Go Back   HeliFreak > For Sale Forums KNOW your buyer/seller ratings! No Price bashing. NO FIREARMS > Electric Motors, ESC's, BEC's, Chargers and Batteries
Electric Motors, ESC's, BEC's, Chargers and Batteries *No Commercial Ads - E-Helis Stuff Only
Old 12-08-2013, 07:12 PM   #1
velocityguy
Default Thunder Power 1430C Charger
Up for sale is my TP 1430C Charger
The charger has the latest software from Thunder Power
Asking $125.00 shipped within it USA
Below are the specification from Thunder Power
Product Description
The TP1430C is a powerful and advanced multi-chemistry charger, discharger and balancing system. With up to 1000 watts of total charging power the T1430C is equipped to charge, discharge and cycle a variety of 1-14S LiPo, LiIon and LiFe (A123) batteries, as well as 1-40 cell NiCd and NiMH along with 6-48V Pb (lead-acid) batteries. The built-in 2-14S LiPo/LiIon/LiFe (A123) cell balancer and included balance connector adapter board are readily compatible with Thunder Power balance connectors and the JST-XH balance connectors found on most other batteries. The TP1430C is capable of charging at rates up to 30 amps offering the ability to charge many of the latest-generation LiPo batteries at ultra-fast rates up to 6C and beyond. Other great features include built-in data monitoring and internal resistance measurement, plus the ability to use a standard USB cable to install future firmware updates available for free download using a standard mini USB cable. Best of all these incredible features are all available at a value that’s hard to beat while being backed by Thunder Power RC’s industry-leading warranty.
Special Features:
•Powerful 1000W charger, discharger and cycler system with built-in LiPo/LiIon/LiFe (A123) cell balancer
•Includes a balance connector adapter board readily compatible with 2-14S Thunder Power and JST-XH balance connectors
•This powerful and compact single port design charges, discharges and cycles 1-14S LiIon/LiPo/LiFe (A123), 1-40 cell NiCd/NiMH and 6-48V Pb (lead-acid) batteries
•Up to 1000 watts of total power with selectable charge rates from 0.2 amps up to 30 amps for ultra-fast charging
•12 user-programmable memories plus built-in data monitoring and viewing with internal resistance measurement and more
•Fully-adjustable charge capacity limit (NiMh/NiCd/Pb), per cell end voltage and low voltage cutoff settings to maximize safety, charge and discharge performance
•Wide 12.0-36.0V input voltage range with adjustable input power current limiting to maximize performance and protect power supplies
•Durable and compact aluminum case with dual computer-controlled cooling fans and an extremely easy-to-read blue backlit LCD screen
SPECIFICATIONS
Type: Multi-Chemistry Single Port DC Charger/Discharger/Cycler with Integrated Balancer
Input:
12.0-36.0V DC
(40 amps recommended)
# Cells: 1-14S LiPo/LiIon/LiFe (A123), 1-40 cell NiCd/NiMH and 6-48V Pb (lead-acid)
Charge Rate: Adjustable from 0.2 to 30A
Input Connector: 4mm bullet connector or alligator clips
Output Connector: 4mm bullet/banana
Thanks,
Pete G
velocityguy is offline        Reply With Quote
Old 12-18-2013, 12:56 PM   #2
velocityguy
Default New price
New price, $125
Thanks,
Pete G
Old 12-18-2013, 03:46 PM   #3
RV_7A
PM Sent
Jeff B.
800E Trekker - 700E DFC - 550v2 - 500 DFC - 450 DFC - Goblin 630
RV_7A is offline        Reply With Quote
