Go Back   HeliFreak > R/C Helicopter Support > SAB Goblin 500/570
SAB Goblin 500/570 SAB Heli Division - Goblin 500/570 Helicopters
Old 02-13-2013, 03:08 PM   #1
andersn
Default goblin 500, 4025 fits
since it has larger bolt holes, I reamed the oem bracket, and grabbed spare 630/700 motor screws
Since bolts build more and cant be countersunk, I put the 3 shims needed, on top of the main gear owb stack, to shim it as far down as possible, so I could move the main pulley down a smidge
No need to cut canopy
honey bee king II
andersn is offline        Reply With Quote
Old 02-13-2013, 03:32 PM   #2
Jeff_Barrett
LOL ... that thing is going to be a rocket.
I think Bert said he tried this motor as well, and it was overkill, but worked. Looking forward to hearing your thoughts. I have one sitting on my work bench in need of a home. I am planning on using a Pyro 600-11 in my 500 ... should be here by the end of the week.
Jeff Barrett
Team Synergy / Bavarian Demon / MKS Servo
www.synergyrcexpress.com
Jeff_Barrett is offline        Reply With Quote
Old 02-13-2013, 04:07 PM   #3
andersn
Bert has awsome collective mgmt and I fly.. I dont
primary reason for using it was I got the motor dirt cheap from a logo, and well.. it fits
honey bee king II
Old 02-13-2013, 10:53 PM   #4
McCollister911
+1 I'm doing the same. I found a killer deal I couldnt pass on.
McCollister911 is offline        Reply With Quote
Old 02-14-2013, 06:55 AM   #5
J-Money
That motor looks huge
J-Money is offline        Reply With Quote
Old 02-14-2013, 09:16 AM   #6
smytilineos
Are two bolts enough you think?
smytilineos is offline        Reply With Quote
Old 02-14-2013, 11:09 AM   #7
Fasrc
Default Re
Mine bolted right on with the stock screws no need to widen the holes. All 4 fit fine. only issue I have is the shaft length, it needs to be cut down as the battery barely clears it. In a crash, you could potentially puncture the battery. Now I have to remove the tail belt, remove motor mount and figure out how to cut the shaft. Any one have any ideas? I was thinking a drimal but that might take a while since its hardened steel.
Fasrc is online now        Reply With Quote
Old 02-14-2013, 11:15 AM   #8
jhheli
Tape the motor up completely so you don't get any metal shavings into it and get a thin cutting wheel, should only take 5min.
Justin Harris It is better to measure 10 times and cut once, than to cut 10 times and measure once.
Sponsored by :
KONTRONIK, OPTIPOWER, SAB USA , PRC, CANOMOD
jhheli is offline        Reply With Quote
Old 02-14-2013, 11:21 AM   #9
smytilineos
For cutting motor shaft refer to this post:
http://www.helifreak.com/showthread....19#post3716319
Old 02-14-2013, 11:29 AM   #10
Fasrc
Default Thanks Guys...
Just saw a video on YouTube on how to do it.
BTW: My motor is the HKIII-4025-1100. That is probably why mine was a direct fit.
Old 02-14-2013, 11:36 AM   #11
ericcolon
I cut my shaft today. Extremely easy with a dremel and cutting wheel. I used a zip lock bag and blue painters tape. After cutting and making the flat on the shaft, take a blower and blow the ziplock so there are no metal particles stuck on the bag just in case.
-- Outrage Fusion 50 FBL, Outrage 560k motor/CC HV80 ESC, Torq 9180/9188 servos, Skookum 540
-- SAB Goblin 500, Scorpion 4020-1350kv, CC Talon, Skookum 540
Lynx Heli Innovations Team Pilot | Southwest PR RC Crew
ericcolon is offline        Reply With Quote
Old 02-14-2013, 02:22 PM   #12
andersn
for cutting, or grinding shaft I use silly ammounts of gladpack.
honey bee king II
