Old 02-24-2017, 07:41 PM   #1 (permalink)
Default Microbeast does not hold tail on climb
Hi I have been having trouble with the the microbeast holding the tail on climb outs. Pirouette right or left and it stops on a dime. Flying sideways tail holds. It is when collective is applied hard that the tail kicks right (nose left). Here are the settings
BL855H Servo
Gyro gain 75 (tried up to 95)
Head speed 1900, 2100 (same kick on both speeds)
I changed the parameters to the following and it still does it.
--Parameters Menu--
D Tail - HeadingLock gain - very high
F Tail - torque precompensation (RevoMIX)
Any ideas on how to solve this?
Torito is offline        Reply With Quote Quick reply to this message
Old 02-25-2017, 03:11 AM   #2 (permalink)
if tail precomp at max not helping, then:
1, you hs is to low tail ratio on 600 is just 3.85 It was designed to use 2300-2400rpm.
2, you collective pitch is too much.
3, use longer tail blades.
XL Power 520 - XL4020-motor, DS512HV + DS825 servos, Spirit Pro FBL
XL Power and Spirit FBL field rep.
Gtamas90 is offline        Reply With Quote Quick reply to this message
Old 02-25-2017, 04:27 AM   #3 (permalink)
+1
Allan
TREX 250 PRO,Talon15, GPRO, Zeal ----TREX 500 EFL PRO, GPRO, RAILS ----2x TREX 450PRO V2, 1xGPRO&1xBRAIN, Talon35, RAIL , Zeal ---- SAVOX powered TREX500 EFL in Roban scale UH1-N ---- TREX 600 EFL PRO, GPRO, RAILS ---- DX9 ----
TR450ZS is offline        Reply With Quote Quick reply to this message
Old 02-25-2017, 05:10 AM   #4 (permalink)
As the guys above alluded to, problem is not in the MB but in lack of tail authority caused by too little tail thrust when rotor at extreme limit or too much drag from the main rotor. The latter can also be decreased by lighter, or slightly shorter main blades as well as increasing tail thrust by longer or faster tail blades. Sometimes there can be too much tail rotor pitch and the blades stall, they shouldn't have more than ~25° AOA
John
Old 02-25-2017, 03:20 PM   #5 (permalink)
Thanks for the info. Is there a way to change the tail gear ratio?
Old 02-26-2017, 10:40 AM   #6 (permalink)
Assuming this is a TRex 600, look under "Scale Helicopters" on this forum, and also others. This modification is not uncommon because for scale helicopters a low headspeed is desirable, which sometimes requires the modification you are after.
I know for a fact that I found a thread about this, with a complete parts list, but I don't remember where.
Good luck!
getsuyoubi is offline        Reply With Quote Quick reply to this message
Old 02-26-2017, 03:28 PM   #7 (permalink)
It is a Trex 600. Thanks so much I'll take a look.
Old 02-28-2017, 05:10 PM   #8 (permalink)
This should be the origonal 550-600E w/4.7. This is what I use.
https://www.amainhobbies.com/align-a...0020aa/p271430
https://www.amainhobbies.com/align-m...g001xx/p258872
Align 450Pro 3GX, 500ESP/DFC 3GX, 500L, 550 DFC MicroBeast , Velocity 50 Vbar OS55 HZ-R, D380 DFC D420, G500 Sport Microbeast, All HW V4,
X5 stretch 220 Flame Emax Bullet Force V2 VTX
bad007 is offline        Reply With Quote Quick reply to this message
Old 02-28-2017, 11:08 PM   #9 (permalink)
Thanks, these parts will fit on the Trex600L Dominator?
Old 03-01-2017, 09:05 PM   #10 (permalink)
Let me check my old orders, got a set not long ago.
See 550E , Pro, ,L,, X
The 550E gears are the higher ratio'
http://shop.align.com.tw/partfinder.php
