Like Tree1Likes
Old 11-23-2015, 08:49 AM   #21 (permalink)
I too had to go with a smaller servo horn. This after I ordered bright shiny metal ones. LOL.
My set up is almost identical to rcflyerheli's.
Ted
Ted Schubert
I always have fun. Some times are more fun than others.
I can't remember half the crap I forgot.
strat1960s is offline        Reply With Quote Quick reply to this message
Old 03-28-2018, 04:05 PM   #22 (permalink)
Strat, I tried those Futaba horns, but just was not happy with the numbers. As I recall, those distances are about 12mm from center, and I just could not get good numbers on my collective and cyclic. The JR setup worked for me, but as it might not be available, those Futabas are the best you can do.
Specter 700, Logo 700, Logo 690SX, Goblin 700, Trex 700DFC, Gaui X7, Trex600EFL Pro, Trex 600 ESP, Trex 500 ESP, DJI 550
Amain Hobbies Team Rep
rcflyerheli is offline        Reply With Quote Quick reply to this message
Old 04-03-2018, 12:22 PM   #23 (permalink)
Has the Trex 600 nitro DFC been discontinued?
I have an older Trex 600 nitro (flybar) that I am thinking about converting to a DFC. I guess there is no kit for the upgrade?
000jb is offline        Reply With Quote Quick reply to this message
Old 06-16-2018, 09:32 AM   #24 (permalink)
Originally Posted by getsuyoubi View Post
I'm pretty much a scale flier, so slower flips and rolls won't matter to me. So, if I get a non-DFC FBL head I need either a shorter (191.8mm) main shaft, or longer main linkages to use it with the existing 201mm shaft - correct? This is great info, especially since some time down the road I'm planning to install this heli in a scale fuselage. This way I can adjust the main rotor height by a centimeter, depending on what exact heli model I decide on!
Do you happen to have a link for those longer main linkages?
I know it has been awhile since then. But can you tell how did you finally convert your TRex 600 CF? Did you get the non-DFC rotor head and from where? Which main shaft and linkages length you used? Did you keep the original swash plate / did you need to modify the swash?
Thanks for any hints. I am about to convert my 600 CF, also for a scale heli.
Align T-Rex 720X (2x) + CGY760R
Quest Neo Caliber 600 + CGY750
Futaba T18SZ 70th Anniversary
Rex Batavia is offline        Reply With Quote Quick reply to this message
Old 06-16-2018, 10:26 AM   #25 (permalink)
I got a non-DFC head from someone here on HF through the classifieds. I have to admit that it never flew that great until I got rid of the bell cranks. With the bell cranks, I needed an 11mm servo horn to make the BeastX happy (blue light at 6 degrees), and there was quite some slop in the system. Once I went direct to swash, using (I believe) 19mm servo horns, it flew fantastic. I used the stock main shaft (201mm, with third bearing block). The linkage rods I got from a friend who just happened to have the right size laying around.
The machine got since converted to a 3-blade head for a scale project.
Rex Batavia likes this.
getsuyoubi is offline        Reply With Quote Quick reply to this message
Old 06-17-2018, 01:01 AM   #26 (permalink)
Hi,
Thanks for the reply.
How did you get rid of he bell cranks, and go direct to swash? any pictures?
Did you use the same swash plate (when still 2 blades)?
Old 06-17-2018, 05:24 AM   #27 (permalink)
If you look at your helicopter long enough, you will notice that a ~20mm servo arm ends up pretty much right underneath the linkage ball on the swash. That is true for all three servos. I don't remember whether I needed different length rods from the servos to the swash - probably not.
There may be some pictures in my build threat in the "<790mm" scale section here on HF. Those show the situation with the 3-blade head, but with the 2-blade head and without fuselage things were even easier.
