250 Class Electric Helicopters 250 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
03-27-2012, 12:54 AM | #61 (permalink) | |
03-30-2012, 03:54 PM | #62 (permalink) |
OK, my refund is in and I am screaming to make an order on the 250 batterys. Did anyone decide that the Hyperions will fit the stock canopy. There is so many opinions out there I am spinning. I usually can google and figure out what I am doing. This is the first time I cant figure out what to pull the trigger on....
04-01-2012, 10:59 PM | #63 (permalink) |
I have the 900 45C Hyperion and its a tight fit under the stock hood. Thae battery rocks. I have the first 250 V1 with some SE parts.
04-02-2012, 02:31 PM | #64 (permalink) |
Where did ya order them from and can ya get them with JSTs stock?
04-02-2012, 06:27 PM | #65 (permalink) |
When I go to Chicago IL there is a hobby shop that carries Hyperion.
I paid $18. They do not have plugs on them. I use the micro deans. I got a 1900 45C for my 450 pro for $24 and rocks too. I used to Thunder Power but there wire for the balancing plug are to stiff and always broke and I had to resolder the wires back to the cells. They are powerful and lite but I like the Hyperion's. Customer for life. I have been getting lipo's since 2005. They were alot back then and were like 12c. Now more C's for less. |
04-07-2012, 06:09 PM | #66 (permalink) |
For the small extra size and weight the XT-60 are well worth it.
similis vobis fugere eam furatus "The beatings will continue until morale improves." -- William Bligh |
04-14-2012, 09:21 AM | #67 (permalink) |
I wonder if someone can recommend a good charger for the Gens Ace Lips above. Hobbypartz has been sold out of the Gens Ace charger for some time now. Thanks.
mCX2, Walkera Lama 400, Trex 250 SE (Building) |
04-14-2012, 11:14 AM | #68 (permalink) |
I have a Skycharger B6AC, and it works pretty well for up to 450 size helis, it comes with an internal ac power supply, and can also be run off an external supply or a 12v battery. It's ability to charge large capacity lipos is limited, though, so if you intend to move up to 500 size helis or bigger you might want to consider something more capable.
MARTY Team Newb pilot Trex 500 fbl -Tarot 450 Pro fbl- 300X - 130X X3- mCPX brushless X3-Nano cPX X 2- Nano QX |
04-28-2012, 09:18 PM | #69 (permalink) |
turnigy nanotechs are good
05-18-2012, 12:06 AM | #70 (permalink) |
For the guys useing the 3S 1000mAh Gens Ace lipos..Does it fit under the canopy and does the heli balance good?
Team Align |
11-15-2012, 09:12 PM | #71 (permalink) |
subbed.
you should look into it........... |
11-15-2012, 11:52 PM | #72 (permalink) |
anyone using these in a 250.....ordered 2 so they better fit!!!
http://epbuddy.com/index.php?main_pa...roducts_id=353 Sent from my phone using Tapatalk2...otherwise i would of sent it from my home PC.
