Go Back   HeliFreak > R/C Helicopter Support > Gas Powered Thoughts
Gas Powered Thoughts Advice for Gas Helicopter Success from Carey Shurley
Old 08-18-2016, 06:52 PM   #1 (permalink)
Default News - Helibug Aerodyn Power Module
Another new product from Helibug, its called the Alligator Aerodyn
Helibug Alligator Aerodyn
This is a totally new engine module variant. In this setup the cooling fan shroud is removed and the fan is lightened by removing the outer set of cooling fins. The idea here is to reduce weight
I'm probably not explaining this adequately so I'd recommend following the link and reviewing the photographs
It would appear that this will be the basis for an entirely new line of conversions based on this power module. The first being for the Trex 600 series
Helibug Aerodyn Trex 600 Conversion
Carey Shurley
Proprietor - Gas Powered Helicopters
carey shurley is offline        Reply With Quote Quick reply to this message
Old 08-21-2016, 09:03 AM   #2 (permalink)
Default Design
Looks like Ali decided to take out the bottom motor cover and cut the cooling fan in half. Should be lighter for sure however the engine would run warmer as well, less meat for the heat to propagate to and less cooling will probably work OK in cooler weather its the hotter weather that one needs to be more vigilant about engine temps.
-=>Raja.
MA 1005, Hanson 270, 4717 flts, Spectra-g, Hanson 270, 3672 flts
Whiplash-g V1-2, Hanson 300, 2235 flts, Whiplash-g V2, Hanson 300, 1552 flts
Whiplash Turbine, TS 45i WSE, 296 flts
Jewel on-board Generators, Miniature Aircraft Team Manager
rbort is online now        Reply With Quote Quick reply to this message
Old 08-21-2016, 01:06 PM   #3 (permalink)
Interesting
less weight on fly wheel means engine will rev faster
half the blades means less h.p. used for blowing cooling air = more usable h.p.
but what will be the temperature increase ?
If a person doesn't increase head speed or pitch it may be a wash
Have to wait and see as I am not usually an early adopter !
banshee rider is offline        Reply With Quote Quick reply to this message
Old 08-21-2016, 06:34 PM   #4 (permalink)
Carey have they done any testing on it yet ?
Old 08-21-2016, 06:46 PM   #5 (permalink)
no, I didn't know it existed prior to the day I posted the news
Carey Shurley
Old 08-24-2016, 07:59 AM   #6 (permalink)
Originally Posted by banshee rider View Post
Interesting
But that may only make a meaningful difference in initial spool up (where we don't want it to be fast anyway). Once the clutch is locked up the engine is turning the entire mass of the full gear train and blades anyway so I'm not sure how significant the effect will be? Maybe it will recover a little better from bogging, i don't know.
(actually this is a good questions for people who have flown both RC and PUH formats- do PUH feel snappier and recover better?)
The cooling I agree is concerning. Note that Ali says he only supports it for stock engines because "tuned engines make too much heat' ( which should be true as we know more power = more fuel = more heat)
MA Whiplash Gas v2 | HelixHeli T700 Gas conversion | G500 Raw | Trex 450 Sport FBL | OMP M1
Futaba, Bavarian Demon, Hanson Engines| DIY Lithium field battery
jharkin is online now        Reply With Quote Quick reply to this message
Old 08-24-2016, 08:01 AM   #7 (permalink)
My other concern is the one I elaborated on in the Protos Max thread in the gasser room. By eliminating the front frame he is making the engine a stressed member of the airframe and all the landing loads are passing through the fan case. I'm worried that we will see the cracked case problems again.
Old 08-27-2016, 09:32 PM   #8 (permalink)
Default No
There is no discernible difference in recovery that you can really tell. In fact I think the other way, the more mass on the fan the more smoother the engine is, the mass takes away from the pulse shock wave, and the heli tends to be smoother.
Cut the fan down and not only will you add some heat due to less cooling but you will make the motor less smooth. May not be much, but its there allright.
And I agree, maybe some cases will begin to crack when the motor case is part of the helicopter airframe. Only time will tell, give me one of those to test (not saying that I want one) and I can find out for sure for you in short order.
-=>Raja.
Old 09-13-2016, 07:35 PM   #9 (permalink)
I don't know of this idea will work or not , but it's great that people are trying to improve the performance.
Helifreak #262-Past helis-Shuttle, Hawk, MA Fury, Ma Fury Extreme, Ma Stratus, Trex450,Trex700 nitro, WhiplashG, 7HV, Chase360, 180cfx, KDS A7 Current helis-KDS Agile 7.2, SAB Raw, Trex 500x, KDS agile 7.2 gasser
goof2 is offline        Reply With Quote Quick reply to this message
