Old 06-15-2012, 07:01 AM   #1
Jamesppp
Default Power Jive Programming Question
Let's say I have programmed my esc by doing a mode 1 reset, then programmed mode 4 and mode 9. Everything went as it is supposed to with all to es acknowledging the steps.
Later on I decide I need to program mode 10 in. Should it be ok to just add mode 10 without starting over with mode 1?!
I would like to know if this SHOULD work. I did this and the results were not good but I can't tell from the manual if this is something that should never be done
The manual does say the effects of the modes are cumulative or something lie that
Compass7HV,Sk720HeliJive120HV Pyro 700 52L allHV
Outrage 550: Scorpion 4020-1390,CC125A ESC,WR ESC
Logo 5003D Scorpion Sk720 4020-1100, Blade130X MCPX
TT E-620 SE x 2: Scorpion 4025-740 CCHV85 ,770/8900
Jamesppp is offline        Reply With Quote
Old 06-15-2012, 07:52 AM   #2
ZuvieleTeile
The manual states clearly that you can program mode 10 (KSA) in addition to any other mode.
You can try to go back and reset with mode 1 and go directly to mode 10 and see, if the result is different.
Kind Regards ZT - TDR, Logo-400SE
No problem can be solved from the same level of consciousness that created it.(AE)
ZuvieleTeile is offline        Reply With Quote
Old 06-15-2012, 08:29 AM   #3
Jamesppp
Yes , it does but do you have to program all modes wanted at the same time.
I did mode 1 reset, mode 4 then mode 9 . I tried it out on the heli spooling up twice . Then I added mode 10 and attempted to spool up but the soft start was gone and other problems including what appears to be a dead esc
I was wondering if I had started over with mode 1 reset then 4, then 9 then 10 if the outcome would have been different
Old 06-15-2012, 11:59 PM   #4
Stolla
no I seriously doubt that, sometimes the jive can get confused although I only had it once where my friends jive was dead, reset on cp brought it to life again. same with old power jazz, I'm a bit confused though since you say soft start was gone so it's still working?
Stolla is offline        Reply With Quote
Old 06-16-2012, 10:42 AM   #5
Jamesppp
Stolla, no, it isn't working.
I set it up like this, mode 1, mode 4, mode 9 and tried to fly it. It seemed good but after maybe 30 seconds it did a soft cutoff . I autoed in , looked at the esc for blinking lights, saw none and spooled it back up. This time I just hovered in one spot for 20-30 seconds and it had another slow or soft cutoff.
Next Instead of starting over with a mode 1 reset ,... And trying mode 10, I just added mode 10. I got the proper tones including the "phone ring" at the end.
I went back out and tried to spool back up in normal flight mode with 0-60-60-60-60 as before and the heli acted as if there was no soft start. It jerked nose left violently. At this time there were no codes blinking. I tried it one more time with the same results only this time at low stick, 0 throttle there was no solid light or any light on the ESC .
I have not been able to get any response from it simce
Old 06-16-2012, 03:00 PM   #6
Stolla
sometimes wires double back against esc it will not response, have you tried moving wires away from esc. If all else fails you should be able to do reset with cpanel. Not impossible its damaged but I suspect programming that went bad
Old 06-16-2012, 05:35 PM   #7
Jamesppp
I hope it can be reset.
I sent it to Mike at Nankin and he is going to have it checked out by guy that really knows kontronics stuff
It shouldnt be burned as it neve even warmed up
Im crossing my fingers
Old 06-16-2012, 11:30 PM   #8
Stolla
let us know how it turns out
Old 06-17-2012, 12:19 PM   #9
Jamesppp
I should know something, good or bad,in a day or two
Old 01-18-2013, 06:31 PM   #10
NLTRex
How did you get on with this? Self same thing happened to my Jive 100+LV yesterday.
SAB Goblin 630 with AR7200BX | Mikado Logo 500 with VBAR 5.3 | Align T-Rex 450 Pro V2 with BeastX v3 & DFC | Blade 130X | Blade mCPX v2
NLTRex is online now        Reply With Quote
