Old 08-24-2015, 01:53 PM   #1 (permalink)
Default OS 105...bad regulator?
Hey guys,
I noticed yesterday that while iding and tilting my helicopter backwards that a considerable amount of fuel poured out my Hatori pipe. I've also noticed that in between flying days the motor seems to flood with it just sitting with the fuel line clamped off and the tank empty. The last few times I've had to take the glow plug out and blow fuel out of the cylinder. I can also see some fuel in the line between the check valve and backplate. Could this be a bad regulator and/or check valve. Thanks!
Justin
raptorflyer88 is offline        Reply With Quote Quick reply to this message
Old 08-24-2015, 03:31 PM   #2 (permalink)
Certainly sounds like the regulator could be leaking.
It would be worth your while to remove it from the helicopter, remove the 5 screws from the back, and clean it out thoroughly with some alcohol.
Sometimes, oil seems to gum up the valve inside, and it will not fully seat back down on the inlet hole, allowing fuel to leak past.
dchekas is offline        Reply With Quote Quick reply to this message
Old 08-24-2015, 03:39 PM   #3 (permalink)
Awesome. Thanks for the info man! I'll check it out
