700 Electric Conversions Align T-REX 700 Electric Conversions |
03-13-2010, 02:37 PM | #1 (permalink) |
Need info on gearing for 700 E conversion please..
I am looking to use the helidirect conversion for the 700 with the 560 scorpion motor and wanted to know if I would need to change my main gear on my stock 700 now.
Do I need a different pinion on it, teeth, or the one that I already have on the nitro will do ? If I need to change it can you suggest one and also the pinion I would then need for the motor ? Thanks in advance.. |
03-13-2010, 02:59 PM | #2 (permalink) |
Recommend reading through the various threads for what works and the reasons why..
The 4035-560kv is a tricky motor, as it easily strips main gears due to the high kv and low gearing, with shaft snapping issues. Personally, I will be running the 4035-400kv with 13T mod1 on the stock 8mm shaft in fixed end points. This addresses the high kv, poor meshing, shaft snapping and flight time issues.
T-Rex 700e 'Chrome Edition', Skookum 720, Turnigy , Scorpion motors, Align servos. DX8 with Turnigy 4000Mah Li-Po |
03-13-2010, 03:09 PM | #3 (permalink) | |
How can you tell whick gearing will affect flight time. I know you lose flight time with larger pinions but if you go from a 13 tooth pinion with a 115 tooth main gear to a 18 tooth pinion with a 164 tooth main gear will you lose flight time? Will the esc have to work harder? |
03-13-2010, 03:19 PM | #4 (permalink) | |
The higher the ratio, the more load is but on the motor, the shorter the flight time. Due to keeping the same ration, a stock 164/20T would have the same ratio and flight time as the new Align 115/14T mod 1 kit, with the Scorpion 4035-400kv motor. The 4035-400kv with a stock 164/20T setup has proven to be a cheap, powerful and reliable setup.
03-13-2010, 04:02 PM | #5 (permalink) |
After reading a bit on the setups, how about the 115t main gear with the 500 motor and a 13 or 14 tooth pinion ?
The speed calculator gives a bit over 2000 rpm and I guess I can use the gov. mode of the ESC for a target speed of about 2000 ? |
03-13-2010, 05:59 PM | #6 (permalink) | |
If not I guess I just need to stop doing hard punchouts or get rid of the zippys. |
03-14-2010, 05:09 AM | #7 (permalink) | |
Scorpion 4035 motors compared
03-14-2010, 09:49 AM | #8 (permalink) |
Thanks again for the reply, just need to ask you about the watts you mention. Keep in mind I have no idea about these numbers and what they mean. Is 3500 watts a good thing or a bad thing then ?
What would be the difference in flying times or heat issues between the 400 and 500 motors ? Assuming we are targeting around 2000 rpm, I see I should use a 15 tooth pinion I guess. Let me know if you can if I assume right, and also I appreciate your input on this. It has helped me understand more. Mario. |
03-14-2010, 10:26 AM | #9 (permalink) | |||
With out-runner motors, the lower the kv value, the more efficient the motor can be. Basically, the rpm's the 400kv motor produces is similar to a stock nitro engine, so similar gearing can be used. Higher kv motor basically revolve faster, so require a smaller pinion to gear them down, but introduce the gear stripping issue. Quote:
Highly recommend looking into this setup, they have had great success. https://www.helifreak.com/showpost.p...50&postcount=5
03-14-2010, 10:51 AM | #10 (permalink) |
THANKS A LOT for the explanations. Finally I can understand a bit about the motors and not just follow suggestions.
I appreciate it. Mario. |
03-14-2010, 11:15 PM | #11 (permalink) |
Just for info you care, I pulled just shy of 6200 Watts today with my hacker A50-14L 540kv. From what I could figure thats just over 8.3 horsepower.
