Go Back   HeliFreak > R/C Simulators Support > Phoenix Flight Sim > Phoenix Custom Creations
Phoenix Custom Creations Phoenix Flight Sim Custom Models and Fields
Old 01-11-2013, 10:15 PM   #1 (permalink)
Default Goblin 500 scheme request
I have made a goblin 500 variant and would like to also have the red and white scheme too. Could somebody please make this scheme?
ID:	382970   Click image for larger version
ID:	382971   Click image for larger version
Goblin USA KDE Direct
Pulse Batteries
BK Servo
Switchblades
Mikado VTeam
Team Pilot Jordan Martin
JNMIA is offline        Reply With Quote Quick reply to this message
Old 01-22-2013, 06:02 AM   #2 (permalink)
Would you mind sharing the one that you've already made?
Rclover is offline        Reply With Quote Quick reply to this message
Old 01-22-2013, 06:06 AM   #3 (permalink)
Double post sorry
Old 01-22-2013, 03:23 PM   #4 (permalink)
Couldn't figure out how to convert the file so that I could upload it so just going to have to do it the hard way. copy and paste everything below starting at '
-- Phoenix R/C model variant file
function applyVariant()' into Notepad and save it with the name goblin700_500.pxv. then move the notepad file to phoenix/variants/helicopters and it should work.
-- Physical
newObjectType.Model_setup = 50.0000
newObjectType.Weight = 2.9091
newObjectType.Vertical_centre_of_gravity = 0.1529
newObjectType.Yaw_inertia = 0.0600
newObjectType.Pitch_inertia = 0.0600
newObjectType.Roll_inertia = 0.0600
newObjectType.Frontal_drag_area = 0.3704
newObjectType.Lateral_drag_area = 0.0900
newObjectType.Vertical_drag_area = 0.1389
newObjectType.Robustness = 45.0000
newObjectType.Maximum_fuel_flight_time = 0.0000
newObjectType.Pilot = 0
newObjectType.Cockpit = 2
-- Motors/Servos
newObjectType.Power = 1.6544
newObjectType.Engine_RPM_at_max_torque = 15000.0000
newObjectType.Main_gear_ratio = 6.3000
newObjectType.Minimum_throttle = 0.0000
newObjectType.Maximum_throttle = 1.0000
newObjectType.Throttle_response = { 0.1000, 0.0600, }
newObjectType.Cyclic_servo_response = { 1.5000, 0.0000, }
newObjectType.Collective_servo_response = { 0.8500, 0.0000, }
newObjectType.Tail_servo_response = { 1.0000, 0.0250, }
-- Options
newObjectType.Training_Gear = 0
newObjectType.Use_prebuilt_throttle_curve = 1
-- Fine_tuning
newObjectType.Lift_tuning = 80.6962
newObjectType.Cyclic_tuning = 115.5854
newObjectType.Tail_power_tuning = 106.3291
newObjectType.Knife_edge_tuning = 100.3956
newObjectType.Tail_wash_tuning = 95.5696
newObjectType.Engine_loading_tuning = 50.6329
-- Control_expo
newObjectType.Elevator_expo = 0.4292
newObjectType.Aileron_expo = 0.4292
newObjectType.Rudder_expo = -0.4292
-- Main_Rotor
newObjectType.Main_rotor_diameter = 1.0938
newObjectType.Main_rotor_chord = 0.0550
newObjectType.Minimum_pitch = -12.5000
newObjectType.Mid_pitch = 0.0000
newObjectType.Maximum_pitch = 12.5000
newObjectType.Pitch_curve = 1.0000
newObjectType.Blade_inertia = 0.2400
newObjectType.Rotor_head_damping = 0.8500
-- Lift
newObjectType.Hovering_stability = 90.0000
newObjectType.Ground_effect = 30.0000
newObjectType.Induced_cyclic_power_loss = 10.0000
newObjectType.Induced_tail_power_loss = 10.0000
newObjectType.Vortex_lift_loss = 16.0000
-- Flybar
newObjectType.Flybar_type = "Passive flybarless"
newObjectType.Frontal_cyclic_response = 0.8200
newObjectType.Lateral_cyclic_response = 0.8200
newObjectType.Flybar_interaction = 20.2532
-- Flybarless
newObjectType.Flybarless_agility = 141.7722
newObjectType.Flybarless_response = 100.0000
newObjectType.Flybarless_gain = 50.0000
newObjectType.Flybarless_active_response = 50.0000
newObjectType.Flybarless_active_delay = 50.0000
newObjectType.Flybarless_active_inverted = 0
newObjectType.Flybarless_auto_trim_enabled = 0
-- Rotor_Governor
newObjectType.Rotor_governor_enabled = 1
newObjectType.Governor_rotor_speed = 2800.0000
newObjectType.Governor_sensitivity = 100.0000
newObjectType.Governor_rotor_advanced = 1
newObjectType.Governor_rotor_speedA = 0.0000
newObjectType.Governor_rotor_speedB = 2000.0000
newObjectType.Governor_rotor_speedC = 2650.0000
-- Tail_Rotor
newObjectType.Gyro_mode = "Heading hold"
newObjectType.Tail_drive_mode = "Head driven"
newObjectType.Tail_RPM = 9200.0000
newObjectType.Tail_rotor_diameter = 0.2700
newObjectType.Tail_rotor_maximum_pitch = 45.0000
newObjectType.Tail_rotor_minimum_pitch = 40.0000
newObjectType.Gyro_sensitivity = 60.0000
newObjectType.Servo_delay = 0.0000
newObjectType.Max_pirouette_rate = 420.0000
newObjectType.Tail_fin_area = 0.0150
newObjectType.Tail_stabiliser_area = 0.0009
-- Undercarriage
newObjectType.Frontal_gear_friction = 0.0350
newObjectType.Lateral_gear_friction = 0.0350
newObjectType.Gear_spring = { 0.0100, 1.0000, }
newObjectType.Guide_wheel_travel = 20.0000
newObjectType.Gear_robustness = 60.0000
-- Sound
newObjectType.Engine_sound_type = "500 class electric (gearless)"
newObjectType.Engine_sound_volume = 100.3953
newObjectType.Engine_sound_pitch = 200.0000
-- Advanced
newObjectType.Collective_crispness_tuning = 75.1582
newObjectType.Collective_response_tuning = 72.7848
-- Control_profile
newObjectType.Control_profile_override_enabled = 0
newObjectType.Control_profile_override = 0
end
Pulse Batteries
BK Servo
Switchblades
Mikado VTeam
Old 02-03-2013, 07:41 AM   #5 (permalink)
That's an awesome variant. I really like how it flies, I turned the pitch down to +/- 10 and the Flybarless Agility from 141 to 120 as I felt like its a bit too agile to me. I can fly with it no problem, but sometimes it's just too much.
-J
Align T-Rex 550 DFC SELLING
AccuRC
Spektrum Dx7s
Jurica is offline        Reply With Quote Quick reply to this message
Old 02-03-2013, 08:14 AM   #6 (permalink)
Yeah, I have it set for extreme 3d but lowering the head speed and agility should make it much more docile.
Pulse Batteries
BK Servo
Switchblades
Mikado VTeam
Old 02-03-2013, 09:01 AM   #7 (permalink)
Smile
I see.. I re-made one and kept it saved for hard 3D when I will feel like it.. I can do hard 3D but I prefer the smooth, precise 3D flying.. I also find it to be excellent for doing wide steep figure 8 funnels. Do you have a 700 variant by any chance? Would you be kind enough to PM it to me if you do? Thank You in advance.
-J
AccuRC
Spektrum Dx7s
Old 02-03-2013, 09:05 AM   #8 (permalink)
I have it set on my radio so that when I go into idle 1 my headspeed is low. And idle 2 is really high so I don't have to go into the settings to change it. I do have a 700 variant and will pm It to you when I get back from the field today.
Pulse Batteries
BK Servo
Switchblades
Mikado VTeam
Old 02-03-2013, 09:07 AM   #9 (permalink)
Smile
Great! Thank You very much!
-J
AccuRC
Spektrum Dx7s
Old 02-11-2013, 11:01 PM   #10 (permalink)
I'm hoping to see some side on Goblin 500 images to make a good scheme shortly after release, I have a yellow / black 500 scheme in progress and will post it up once I have permission from the owner of the pictures and I finish up cleaning up the scheme, but here's a teaser for now.
DiceK is offline        Reply With Quote Quick reply to this message
Old 02-13-2013, 05:11 PM   #11 (permalink)
DiceK, why don't you share right now your scheme like we all did when we did some ?!...
thx
Flydynamics is online now        Reply With Quote Quick reply to this message
Old 03-14-2013, 10:33 PM   #12 (permalink)
hey buddy have you finished the goblin 500 scheme if so could you please share me and alot others would love this scheme thanks and let know
Brushless2401 is offline        Reply With Quote Quick reply to this message
Old 03-17-2013, 08:26 PM   #13 (permalink)
Here is the scheme, unfortunately I haven't had time to fix up some errors (backwards text on one side, some white spots), but here's how far I got.
I used the pictures posted by helidirect from this thread:
https://www.helifreak.com/showthread.php?t=492505
And modified one of the Goblin 700 schemes made by GSXR
Just take the file, change from .txt to .zip, unzip and put in the schemes folder for phoenix.
Old 03-24-2013, 09:43 PM   #14 (permalink)
Here is a updated version of the 500 that flies closer to mine. Just replace '.txt' with .pxv if you guys don't know.
Pulse Batteries
BK Servo
Switchblades
Mikado VTeam
Old 03-26-2013, 10:17 PM   #15 (permalink)
Default Goblin 500 red and white and Yellow plus Rails
I did not make the yellow design i modified the on posted earlier
the 500 was a modified yellow one
The Rails are not real Rail blades i made them up
http://www.mediafire.com/?5r2721mvp43ymv4
ID:	406963   Click image for larger version
ID:	406964   Click image for larger version
ID:	406965   Click image for larger version
Viper4060 is offline        Reply With Quote Quick reply to this message
Old 05-10-2013, 05:45 AM   #16 (permalink)
Default Goblin 500 for Phoenix sim
Hi guys could you pls help me, i have copied to note pad and then past in the forlder that says varients but i still cant find the 500 in the phoenix sim!
Thank you for your help.
Airwolf777 is offline        Reply With Quote Quick reply to this message
Old 05-10-2013, 06:23 AM   #17 (permalink)
Hi guys im really strugeling, how do i replace the txt with pxv, and where is it that i need to place these files? Also where will i find these veriants in the phoenix sim?
Old 05-20-2013, 06:04 AM   #18 (permalink)
It's a variant for the goblin 700 in the sim
DM_Maverick is offline        Reply With Quote Quick reply to this message
Old 03-06-2014, 11:30 AM   #19 (permalink)
Hello can't seem to be able to load it on phoenix 5 i put it in the folder but when i open the program can't find the model.
Grittner is offline        Reply With Quote Quick reply to this message
Old 03-09-2014, 01:12 PM   #20 (permalink)
schemes look sweet. Not sure what I did but I farted around until I got them to load. Probably have a mess of files in places just taking up room.
RichKnapp is offline        Reply With Quote Quick reply to this message
