mCP X Blade Micro CPx Helicopters Information and Help |
12-04-2011, 11:39 AM | #1 (permalink) |
Banned User
Best battery for stock MCPx
I am sure this has been asked, but new stuff is always coming out. I want the best performing batteries. The small difference in cost is not a factor.
Thanks! |
12-04-2011, 01:30 PM | #2 (permalink) |
The hyperion 250s have been working very good for mine,the nanotech 300s were impressive at first but the lifespan seems to be dropping faster than the hyps..
http://www.readyheli.com/HP25C02501S...X_p_38634.html
700 class nitro,2X 600class electric,2X 450class,250 class,130 class,a few mcpx class().Dx-7.All helis fbl...If I had a dollar for every dollar I've spent on heli's ...I would break even. .Who is John Galt? |
12-04-2011, 02:33 PM | #3 (permalink) |
Hyperion 250s all the way
Goblin 770 sport, Fast Devil 505 Oxy 3 Tereq edition 2017 Blade 360 cfx modified, Blade 360 cfx stock Blade 180 cfx ,Blade mcpx Trex 150 |
12-04-2011, 02:40 PM | #4 (permalink) |
yeah there the best I have used so far. even tho i not try my spyder since it doesn't fit
RAW 580 ,lots of Planes Powered by IX14 AMA 36 yrs. |
12-05-2011, 06:50 AM | #5 (permalink) |
Mine does. You just have to convince the battery that it wants to fit.
Team Newb pilot All my helis and quads were lost in a tragic boating accident. |
12-05-2011, 03:56 PM | #6 (permalink) | |
Seriously I'll give you a couple of bux for it as I have one that is failing. Edit: To the OP. I would have gotten Hyperions, but I ended up ordering from progressiverc and they had a good deal on a few things I needed. LINK |
12-05-2011, 10:07 PM | #7 (permalink) | |
12-11-2011, 09:29 PM | #8 (permalink) |
The spyders are my favorite. Less bogging than the hyperions or the nano techs. The spyders are a little tight but after you use them a few times they fit in much easier.
12-18-2011, 07:37 PM | #9 (permalink) |
Thunder Power Batteries for mCPX
What does everyone think of the Thunder Power batteries compared to say the Spyders or the Lectron Pros?
The two Thunder Powers I bought recently 'nock the socks off' the Hyperions I bought at about the same time. I don't fly 3D yet, but the Thunder Powers have noticeably more punch, just no comparison IMO ... The Hyps are noticeably better than the stock batteries ... Regards to all, Bryan |
12-18-2011, 07:56 PM | #10 (permalink) |
While I'm at it, I'll add the Lightning Power 300mAh to the list ... :-)
Bryan |
12-18-2011, 08:08 PM | #11 (permalink) |
Would think the Tp be best but not try them yet
12-18-2011, 08:43 PM | #12 (permalink) |
Well, the Thunder Powers have not really stood out in my limited experience on larger helis ... Not that I'm doing much more than hovering at this stage ... These TPs standout though!!
Bryan |
01-24-2012, 06:22 AM | #13 (permalink) |
do any of these batteries come with the right connector for the mcpx?
01-24-2012, 07:11 AM | #14 (permalink) |
Derfman,
all come with the right connector. Most look like your stock mcpX battery, with a plastic cap that fits over the end of the battery w/ a hole for the connector to pass through. Makes plugging/unplugging the battery pretty easy. Just purchased 2 Spyders and they don't have this cap - more like a typical battery. I find them easy to plug in, but surprisingly hard to unplug (not much on the end of the connector to grip). I'm sure I'll get the hang of it. Have to compare the Spyders to the others. Again, I am a relative newbie and don't fly 3D so there's only so far MY comparison goes. The Spyders and the Thunder Powers seem to have the most 'oomph' to me than stock, Hyperions or the Lightning Powers (haven't tried the Turnigys or Lectron Pros). Have to check how much I'm pulling from them, etc. The Spyders are sized a bit differently - they will fit through the stock frame, but do not stop at the end (no cap) so you have to (I presume) position them for CG. I tried them with the end of the battery reaching to just under the main shaft at the advice of another flyer who had flown them - CG seemed fine ... Let us know where you end up. Regards, Bryan |
01-24-2012, 08:20 AM | #15 (permalink) |
I'll toss these in: Lectron Pro 3.7 volt 300mAh 35C. Great fit, slightly longer but doesn't mess with cog and comes down cool. Less than $14/pair shipped. Happy so far.
B120SR BSR HK450 FBL 450/Align 3G mCP X Draganflyer Quad DX7 |
01-24-2012, 09:27 AM | #16 (permalink) | |
Thanks |
01-24-2012, 09:57 AM | #17 (permalink) |
Derfman - the Hyperion 250 mAh (I believe, don't have them at the moment to look - definitely not the larger Hyperions) I am running fit just fine. The Thunderpowers are tight ...
N4HHA - I've been wondering about the Lectron Pros, thanks for the info!! Nice to have 300mAh!! Have you flown any of the others for comparison? Regards, Bryan |
01-24-2012, 11:08 AM | #18 (permalink) |
Add me to the list of Hyperion 250 fans. The only small quibble I have with the Hyperions is that the black plastic cap isn't glued on very securely. The caps on all four of mine are really loose. Need to get some Shoe Goo and fix em.
01-24-2012, 12:51 PM | #19 (permalink) |
Only stock. In the middle of the flight time increase tests.
01-24-2012, 02:32 PM | #20 (permalink) |
I got a thunder power about a week after I got the 2 eflight batteries. The 2 eflight batteries are still doing well, the thunderpower died about a week ago. I charged them the same, but the thunderpower didn't last very long
Blade 450x Trex 500 ELF Scale AS350 Trex500 |
