Old 07-12-2012, 06:50 AM   #1 (permalink)
Default Spektrum Satellite Wires -Why so Wimpy?
the only issues I have ever had with Vbar was due to checksum errors, one time it was static from a belt drive tail (corrected by grounding the boom to the motor mount) Two other times it was due to a bad spektrum satellite wire, they always seam to come apart at the connector. Im wondering why they dont make a nice beefy enclosed wire or why dont an after market company do something similar? Seams there is a market for it.
Trex 700L NEO / Mikado Logo 600SX Vbar 6.0/ Trex 470LM NEO, Oxy 2 CC Talon 25 NEO, 450 pro vbar 6.0pro/ Trex 700n DFC OS105HZR, Velocity50 Vbar 6.0pro -Oxy 5 NEO-/Trex 600efl PRO (Night Flyer) vbar/CC HV80 ......ALL VBAR CONTROL
Stevin is offline        Reply With Quote Quick reply to this message
Old 07-12-2012, 01:11 PM   #2 (permalink)
1- so you will pay 8.95 USD for a 6 inch piece of wire
You have a point about their toughness, the connector is straight from PC hardware, commonly used on cooling fans. Maybe someone out there makes a heavy-duty version.
torpedoarmed is offline        Reply With Quote Quick reply to this message
Old 07-12-2012, 02:18 PM   #3 (permalink)
In a word price.
The small jst and similar connectors are crap if you need to continually be making and breaking the connection. The same problem also exists for LiPo balance plugs. They really are designed for one go and leave it be. I have found the connection can go high resistance which for radio gear is not going to end well!
Also with these small connectors and also servo plugs there is only a finite number of insertions that should be made before changing them.
Andy from Sandy is offline        Reply With Quote Quick reply to this message
Old 07-12-2012, 07:10 PM   #4 (permalink)
Its a very good reason to go to the dark side
Dave
Goblin 500, Vbar, BLS153, BLS251, Kontronic Jive & Piro
MutliWiiCopter Scarab Stealth Armour,Scarab Stealth Reconn V3, Scarab TriiKopta, Scarab Octa, Scarab Vampire
Deet is offline        Reply With Quote Quick reply to this message
Old 07-13-2012, 10:38 AM   #5 (permalink)
which would be?
Old 07-13-2012, 11:05 AM   #6 (permalink)
Futaba 10CHG
Trex 600n FBL 9452 cycle 9254 throttle SK540 Bls251 tail Os 50 MP5 pipe.9303 2.4 / AMA 355827
Trex 600 DFC VBar hobbywig-scorpion
john huckelberry is offline        Reply With Quote Quick reply to this message
Old 07-14-2012, 01:21 AM   #7 (permalink)
Try some low temp hot glue on the connections. (dollar store -craft-scrapbooking gun - will say low temp)
Low temp glue will break the bond easily and can be ripped open to get the wires out.
I did this on my 700n and went from an average of 10-20 fades per flight to less than 10 (rx and 2 sats)
Or as deet says - go futaba sbus.
I bought an exxtreme and didn't want to take the risk with dsm2 , and went with a 8FG
MArtin
Logo XXtreme 800 8917 / 256HV VBC
rcmarty is online now        Reply With Quote Quick reply to this message
Old 07-14-2012, 04:06 AM   #8 (permalink)
I never said that.. I did not use the F word
But now they you have...
Dave
Old 07-14-2012, 04:14 AM   #9 (permalink)
not going to happen, I cant stand the menus in futaba. The spektrum system is awesome they just need to beef up this connection. I actually use hot glue on all my connections.
Old 07-14-2012, 01:39 PM   #10 (permalink)
The menu's are a bit different i will admit.
I was a jr guy since i started (except a pair of wideband am radios way back when) and i do like the programming ease of the jr set.
Futaba (8fg unit) did take me a little to get used to. This radio will do alot more (if required) and therefore it will require more programming to do so.
Being were in the vbar forum , i'm assuming our running vbar. The programming of the radio for a vbar'd heli is minimal. As i recall i reversed the throttle , dropped epas to 99 (no subtrim at all x 3 models ) setup dual throttle hold switches (this took me a bit the first time) , and tyed the timer to the idle up switches. After that the vbar does the rest.
Like anything , once you do it a few times it is easy the next.
Short list of pros and cons
+ no more sats and sat wires.
+ small recievers - i use the 6203 sbus units
+ 8fg has very smooth sticks
+ timer screen is huge in 8fg
- 8 fg lighter and smaller than 11x (for those big handed guys)
- 8 fg switch placements tight on the top switches (again big fingers)
- quiet timer beeper on 8fg
I was told by a reputable member that your chances can be reduced to 1 in 1000 by using JR wires and JR dsmx sats on a DSMX system. Jr quality control is far superior to spectrum.
Or just goto the new JR dmss system.
Hope this helps
Martin
Old 07-14-2012, 04:49 PM   #11 (permalink)
Run a beed of E6000 around the wires at the plug for support. Had the same problems before.
It has levels and had some flexability to it. That's the same stuff lots of used on the original 3G mod.
Align 450Pro 3GX, 500ESP/DFC 3GX, 500L, 550 DFC MicroBeast , Velocity 50 Vbar OS55 HZ-R, D380 DFC D420, G500 Sport Microbeast, All HW V4,
X5 stretch 220 Flame Emax Bullet Force V2 VTX
bad007 is offline        Reply With Quote Quick reply to this message
Old 07-14-2012, 05:26 PM   #12 (permalink)
wire braid on the wire a dab of goo at the ends followed by heat shrink and look nice and hold up well
4 x Rush 750/stretched V-bar KDE 700XF-495 HV servos Greys reactor CC 160-HV
Trex 600EFL V2 V-Bar ds610 ds650 CC bec/pro Scorpion 130a HV KDE 600XF-530
450L KDE 1750 cc50 4xDS215MG k-bar
X-8 FPV Wing, TBS Discovery FPV, TBS Caipirinha FPV
satgod is offline        Reply With Quote Quick reply to this message
Old 07-14-2012, 07:54 PM   #13 (permalink)
One more con - no inbuilt telemetry unless you go $3000 18MZ.
I like my DX8 with telemetry and the ability to position my two satellites anywhere I want.
Regards, Jayson
Logo 800Xx Silverline, Pyro 850-40L, Kosmik 200, 14S, 157 & 256 @ 8v
Logo 400SE Silverline, Pyro 600-09, Jive 80+HV, 8S, 9660A+ 8900G @ 6v
Jays200 is offline        Reply With Quote Quick reply to this message
