Henseleit Henseleit Helicopters |
11-27-2015, 03:05 AM | #601 (permalink) |
I hope so, if i am lucky i ll be able to make the maiden flight still in 2015
Frederic |
11-27-2015, 05:27 PM | #602 (permalink) |
Let us know how the build goes!
Mark Dusty Shelf queens: TDR2, TDR, Protos Max, Logo 550SX, Protos 500, Jeti DS-16, etc.... |
12-13-2015, 05:40 AM | #603 (permalink) |
In some of the pics I see Kosmic cool with black top plate do any of you know how I can get one like that?
12-13-2015, 05:51 AM | #604 (permalink) |
Jan has as special edition Kosmik cool. Another trick is to machine an existing cool top to fit the TDR2 and then anodize it black. Lose warranty then.
Henseleit TDR, TDR2, TDF, TDS, TDSF Kontronik, Scorpion ESC, iChargers, VBar, VControl Old hand at Planks Peter |
01-03-2016, 12:04 PM | #606 (permalink) |
Pictures of the Vstabi site showing that nstallation of VBar Neo. Can also see how tight everything is packed.
01-03-2016, 12:21 PM | #607 (permalink) |
Wow! Its definitely jammed in there.
_____________________ |
01-03-2016, 04:41 PM | #609 (permalink) | |
T-Rex 250CF MiniCopter Joker V1 Mikado Logo 600 3D VBAR Henseleit TDR RIGID Futaba 14SGH FASST / FASSTest |
01-04-2016, 03:43 AM | #611 (permalink) |
Just had Jan confirm that I am in the next batch for end of Feb
That does look a bit tight in there for the VBAR Neo installation. I will be using the VBAR Neo too, so I have ordered again the R2 Prototyping Mini power bus thing I used for my last TDR. Advantage is that the servo termination can be anywhere convenient with only a minimum single wire harness for each servo Vbar output required. Also get good voltage supply stabilization for the Vbar and isolation from my Optipower backup from the ESC. See my post on it a few years ago if interested: https://www.helifreak.com/showpost.p...2&postcount=14
LOGO 500SE & 600SE & 600SX Synergy E7 - N7 - N5C zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzTDR + II Alun |
01-04-2016, 05:42 AM | #612 (permalink) |
I am not sure if this kind of installation will fit into TDR2. There is not much space and i needed to replace my IISI telemetry with Fasstest telemetry and Robbe telemetry box.
In TDR2 is possible to do very nice cable routing. |
01-04-2016, 02:12 PM | #614 (permalink) |
Amazingly-clean installs for all set-up's shown, really gives a great perspective of how to do it right !
01-05-2016, 12:26 AM | #615 (permalink) |
Almost scary how tight everything fits in, but yet unique and well (it works) obviously. I may need to get on the #2 bus we shall see.
...Once upon a time there were Nitros, flybars & frequency pins...Shawn |
01-05-2016, 01:33 AM | #616 (permalink) |
Tight, but straight forward and possibly very clean. This is my first build of my own helicopter when i done final installation on first try. On other models including TDR it was on 3rd time and matured over time.
01-05-2016, 07:05 AM | #617 (permalink) |
Lucky devil, mine only in February so I drool over the European ones! Thanks for sharing on Vstabi.
01-05-2016, 10:13 AM | #618 (permalink) | |
I'd consider getting a small torque wrench if I had torque settings to go by. Seriously!
01-05-2016, 10:46 AM | #619 (permalink) |
Recommended torqs for critical screws are written in manual. Used range is from 1.5nm up to 6nm.
