Old 12-04-2010, 02:20 PM   #1
ragge1
Default alitle confused about Swashplate servo frequency
this is on the v.1 manuel page 50 : http://www.beastx.com/manuals/MICROBEAST_PV_ENG.pdf
AlignDS 410
swashplate ----------------- blue - 200Hz
servo frequency
colour - Hz
on beastX home page on v.2 :http://www.beastx.com/service_servoliste.html
DS 410 red flashing--------65 Hz
so which frequence should I set my servo on with the beast V.2 , its the DS410M digital servo
Trex 500 : Atom FBL head ikon | Atom 6HV : vbar 5,3 pro | Goblin 700 : vbar 5,3 pro | HD Cell 500 : ikon
ragge1 is offline        Reply With Quote
Old 12-05-2010, 02:41 AM   #2
DannyvG
just put it on 65Hz. theoretically there isnt much of a difference in flying characteristics between the different rates.
And with a to high frequency you can overheat the servos and you draw more power from the battery.
DannyvG is offline        Reply With Quote
Old 12-05-2010, 03:10 AM   #3
seemore74
where on the site did you see this, i've downloaded the new manual & can't see any lists like in the old manual regaurding servo frequencies. I assumed we would just use the recommended frequencies in the old manual or is this just a new recomendation for the DS410?
Shape 9.0, Trex 700 DFC pro** MKS Cyclics & Rudder Servos all round. Kontronik Pyro 750 Drives, Kontronik ESCs
Futaba SBus Rx, Futaba 8FG** transmission
seemore74 is offline        Reply With Quote
Old 12-05-2010, 04:10 AM   #4
MrMel
V-BAR Guru
New stuff replaces old stuff, your comparing a old preliminary manual (200hz) with an updated version (65hz), safe to say I would use 65hz
MrMel is offline        Reply With Quote
Old 12-05-2010, 05:32 AM   #5
ragge1
thanks ,will set at 65
her , choose the language and the versoin: http://www.beastx.com/service_servoliste.html
Old 12-05-2010, 03:11 PM   #6
Helico-pteron
The answer is obvious, you don't reference a 2001 Mustang repair manual to repair a 2010 Mustang.
Goblin 700
Dominator 450L
Helico-pteron is offline        Reply With Quote
