Old 07-28-2015, 07:39 PM   #1 (permalink)
Default Spektrum throttle question on a new bind??
i sold my dx6i and got a dx6 radio my question is when i rebind the new radio to the receiver should i worry about the motor being reversed? i was going to take off the prop just in case but my generally speaking from new binds is the spectrum throttle channel ever reversed or should i not really worry about that? I just don't want to bind the new radio to the plane and have the motor be on full throttle when i connect the battery?
I KNOW THIS IS A HELI FORUM BUT I KNOW YOU GUYS HERE KNOW YOUR STUFF!!!!!!
GENERAL SPEKTRUM QUESTION
emederos is offline        Reply With Quote Quick reply to this message
Old 07-28-2015, 07:56 PM   #2 (permalink)
I would just for safety sake, but if the throttle is reversed, the esc will see a full throttle signal and likely wont arm. I know some esc's like castles wont arm until they see a 0% throttle level.
Gaui X7 w/Vbar, Miniature Aircraft Tempest w/ YS 91, Gaui X5 w/ Vbar, JR Vigor w/ YS 61, Gaui X3 w/ Vbar, Blade 180 CFX, Spektrum DX9
19trax95 is offline        Reply With Quote Quick reply to this message
Old 07-28-2015, 07:58 PM   #3 (permalink)
Suspended User
Exactly. 100% throttle signal on power up forces them into program mode. If you're running an AR7200BX, you're "double protected", too. It won't start outputting a throttle signal until it sees 0% throttle on its power-up.
WedgeD is offline        Reply With Quote Quick reply to this message
Old 07-28-2015, 08:29 PM   #4 (permalink)
The direction of the channel I'm 99% certain in the current gen spekky radios is the same as the older ie DX6i, DX8.
99%. I'd almost guarantee it but for the fact I myself do not have a current gen spekky radio but you can see there is no difference on published Blade BNF settings for the throttle channel from your old gen radio to the current, implying this.
If you don't want to take the prop off, put a servo of known behaviour to your rx throttle port. That should give you more reassurance.
Now how you set up your other plank electronics otherwise, I'd have no idea. You may need to recalibrate your esc... that sort of stuff.
spykez is offline        Reply With Quote Quick reply to this message
Old 07-28-2015, 10:34 PM   #5 (permalink)
On my Hobbywing it explains to turn on the TX with throttle at full stick until it emits a beep marking the full throttle point, then lower to low stick and again it emits a beep recognizing the 0 throttle point and your set. How is this throttle range set on a castle esc? Looking through the manual it doesn't go into throttle range setup only states how to enter programming mode?????
Old 07-29-2015, 02:46 AM   #6 (permalink)
On castles you reduce your stick travels greatly before you power up the ESC. Then you go full stick and adjust the travel in that direction until you get a signal and add a point or two more. Then you do the same for low throttle. I'm not too fond of this method but it is what it is.
Trex 250 Pro DFC | Gaui X3 | Goblin 570 | Stingray 500 | DYI Multirotors
FrSky Taranis
RCHN #637
smiler.se is offline        Reply With Quote Quick reply to this message
Old 07-29-2015, 08:08 AM   #7 (permalink)
Trying to get instructions on how to EXACTLY do this.....
Old 07-29-2015, 08:16 AM   #8 (permalink)
http://www.castlecreations.com/suppo..._endpoints.pdf
FrSky Taranis
RCHN #637
Old 07-29-2015, 08:53 AM   #9 (permalink)
Man thay seems a bit confusing to me , is there a step by step simpler way to explain this
Old 07-29-2015, 09:27 AM   #10 (permalink)
Without the castle link or card (fixed end points) will the esc have to be manually calibrated every flight???
Old 07-29-2015, 09:29 AM   #11 (permalink)
No. Calibration is only one time. After that you just plug the battery in and let it arm and your set to fly.
It's really simple once you do it once. Takes no more than a minute or two.
Old 07-29-2015, 12:41 PM   #12 (permalink)
In the castle world you don calibrate the ESC to your radio but opposite.
The Castle have a fixed range of signal it need to operate and you calibrate your radio to fit the range needed and do it only once ore each time castle comes up with a new firmwareupdate.
Logo 600SX
Warp 360
Chase 360
Exo 500
Mr.Andersen is offline        Reply With Quote Quick reply to this message
Old 07-29-2015, 01:07 PM   #13 (permalink)
Ok and this is the throttle calibration xont where you set the end point on hi and low to 30, then move to high stick and adjust the ATV up until it recognized full and vise versa for low? And again tgis can be done without the castle link or the card?
Old 07-29-2015, 01:19 PM   #14 (permalink)
Yes on all points.
FrSky Taranis
RCHN #637
Old 07-29-2015, 01:23 PM   #15 (permalink)
Originally Posted by smiler.se View Post
Yes on all points.
All points?
Old 07-29-2015, 01:27 PM   #16 (permalink)
heres the video i used when i did mine the first time. You dont need to set the travel to zero like he did though. 50% for low and high is good enough.
He is using a jr radio, but it is similar, just will look differnt. Also, disregard the end about the flight controller
How To Program Your Throttle End Points on A JR X9303 With Castle Creations ESC (4 min 58 sec)
Old 07-29-2015, 01:31 PM   #17 (permalink)
All points?
Stupid choice of words on my part. I meant that you were fully correct in your previous post
FrSky Taranis
RCHN #637
Old 07-29-2015, 01:50 PM   #18 (permalink)
Ok i got my dx6 today ill give it a shot later and post feedback, thx
