Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 425
Hurricane 425 Discussion and support of the Gaui Hurricane 425
Old 08-27-2010, 10:59 AM   #1 (permalink)
Default Torque Tube conversion-kit on sale
I'm not sure if this is allowed...
Please let me know if I am violating any rule and I will feel awfull for the rest of days...
Anyway: At hobbyking they have the TT-conversion-kit + CNC-tail on sale for $51,-
http://www.hobbyking.com/hobbyking/s...dProduct=13285
(it will show $99,- but load it into your cart, and it will show the actual selling-price.
CopterX 450 _ T-rex 250 _ Walkera CB100
Gaui Hurricane 425 (under construction)
Spektrum DX6i
snowflakes is offline        Reply With Quote Quick reply to this message
Old 08-27-2010, 05:17 PM   #2 (permalink)
you have been VIOLATED! lol, jk. Thanks for the link, that's a stellar price.
Gaui 200 •Gaui 550 •Gaui X5
BeastX Castle Scorpion Hyperion Spektrum JR
The Front Porch, Nexgens Lounge
nexgen is offline        Reply With Quote Quick reply to this message
Old 09-15-2010, 11:10 PM   #3 (permalink)
I ordered the torque tube for my 425 and 2 more batteries. Waited anxiously for it to come from Hong Kong and it finally got here. Wasted no time taking out the belt tube and tail to install the new torque tube. The drive gears will never mesh with the way the frame is set up on the $79 basic kit. The centerline of the tube is lower than the bottom of the drive gear. The picture in the one page "installation guide" even shows a diffrent looking frame. There is only 3 screws holding the bearings on the shaft that is driven off main gear and the battery tray is at a steep angle. Does anyone know if I am just trippin or is this for a diffrent main frame?
atkinson is offline        Reply With Quote Quick reply to this message
Old 09-15-2010, 11:42 PM   #4 (permalink)
yeah...that ain't gonna work !
i was thinking about the TT upgrade myself..gonna have to look into this more now !!!!
thanks for the info on that.....do hate it's not gonna work.......yet
Brick is offline        Reply With Quote Quick reply to this message
Old 09-15-2010, 11:49 PM   #5 (permalink)
It would seem that it's for the carbon frame only. The XF frame that I just built has an extra set of holes in it to move the bearing block for the tail drive gear to accommodate the beveled gear.
spootman is offline        Reply With Quote Quick reply to this message
Old 09-16-2010, 12:28 AM   #6 (permalink)
Yep, I would have to agree with Spootman. Since none of the plastic framed kits come with an optional TT tail drive, they likely only work on the CF frames. Although, some of us have been known to 're-engineer' things on the plastic framed Hurris, I don't know of anybody that added a TT tail drive. MARCO ?????????
I don't need the latest and greatest. I just need more time to fly what I have.
Align 450 Sport V2, Gaui 200, Gaui 425 x 2, "HeadHunter 500, Gaui 550, all Flybar'd
Jerrymac is offline        Reply With Quote Quick reply to this message
Old 09-16-2010, 05:44 AM   #7 (permalink)
This is a real "bummer"
I have the TT upgrade waiting to be build into my plastic frame...
However now I understand this will not fit
I'm also very interested if anyone has modded his plastic frame to fit the TT..
Spektrum DX6i
Old 09-18-2010, 06:42 PM   #8 (permalink)
The only way I could think you could make it work (and this is reaching here).
is to shave out the plastic blocks to the frame sides, then use two of the metal top bearing blocks for the cf frame, then shave out the little lip in the boom block that keeps you from inserting the boom too far so you can slide that gear in close enough. you should be able to use the existing bottom bearing block holes, but would also need to measure/align/drill out some lower holes for the top bearing block so that crown gear can be lowered to where it should be.
Something like this:
This illustrates the different bearing block alignments for reference, notice the tt one is lower:
if going to all that trouble, you may as well just shave out all the bearing blocks and install the whole cnc bearing kit. may take some fiddling, but I know others have done it with success.
Old 09-18-2010, 09:07 PM   #9 (permalink)
Rather than go thru all that I figured it would be easy enough to just put the cnc tail assembly on the belt drive that came with it. Just had to pull the tt gears and bearings then put on the belt drive gear on the shaft. Actually it is a lot easier than modifying the frame. If you have already ordered the tt upgrade not knowing it wont fit in the plastic frame, like I did, you can get some upgrade out of it.
Old 09-19-2010, 02:53 PM   #10 (permalink)
@nexgen: Thanks for helping the plastic dudes
Seems like a lot of work to get the TT installed on a plastic frame.... But on the other end: Days are getting shorter, evenings are getting longer, so there is more time to tinker, and less to fly
Indeed best option looks to remove enough plastic to install the complete CNC tail-block.
Spektrum DX6i
Old 09-19-2010, 05:13 PM   #11 (permalink)
No material removal required. Just loosen the four frame screws to relieve belt tension and pull the plastic tail housing. Here is the hardest part- press the pin holding the tail gear off the original shaft. If you have already removed the tt gears from the cnc tail then just slide the housing onto the boom. Put the gear on the new shaft and slide the belt over the gear. Might need some small shims on the side of the gear towards the blades. No grinding or modding required.
Old 09-21-2010, 06:34 PM   #12 (permalink)
Took it out for a test with the cnc tail and it nonstop piros to the right. I tried resetting the gyro and recentering the servo.... no success. It just wasn't meant to be. Will put back on the plastic tail and re do the gyro and servo. Maybe others will have success with this deal. My flying is not good enough to "need" a diffrent frame or to mod the plastic frame to get this tt to work. Flips and rolls can be performed just fine without a metal tail. Hopefully I will find someone who can use this tail upgrade. I now know I sure can't.
Old 09-22-2010, 02:32 AM   #13 (permalink)
If you just want a metal tail there are numerous alternatives for the belt - I use this one
http://www.cnchelicopter.com/servlet...ANE-550/Detail
you would also need this ..
Old 09-22-2010, 05:46 AM   #14 (permalink)
@mikej : Thanks for link to this site! It has a lot of 425/550 parts
Spektrum DX6i
Old 03-17-2013, 10:05 AM   #15 (permalink)
Sorry to move up this old post
I have a torque tube upgrade kit but if I turn the front TT gear (boom entry), it does not turn smoothly so I would like to disassemble the torque tube boom.
How did you remove the front gear from the tail boom (specialy from tail shaft)?
Did you have first to remove the tail box and after that, push the metal piece in middle of front tail gear?
I try to pull the gear with a flat screw driver but I could not get the gear out
It would be better if the torque tube upgrade kit was not assemble from factory
milliotseb is offline        Reply With Quote Quick reply to this message
