Go Back   HeliFreak > R/C Helicopter Support > Scale Helicopters
Scale Helicopters Discussions About Scale Helis, compatibility and and projects
Like Tree5Likes
Old 12-04-2010, 03:19 PM   #21 (permalink)
More picture....
Added tube spacers in the wing mounting holes. I didn't like the compression when tightening the two wing mount screws.
Three Futaba GY520's
hoot is offline        Reply With Quote Quick reply to this message
Old 12-05-2010, 12:37 AM   #22 (permalink)
Very very cool.....
I do have one question though........ It doesn't look like you have enough room between the pool table and the window for a pool cue. And don't you worry about balls going through the windows??
I have been arguing with the wife about getting one (a pool table) and she says we don't have enough room. I told her that we have 4500 sq ft....I'm sure I can find room.
Roban AS350. Roban Bell 429. Ikon
Jeti DS-16
JurassicJet is offline        Reply With Quote Quick reply to this message
Old 12-05-2010, 06:08 AM   #23 (permalink)
They also make great building tables.
Mike
" When inverted down is up and up is expensive"
rcmiket is offline        Reply With Quote Quick reply to this message
Old 12-05-2010, 06:43 AM   #24 (permalink)
Registered User
AWESOME build thread Hoot.
Thank you for sharing!!!
William James
Old 12-05-2010, 08:34 AM   #25 (permalink)
Originally Posted by JurassicJet View Post
Very very cool.....
I used this Brunswick online Space Planner...
http://brunswick.icovia.com/icovia.aspx
Room Size Requirements..
http://www.brunswickbilliards.com/he...uirements.html
Even going by their recommendations the fellows that put the table in gave me a little more room from the walls. The closest wall... the one with the window is 57" from the edge of the table. It works out great with full size cues. The window isn't as close as it looks. Only the end of part the window is in line with the table. The only complaints I have is the balls put dents in the wood floor.
Old 12-05-2010, 09:04 PM   #26 (permalink)
Remember all of this stuff gets covered up inside the fuselage once all flight testing is complete.
BTW: I chose Futaba gear because I like the simplicity of the system and the reliability of FASST.
Checking CG. It's perfect!
Old 12-06-2010, 08:42 AM   #27 (permalink)
Default Flight Control Description
As conversion takes place the Helicopter Mode Controls transform into Airplane Mode Control.
Aileron is accomplished with differential For/Aft cyclic of swash plates.
Elevator is accomplished with For/Aft tilt of both swash plates.
Rudder is accomplished with differential Collective Pitch of both swash plates.
Speed control is accomplished with symmetric Collective Pitch change of both swash plates.
In Helicopter Mode swash plate movements are:
Roll is accomplished with differential Collective Pitch of both swash plates.
Pitch is accomplished with For/Aft tilt of both swash plates.
Yaw is accomplished with differential For/Aft tilt of both swash plates.
Vertical control is accomplished with symmetric Collective Pitch change of both swash plates.
There is also a pitch governor that reduces pitch as power requirements exceed motor capability. This only engages in airplane mode and only above a preset rpm.
Explanation:
During conversions collective pitch is dependent on airspeed. As the ship converts the controller will intentionally over apply collective pitch. When the pitch governor detects RPM below the set value it will pull back collective pitch to prevent a bog. As airspeed increases the governor will allow higher airspeed. To effectively tune this setting an on board watt meter is necessary (max continuous of 400 watts).
Old 12-08-2010, 10:19 PM   #28 (permalink)
Bri
All the mechanical components in your "V22 Osprey" are awesome looking.
Thanks for sharing your build and all the great pics with us.
Brian
T-Rex 700F3C / T-Rex 450 Pro / Blade mCPX / Blade mSR / Blade mCX / Walkera 53Q3
JR X9503 /
Spektrum DX7
Phoenix Sim
Bri is offline        Reply With Quote Quick reply to this message
Old 12-13-2010, 11:15 AM   #29 (permalink)
You are all welcome.
I got the thing powered up the other night. Got all the latest firmware and software loaded along with the controller settings.
The nacelles are tilting. Got them on channel eight using the slider controller on the side of my 12Z. Need to do some adjusting of the nacelles. Got the ESC's programmed. Only thing left to do is set up the gyros. Waiting on the USB link for the GY520's to make that job a little easier.
Mike
Old 12-13-2010, 05:47 PM   #30 (permalink)
yesterday i was standing outside prepping some canopies when i could feel this dronning sensation. Kept looking across the sky cause i'm near the approach to miramar. I noticed it getting less intense and finally spotted what it was, a pair of v-22's at 5k feet. couldn't believe how loud in a different way it was.
Cool model, can't wait to see them all come to life. Do they fully support parts like a helicopter to crash and fly or is this a one shot gig?
US Drones
Aerial Media Pros
Ritewing
helipainter is offline        Reply With Quote Quick reply to this message
Old 12-14-2010, 11:05 AM   #31 (permalink)
Hoot this is a fantastic build project.
Thank you for sharing your progress and good luck with the fun stage (flight)
mike
"nothing is foolproof because fools are so ingenuous"
Logo 600SE, Vario EC135 Benzin, Bell 47g II Benzin, BO 105 big Benzin, Benzin trainer, T-Rex 600NSP V-Bar, 500ESP 3G, 450 Pro, 250, Beam 450,
mikmerl is offline        Reply With Quote Quick reply to this message
Old 12-15-2010, 07:17 AM   #32 (permalink)
Looking great. I thought about Sunday morning when 2 Osprey's flew over our field. Keep up the excellent work.
Mike
Old 12-20-2010, 10:18 PM   #33 (permalink)
Bri
Any updates hoot?
Brian
JR X9503 /
Spektrum DX7
Phoenix Sim
Old 12-21-2010, 03:54 AM   #34 (permalink)
I'm in the critical phase of setting everything up. I had to put things a side for the Christmas rush. I'll be back on it shortly.
Old 12-22-2010, 05:28 PM   #35 (permalink)
Great Build
Would be great to see a few of these in Australia
Regards
FourPlay26 is offline        Reply With Quote Quick reply to this message
Old 12-29-2010, 03:32 PM   #36 (permalink)
wow, that thing is intense!!! what's it take to build something like this as far as cost goes?
Had, Blade SR... tailmotor mod https://www.helifreak.com/showthread.php?t=252253
Hitec Eclipse 7 pro, blade MSR
Dw Foamies Yak 55 rest in pieces, DWExtra 330 sc
soon to be 450v2 fbl
mikeonthebike is offline        Reply With Quote Quick reply to this message
Old 12-29-2010, 03:41 PM   #37 (permalink)
I just found this video.
[ame]http://www.youtube.com/watch?v=mAazH_iQwSY&feature=related[/ame]
Old 01-02-2011, 07:27 AM   #38 (permalink)
Great looking kit. Does the kit come with the main blades? The website isn't clear on that fact.....
Thanks for this build thread I am anxious to hear your opinion of it's flight handling. Looks great on the videos.
There's alot of nuts in this hobby.
billyd is offline        Reply With Quote Quick reply to this message
Old 01-02-2011, 07:34 AM   #39 (permalink)
I've got $2600 total in it. That is the full fuselage version. Yes, it does come with carbon fiber main blades.
Rotormast V-22 Osprey, 2 450 Clones, BL P-51, Micro P51, Stryker, 2 Vapors,
Old 01-15-2011, 09:49 AM   #40 (permalink)
Hoot,
I have the kit and started my build. I am confused by the instructions for the rotorhead.
o-rings and thrustbearings are included in the kit (for the rotorheads), but are not mentioned in the instructions. Also if assembled per the verbiage of the instructions, (three standard bearings only per blade grip), I get some binding on a couple of the blade grips against the rotorhead if the locknut is fully tightened. It seems a narrow washer should be used between the innermost bearing and the rotorhead.
Finally the drawings in the instruction show an unnumbered washer between the outermost and center bearings of the blade grips, but no washer is included in the kit.
How did you assemble yours?
