby, ST Models FW190, Micro SU26 & GWS P38. DX7s |
11-07-2011, 06:25 AM | #203 (permalink) |
firstly luke, this one is rewally low weight. I bought it recently by mistake and i want to get every bit of use out of it. although it does help whatso ever.
secondly, yea, I am okay, thanks for asking and I am still waiting for a reply! damn those noobs! as you saw in the tail setup, arent 2 hbv2 heat sinks and a thermal paste better than a cp3 tail heat sink? |
11-07-2011, 06:41 AM | #204 (permalink) |
Since those bastards didnt reply to my email I called them and they told me that they were out of stock for the CP3 Tail heat sink and they sent me two hb sinks aparently they do the same job. and when they get in stock, they will send me the cp3 heat sink and I can keep these heat sinks for free
so Now, I am waiting for thermal paste and then I will snap on the 3 heat sinks i have |
11-07-2011, 06:46 AM | #205 (permalink) |
it looks like those heatsinks are the correct shape but they are about 1/3 as wide as the proper cp3 one. you could be ok with those 2 and thermal paste just keep an eye on it as time goes by for signs of the motor wearing out (or smelling bad/hot after/during flight).
[edit] you will only fit 1 smaller one on in addition to the cp3 h/s, and maybe not even that as you need to make sure you are not covering the air vent near the end with the h/s.
T-Rex 700E Pro DFC HV Brain | T-Rex 600E Pro DFC V-Bar Silverline 5.3 Pro |T-Rex 500 DFC Pro mini V-Bar T-Rex 450L Dominator | JR DSX9 9503 Mode 2 Last edited by Steemo; 11-07-2011 at 06:48 AM.. Reason: more info |
11-07-2011, 06:47 AM | #206 (permalink) | |
I'm with Luke on the training gear, even light weight objects have a large influence on flight characteristics when placed so far away from the center of gravity, especially if they're able to move a bit, it only amplifies the pendulum effect. The ping pong balls make for great cat toys by the way
HB FP V2 (Night Bee) and CP3 (in bits and pieces), GW 9958. Electronics enthusiast. Duck and cover! |
11-07-2011, 08:19 AM | #207 (permalink) | |
I hear what you are saying about the weight...but to be honest, it's not so much the weight as the position of the weight. Because the training gear hangs down lower than the heli, it shifts the whole centre of gravity to a lower point. That is what gives it the pendulum effect! edit: now I just read DVD's post..."what he said!"
11-07-2011, 10:07 AM | #209 (permalink) |
Video's gone
Raptor 50 TitanSE - AR7200BX + RJX head Raptor 550E with a flybar!! Align 500 pro with Speed fuselage mCPX V2 |
11-07-2011, 01:16 PM | #210 (permalink) |
i get the gear stuff, its pretty obvious how a higher gear means more speed but less power. But I am just saying what bladfes are perfect for stock steup?
btw, broke another blade :/ I just have to wait for the super blades to arrive alllllllll the way from america |
11-07-2011, 01:35 PM | #211 (permalink) |
Stock setup is compatible with stock blades, Xtreme 10 degrees wooden blades, and I think Superblades EZ, not sure about Superblades XP.
For hover training use stock blades or Superblades EZ, for outdoor (fast) forward flight use 10 degree woodies or Superblades XP
11-07-2011, 02:06 PM | #212 (permalink) |
ll, i ordered xp...... because nuttcase told me to skip ez. i hope itll work. but i still have to wait aaaaaaaages
11-08-2011, 12:29 AM | #213 (permalink) |
If your 3cell setup is totally stock I like the V-L modified blades. Its trimming 10mm off each tip in a rounded pattern. Slightly higher headspeed/stability with much longer DD life.
Every time I crash I wonder, why didnt I get into RC tanks. |
11-08-2011, 04:54 AM | #214 (permalink) |
Hovering outside in the cold
I am going out to the park with an embarrasing hat with my keychain cam on it and a key chain cam on the heli and a normal picture camera on a tripod. That'll give you 3 angles i hope. Ill upload all of em on youtube and embedd below
11-08-2011, 05:12 AM | #215 (permalink) |
11-08-2011, 05:17 AM | #216 (permalink) |
you know the rule, never finish your popcorn before the movie starts
the 3 cams and battery are still charging, |
11-08-2011, 05:40 AM | #217 (permalink) |
C'mon......
11-08-2011, 05:43 AM | #218 (permalink) |
key chain cams done. just waiting for digi camm to finish and the 1300 mah battery too.
I used come weak velcro i found lying around to attatch cam to hat and its working pretty well. Just need to look up more. I just need to figure out how to attatch cam to heli properly.... |
11-08-2011, 05:53 AM | #219 (permalink) |
Felix, I've got a small cam attached to my Bee, I use some velcro with 3M backside to stick it to the bottom of the frame and then use some tie wraps to keep it from vibrating too much. The Velcro dampens most of the head's vibrations while the tie wraps prevent it from being too loose.
Tags |
beginner, day, honey bee repair mod tail, honey bee v2, hover |
