Old 07-10-2012, 01:19 AM   #41 (permalink)
I should thank you for sending me the 130x board so I can
have some fun poking with it.
About the servo plug. Since it is the same one as MCPX servo.
I have new plug for it. However, the trace to hold the servo plug on
the board has been pull off. The challange will be how to hold the
plug back on the board without the trace under it. The electronic
signal is repairable. The mechanically part is what I am worry about.
I suppose there is some glue can be use on it.
Originally Posted by realrc74 View Post
@ coredump,
Thank you very much for your time and effort!
MCPX HP05s/HP03T Xtreme Frame (Beater)
MCPX HP06v2/HP03T MH X Frame (Precious)
MCPX HP08/HP03T MH X Frame (Grounded)
MCPX stock DIY firmware (Experimental)
coredump is offline        Reply With Quote Quick reply to this message
Old 07-10-2012, 01:39 AM   #42 (permalink)
No worry! I'm sure that you will discover some thing else by having the board w/ you ....
I have a stock motor and Spin 8800KV motors are coming...
What ESC should I try?
realrc74 is offline        Reply With Quote Quick reply to this message
Old 07-10-2012, 03:07 AM   #43 (permalink)
Coredump, ok, I understand now. Its only the coating that needs removing. I thought it was board material that had to be removed. Very good! Time to order another xp12a!.... Topper, where you at brother, I saw you lurking with your popcorn bag.... lol
Coredump, do I need a converter of any kind? Or can I just solder up an xp12a and have at it?
ChrisG23 is offline        Reply With Quote Quick reply to this message
Old 07-10-2012, 03:17 AM   #44 (permalink)
I have a XP12a I can give it a try and report back.
Old 07-10-2012, 03:43 AM   #45 (permalink)
Nope, the factory XP12a does not read the throttle signal.
It give some beeping error when connected. If I move to other
throttle value, some time it can get it to make a different sound.
But the motor never turns.
I haven't try BLHeli, I suspect it needs some update in BLHeli
to read the throttle signal.
Old 07-10-2012, 03:48 AM   #46 (permalink)
hmm. Figures. Well it looks like we are at a standstill until new bl heli code is written..
@coredump, again, thank you very much for everything.
Old 07-10-2012, 11:59 AM   #47 (permalink)
I put the board under microscope, it turn out the gyro should be ITG 3205
instead of ITG 4205 as I first thought. The mark has been erase by HH,
I have to use some hint to read it. It the same gyro used in MCPX.
Old 07-10-2012, 01:14 PM   #48 (permalink)
this is not a problem, you can use an external rx only for throttle channel.
i do that with my mcpx and fly well,then blheli works with ppm signal.
sorry for my terrible english
flavio95 is offline        Reply With Quote Quick reply to this message
Old 07-10-2012, 02:05 PM   #49 (permalink)
Great work core!
I'm tempted to pick up a CC Phoenix 10 and throw a 3 cell at it with a governor and power the MCU with the BEC. The question is.. will the motor still live at a decent headspeed.
izergfx is offline        Reply With Quote Quick reply to this message
Old 07-10-2012, 02:56 PM   #50 (permalink)
Still lurking
new bee is offline        Reply With Quote Quick reply to this message
Old 07-10-2012, 04:14 PM   #51 (permalink)
Originally Posted by izergfx View Post
Great work core!
Stock motor? doubt it kv to high.. you will want a kv in the 4200 to 4600 range on 3s I'm guessing.
Old 07-10-2012, 04:26 PM   #52 (permalink)
I need to see how the stock ESC works with my BL in runners I have
I wish horizon would list some specs.
fusionsx00 is offline        Reply With Quote Quick reply to this message
Old 07-10-2012, 04:45 PM   #53 (permalink)
If they are 2 pole with a max amp around 6 it would probably be safe to try. But thats why we are looking for alternatives.
Old 07-10-2012, 05:27 PM   #54 (permalink)
What kV?
Old 07-10-2012, 06:29 PM   #55 (permalink)
What kV?
Stock is 6300 ish. I think governed 3s at about 85 to 90%.... maybe 4500 to 5000 would be my guess. Obviously pinion selection is paramount.
Old 07-10-2012, 09:09 PM   #56 (permalink)
Can you determine what the esc mcu is and it if will be possible to flash it?
itsmillertime0 is offline        Reply With Quote Quick reply to this message
Old 07-10-2012, 09:27 PM   #57 (permalink)
Hence the governor... but idk about running partial throttle so much.
iirc, liftbag doing this on his 3s MCPx using 2s kv motors.
Old 07-10-2012, 09:36 PM   #58 (permalink)
In his post, he says "The question is.. will the motor still live at a decent head speed." That statement to me leads me to believe that it would be governed at an rpm significantly above the stock 3k. If that is the case, I doubt there would be any longevity to the setup. Keep in mind, Liftbags setup was wickedly overpowered for the weight, disc loading, and disc diameter. That lends to some flexibility.
Old 07-10-2012, 09:51 PM   #59 (permalink)
I should clarify, when I said decent headspeed, I didn't mean significantly faster than stock.
What I meant was a little bump over stock if neccessary. I'm satisfied with the stock headspeed, it just can't hold it well enough when pushing hard.
Old 07-11-2012, 12:50 AM   #60 (permalink)
Update:
I flash xp12a with BLHeli 5.0 then I use the BLHeliSetup tools to select
Input Polarity to "Negative".
Then using the signal spot I found. The XP12A can detect the ppm
signal. When I apply the throttle, the motor actually spins. It is a
walkera 4#3b BL 1S motor. I just give it a little throttle hoping it does
not burn out.
So BLHeli with negative input signal will work on the 130x board.
