Old 07-29-2012, 02:16 AM   #1
scoio
Default 600 3d flight times
I know that has been talking a lot in this forum abt flight time on a L600.
I am bit concerned abt the times I got now, after a good 8+ minutes being SE.
Running same lipos, 10S 5000mAh, with 14t, Pyro 450, Jive 80HV, 623mm blades.
Accordind Mr. Mel HS calculator I am running 1800 (60%) 1900 (70%) 2100 (85%)
My last flights entirely at 1800 I got 5.30m, cell at 3.72.
I was thinking to get this timing running above 2000rpm!
Is there anything that I missed or maybe just my collective management?
Chris
Logo 600 3D MiniV 5.3 Pro
SAB Goblin 500 MiniV 5.3 Pro
Rigid 480 6S Beast X
MCPX BLS
scoio is offline        Reply With Quote
Old 07-29-2012, 03:27 AM   #2
Blink 182
Check with optical tac to get true rpm.
Hard to say you are getting too little flight time since its really subjective.
On my 600 I use 10s 5000mah, Jive 120, Scorpion 4225-610kv, Edge 603, 12t pinion
2270rpm at 60% and yeild 4:35 flight time going moderate on collective and 4:00 when I use full collective often (14 degrees)
(´・ω・`) ギルティクラウン
(´・ω・`)
(´・ω・`)
(´・ω・`)
Blink 182 is online now        Reply With Quote
Old 07-29-2012, 08:33 PM   #3
scoio
I have a Skytach, but being alone to fly, is difficult for me to read the rpm.
Need to find a good way.Pretty scary tho to leave the stick with a 600 hovering in front of you!
Chris
MCPX BLS
Old 07-30-2012, 12:31 PM   #4
NovaCX12
I get 3 minutes on 10s 4000's @ 2200 if I'm lucky before I strip a gear.
Gaui X5 VBar + Gov
mCPX BL
NovaCX12 is offline        Reply With Quote
Old 07-30-2012, 03:55 PM   #5
Blink 182
You must have a super cool motor.
(´・ω・`) ギルティクラウン
(´・ω・`)
(´・ω・`)
(´・ω・`)
Old 07-30-2012, 07:39 PM   #6
scoio
MCPX BLS
Old 07-30-2012, 08:51 PM   #7
Sean212
Running a 12S setup at 2150 headspeed with an 11T pinion. My Voltz 4200's I get 6:30 minutes and use between 2900-3000mah. Thunder Power 3300's I get 5:00 and use about 2000mah give or take. Thunder Power 2650's I use for 4:00, but only practice hovering and orientations. Keep in mind I only do very FFF, loops, rolls, flips and some inverted hovering.
Logo 600 12S- HKIII 4035-500, Jive 80HV, BLS451's, BLS251, Edge 623's, Edge 105's, Mini VBar
Futaba 8FG
Sean212 is offline        Reply With Quote
Old 07-31-2012, 09:48 AM   #8
NovaCX12
Its only an HKIII 4035-560, not sure what your trying to imply.
Gaui X5 VBar + Gov
mCPX BL
