100 Class Electric Helicopters 100 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
01-23-2017, 06:28 AM | #1 (permalink) |
v977 with a Taranis
Hello,
Hopefully I`m asking this in the right place. I`m trying to get my v977 to work with my Taranis. The heli is amazing but the transmitter it comes with is a piece of . I use a module in the back of my Taranis and I can bind the model and fly it around. However. It only flies in 6g mode and I have no idea how to get it to fly normal/3d modes. I`ve tried setting up a 3d curve but that just makes the head spin at a set speed with no swash movement. I could not find anything while browsing the internet about it. Either there isn`t any info or I`m just asking something obvious which I fail to see.(rather new with Taranis aswell) Hopefully this can be done since the heli is just great. Better then any micro blade models I`ve flown. Thanks in advance. |
01-23-2017, 10:54 AM | #2 (permalink) |
3D/6G mode is controlled using channel 5
With the K110 (which is very similar to the V977 but uses a different RX/FBL), the 3D/6G switching is controlled by channel 5. Set up a mix on channel 5 with a switch as the source to output +50 on one side and -50 on the other.
(You also need to setup collective pitch on channel 6, but it sounds like you already have that covered.) |
03-01-2017, 12:06 PM | #3 (permalink) |
Bit of a late reply but haven`t had much hobby time lately.
Turns out I din`t setup a collective pitch channel. I`m flying 4 channels without realising it. The swash is kinda badly setup it seems so it was flying as a FP. I`ve tryed setting a Collective pitch channel on the taranis but there doesn`t seem to be one defined. And tips on how to achieve this? As for the mix. What should I set to +50 and -50? Might be newbie questions but my taranis skills are |
