X5 Discussion and support of the Gaui X5 |
03-17-2015, 12:11 PM | #61 (permalink) |
Ok, the only wire that should plug in there is a sensor wire (only one (usually)white wire) that tells the vbar how many times your motor is turning.
correct. That is all I have running to mine. If you BEC has two outlets (western robotics) plug the other wire into the sbus receiver too. Or what some people do is get an adapter for one of their servos to be able to plug the BEC and servo into female ends of the adapter, and the male end to the servo output on vbar. http://www.motionrc.com/100mm-4-serv...Z2_xoCzhfw_wcB It's not necessary but if you feel the need. |
03-17-2015, 12:23 PM | #62 (permalink) |
For clarification, the rpm sensor wire must go to upper pin of RX-A
|Michalis| ...let the flying be second nature! |
07-26-2015, 12:49 PM | #63 (permalink) |
Has anyone had any problems with the BEC so far?
I'm trouble-shooting "governor input contains glitches" errors in the VBar log. When I do collective pumps from a hover the heli bogs and BEC voltage drops to zero (OptiPower backup steps in). More noticeable with low HS than with high HS (more current draw on climbouts). I think in my case I have a short with the motor, the stock Gaui GM-601 is only rated at 65A cts. When I bench-test the model my BEC voltage drops from 8.4V down to 8.1V with the motor running, and no errors in the log. So I think the problem is with the motor. I tested motor leads for continuity - seem fine. Anywho, gonna get an XNova 4020 1000kV motor and 15T pinion for 6mm motor shaft. Hopefully it's a faulty motor.
Synergy E7se | Mikado 690SX V2 | Goblin Black Thunder T | Gaui X3 | brushless mCPx VControl | MKS & KST Servos | Pulse Heli-X8 | Lynx Team Pilot |
07-26-2015, 01:44 PM | #64 (permalink) |
Set pitch pump in Vbar to 100 and try a bench test again. If it Browns out you'll need either a better bec or a cap to supplement the current bec.
Heli's I have: Goblin 500 (Vbar Neo), Gaui X5(Vbar Neo), X7(Vbar Neo), Innova 600 Night heli (Vbar Neo Vbar Vcontrol I'm the not so newbheliusr as I have been here a while. But I like this name. |
07-26-2015, 01:53 PM | #65 (permalink) |
Thanks, I'll try that once I put the motor back into the heli. I took out the GM-601 and the wires coming out of the motor look almost melted together, that's how hot it got. Definitely not a good sign.
So far I'm pissed at Gaui's motor quality. My GM-302S on the X3 had to be also swapped out for an XNova, I also kept getting gov input glitch errors. And the Gaui ESC's BEC was sagging in voltage on the bench with the heli sitting still. So I swapped it out for HW 50A V3 and haven't looked back. Gaui X3 flies amazing now, very reliable and consistent power delivery.
07-26-2015, 02:21 PM | #66 (permalink) |
I use the internal bec the Hobbywing v3 100A in my goblin 500 and it has been rock solid. I originally had a scorpion bug on it, but I removed it after monitoring the bec voltage telemetry for a hundred flights or so and never seeing it drop by more than 0.4V. I've been running it without backup for 200+ aggressive flights with no issues.
If you're wondering "why remove the bug?" it was because I often leave the heli in the hot car and got tired of taking it off and puting it on all the time.
Citizen 529 |
07-26-2015, 02:55 PM | #67 (permalink) |
Sweet, which motor are you running?
07-26-2015, 03:44 PM | #68 (permalink) |
Quantum 4120-1200
Citizen 529 |
07-26-2015, 04:32 PM | #69 (permalink) |
I should mention that my gov 500 uses mini servos, not full size like the x5. It should still be fine though. I'm using BK minis which have full size motors.
Citizen 529 |
08-13-2015, 04:05 PM | #70 (permalink) |
I found the problem - faulty motor. Replaced with XNova 4020 1000kV and everything is fine now.
What VGov gain is everyone running in heli mode? Has anyone succeeded to running in airplane mode and not having a nasty motor kick on startup?
08-20-2015, 08:22 AM | #71 (permalink) |
Ordered a V3 after original failed the Spirit BEC test. Are you all running stock settings for motor?
Oxy 2, X3, Protos 380, G420, Logo 480, Trex 500X, Logo 550 SX |
08-23-2015, 11:09 AM | #72 (permalink) |
Stock motor settings seem to be pretty good. I have not had to use anything different, and that is on 3 different helis/motors.
Citizen 529 |
10-10-2015, 04:45 AM | #73 (permalink) |
The Platinum-100A-V3 sounds like a great ESC to simplify my wiring a bit.
Currently I run the YGE100A with external Hercules super mini BEC. What I read here is it will fit on it's side in between the frame. No CF modding needed right? (Not using the fan.)
TSH Gaui X5 FES, Spirit, S.Bus, HW100A V3, Formula swash/head TSH Gaui X3, Spirit, 6S, S.Bus, HW50A V3 Futaba T7C (I admit, also a Spektrum DX8 and some planks.) ;-) Phoenix R/C v5 |
10-10-2015, 09:53 AM | #74 (permalink) |
If you don't attach the fan it will also fit flat on the bottom space (its housing only a few millimeter wider than the CF frame):
- GAUI X5 (Mini VBar, stock servos, Scorpion 910kV motor, HW Platinum v3 100A) - TRex 450 Sport DFC (Microbeast, TGY-306G, Y40A, BL450M) - DJI F450 pro (NazaV2/GPS, SunnySky 2212, MWC Light, GoPro 2 BL gimbal) - Blade mCPX, Futaba T8FGs, Heli-X Sim |
10-14-2015, 02:19 PM | #75 (permalink) |
Thx for the picture Rebel10.
At this moment I run the Hercules Super Mini BEC. This external BEC has two servo wires to handle the current. The hesitation I have is that the HW 100A V3 only has one servo wire to handle the BEC current. Could this be a problem with my Align DS610 / DS650 combo?
10-14-2015, 02:24 PM | #76 (permalink) |
If you look earlier in the thread, I mounted mine vertically. Minimum CF cutting.
10-14-2015, 02:28 PM | #77 (permalink) | |
So the CF cutting is only needed for the fan to fit right?
10-14-2015, 02:36 PM | #78 (permalink) | |
I'm just a neat freak, that's all. Like all my stuff bolted down and secure with cable ties lol there's like 1000 ways to mount that ESC on the X5
10-14-2015, 03:07 PM | #79 (permalink) | |
Citizen 529 |
10-15-2015, 01:11 PM | #80 (permalink) | |
If anyone needs a HK buddyprice code, it's valid for 14 days. (You need to login to use it.) I'll let y'all know how it goes when it gets here.
