Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > mSR
mSR Blade (eFlite) Micro SR Helicopters Information and Help
Old 02-17-2010, 10:32 PM   #21 (permalink)
I have had my dx6i for about a week now and using the set up in this post. It is alot more fun to fly now. But, I am still trying to learn the whole settings thing. Which I am sure will take me years, but is it normal to have to put alot of yaw input to get the nose to turn when I am banking? Is there a way to make that more sensitive?
awilson is offline        Reply With Quote Quick reply to this message
Old 02-18-2010, 12:02 PM   #22 (permalink)
Hi awilson:
At first, I found the Tx settings overwhelming and complicated (and I'm still learning), but I don't think it will take "years" for you to learn. To make yaw input more sensitive, decrease rudder expo to something like -30 or -40. Experiment with the settings to see what best suits your flying. Thanks.
-Linac
SRB SG Quark on XP9303 FM, Oct. 2010 I mSR on DX6i, Aug. 2009 I SRB Quark, Jun. 2009 I mCX, Jan. 2009
linac is offline        Reply With Quote Quick reply to this message
Old 02-19-2010, 03:14 PM   #23 (permalink)
Hey linac,
thanks for the DX6i setting.i have tried loads this week,and your are the best out there!!!
cheers mate
Align 700L TOP Spartan Vortex VX1n
Align 550DFC V3 Spartan Vortex VX1n (the dogs nuts!)
Blade 180CFX
Futaba 8FG
JAG1 is offline        Reply With Quote Quick reply to this message
Old 02-19-2010, 03:22 PM   #24 (permalink)
Hi JAG1:
Thanks for your comments. I would be interested in hearing from you if you decide to tweak these settings later on. Enjoy!
-Linac
Old 02-19-2010, 04:25 PM   #25 (permalink)
Do the settings also relate to the DX7se ?
spartanleper is offline        Reply With Quote Quick reply to this message
Old 02-19-2010, 04:52 PM   #26 (permalink)
Hi spartanleper:
Good question. I'm not familiar with the DX7se but I would think that there would be similar menus and input of settings. Perhaps others could comment. Good luck!
-Linac
Old 02-21-2010, 09:57 AM   #27 (permalink)
Originally Posted by linac View Post
Hi JAG1:
-Linac
hi,no mate,not going to change a thing!! there perfect,thank you.
Blade 180CFX
Futaba 8FG
Old 02-21-2010, 12:19 PM   #28 (permalink)
I could not open the PDF attachment.
I'm not familiar with setting mixes.
How do I mix out the rudd/elev mix on my 6i?
hydro_pyro is offline        Reply With Quote Quick reply to this message
Old 02-21-2010, 01:30 PM   #29 (permalink)
Hi hydro_pyro:
The PDF attachment indicates:
Mix 1: ACT RUDD D+30 & ELEV U+30; SW F. MODE TRIM INH
Mix 2: INH
Good luck.
-Linac
Old 02-21-2010, 01:48 PM   #30 (permalink)
I just loaded up those settings on my DX6i and I can't believe how much better the mSR flies now.
Thank you for the info.
Tony Rumore
Heli-Newbie
TonyRumore is offline        Reply With Quote Quick reply to this message
Old 02-21-2010, 01:52 PM   #31 (permalink)
You're welcome Tony! The settings are a place for you to start. Have fun.
- Linac
Old 03-17-2010, 09:40 AM   #32 (permalink)
Default Success!
I was having problems post-crash getting it under control, I fought everything i could until I took a pic and posted it and it was noticed that my links were bent. I got it in trade, and it flew fine...but my theory is the links could have been bent then and just adjusted to make the swash level (I wouldnt know, never flew it new).
After 3 days of fighting it, i printed off your pdf, put the links on at 28.5mm and ajusted the right one up two full turns. I cleared my radio of all the little settings i had put in over the months to keep it flying, and used yours. took about +23 right rudder subtrim and 1 click of forward elevator and it hovered hands off for at least 5 seconds. Amazing.
THANK YOU.
Gaui X5!
Gaui X3!
Outrage G5
Blade mCPX BL | MultiWii Quadrotor
branflake is offline        Reply With Quote Quick reply to this message
Old 03-17-2010, 10:34 AM   #33 (permalink)
That's great news BF12! Thanks.
-Linac
Old 03-21-2010, 07:51 PM   #34 (permalink)
I am still very new to R/C Chopters. I loaded all your settings into my DX6i and have been trying to work on my flying it with those settings. I have a couple questions. Does the F. Mode toggle change the throttle between 0 and 1 mode only? It looks like that also has something to do with the Mix 1. Also does the the Gyro Toggle not do anything?
As an aside has anyone had to bump up the throttle curve on the normal mode? I had problems getting enough lift at 50%?
Also thanks for the settings.
BeerPimp is offline        Reply With Quote Quick reply to this message
Old 03-21-2010, 09:26 PM   #35 (permalink)
Hi BeerPimp:
Gear Mode will use the normal throttle curve which maxes out at 50% throttle (0, 15, 50, 50, 50). This mode can be used for startup and/or safety.
F. Mode (or Flight Mode) when toggled will use the stunt throttle curve which provides more aggressive throttle (0, 30, 65, 85, 100).
According to my settings, the Gyro switch does not do anything in itself. However, the GYRO is activated in F. Mode. and is set at 100%. Also, in F. Mode, Mix 1 becomes active.
Hope this helps. Have fun!
-Linac
Old 03-22-2010, 02:02 AM   #36 (permalink)
I just started using my mSR with the DX6i and I wanted to ask how the travel adjust can be 125%? Does that require any sort of adjustment to the heli? Just wondering how the servo can have more than 100% travel.
Thanks!
Scream And Fly is offline        Reply With Quote Quick reply to this message
Old 03-22-2010, 05:12 AM   #37 (permalink)
The mSR's servos won't respond past 100% anyway. Setting it about 100% will effectively make the last 20% of cyclic throw unresponsive.
If you want 150% cyclic throw, that can be mechanically arranged...
Blade 200QX, Align T-Rex 450 Pro 3GX,
P-51, SU-26XP, Carbon Cub, Cessna 182,
F/A-18, Blackjack 29, Slash 4x4
Old 03-22-2010, 09:09 AM   #38 (permalink)
Thanks!
Hi Scream And Fly:
In this thread, see the bottom of post #7: https://www.helifreak.com/showpost.p...64&postcount=7
Thanks.
-Linac
Old 04-01-2010, 10:31 AM   #39 (permalink)
I bought my MSR and DX6i last Satruday. The LHS setup the DX6i for me and said that it is recommended to program it as an airplane rather than a heli. Any idea why he would say that? I'm going to try your settings instead. He set it up so that it's at 65% with the elevator dual rate switch in the down position and unlimited in the up position.
WGW
wgw103 is offline        Reply With Quote Quick reply to this message
Old 04-01-2010, 10:52 AM   #40 (permalink)
They tell you to use airplane/acro mode because it lets you switch high/low rate with the F.mode/Gear switch without requiring any other programming.
If you use Heli mode, you'll need to program the "gyro" switch to toggle channel 5 between 100% and 0%. Set it up in the "gyro" menu to toggle the value between 100% and zero, to enable regular full control rates. (this switch has NOTHING to do with the mSR's own gyro) The built-in low-rate is around 70%. You can also use the other D/R switches to set up custom rates, or the Combi D/R mode to change multiple channels' rates at once with one switch, as the LHS probably did with yours.
