Old 06-21-2016, 03:39 AM   #1 (permalink)
Default Trek nut vibe log,,,,,,,,,,
=] here you go,,,,
Old 06-21-2016, 07:28 AM   #2 (permalink)
Thanks Georgi ! The heli is trek 800 head speed around 1800 , I did almost everything : tt bearings , balance the tail unit .... It is so smooth , the vibrations are very good if just hover or scale flying but as soon as loop or roll , split s ...at high speed the green light will come on for the remain of the flight , this is the gps 2 the heli used to have a gps 1 and it was a little better , it would go green when it inverted but will come back to blue , gps 2 should be better but so far it was not , I don t really know what is the problem , so pls look at my log I know you guys can help . Thanks again .
Trek nut is offline        Reply With Quote Quick reply to this message
Old 06-21-2016, 08:07 AM   #3 (permalink)
=] motor vibe, overall the vibes are great but we see a motor spike here and there. Mesh related perhaps?
Old 06-21-2016, 01:36 PM   #4 (permalink)
Hi Georgi ! Should I upgrade to KDE motor mount or a machined main gear since I can t change the mesh of a Align motor mount
Old 06-22-2016, 08:01 AM   #5 (permalink)
=] Hi, your next step should be switching to playback logging, this enables better mapping of the vibe. It's sporadic so we need to see where the source is coming from.
If you don't want to use the SK gov, please fit an RPM sensor, this will help to narrow it down even further,,,,,
Old 06-22-2016, 02:25 PM   #6 (permalink)
Thanks Georgi ! I will work on those tips , never use Sk gov before , will look in to that , and how does the rpm sensor work with Sk playback log ? ( I am a rookie ) but I want to learn how to tune to a low vibration heli since I have 2 more to work on after this . Thanks and you are great help
Old 06-22-2016, 03:43 PM   #7 (permalink)
Hi ! Just talked to my bud from RotorQuest , I know what to do now to get Sk gov working ....will post a playback log soon .Thanks again
Old 06-23-2016, 08:26 AM   #8 (permalink)
=] usual stuff for first time gov users, reduce the gov gain to low 30's,,,,,, leave all else at defaults for now,,,,,,,,
Old 07-28-2016, 12:00 PM   #9 (permalink)
Default GPS module Failed
Hi Georgi ! I still trying to get the CC Edge so I can put the heli on governor mode , but I did changed the stock main gear with the Align CNC gear and also put on the Align Metal Shapely reinforcement Plate & Brace assembly , so this morning I swing the Gps again ,everything look good and smooth ,tried hard deck and position hold , flew around with sport flying then toward the end of the flight I noticed the green light was on , landed and hooked on the laptop the I saw this =internal gps module reset, configuration error , gps out of memory, gps module failed and .....everything else error that was on flight 1, swing gps again everything good ...blue light , gps status ok..go for 2 flight .. got up to height tried hard deck,position hold =ok then green light come again ..hooked on laptop =everything same like the 1 flight ....is my gps 2 defected ? since my vib are better now ( still no good but it never went past 3 ) I also flew my Dominator 700 with the 720 BE and GPS 1 and it was 95 % perfect. Thanks again
Old 07-28-2016, 12:08 PM   #10 (permalink)
Default forgot the logs
here are my 2 flight logs
Old 07-28-2016, 12:17 PM   #11 (permalink)
=] hi, have you a log for this, and you have my email addy to send it,,,,,
edit, mind reader! it needs to be a playback log,,,,,,,
Old 07-28-2016, 12:31 PM   #12 (permalink)
Default opps
sorry ! I have to redo the flight this weekend , Thnx
Old 07-28-2016, 12:56 PM   #13 (permalink)
Default warning = not enough sat
Hi Georgi ! can you look at this one for me , it is on my 700 , it is ok for my standard , but it did showed some warning for not enough sat , is it normal FOR THE GPS 1 ?
Old 07-28-2016, 01:47 PM   #14 (permalink)
=] I will check it first thing,,,,,,,
Old 07-30-2016, 06:19 AM   #15 (permalink)
=] yes, it looks like an average gps1 run of the mill brief sat loss,,,,,,,
Old 07-30-2016, 05:46 PM   #16 (permalink)
Default vib log and playback log
Hi ! I got the logs for the flight. it acted the same way even with a new Gps 2 installed today , same messages including this one =EEPROM error , may be it something else Please help. Thanks cannot upload the log because it was more than 2 MB . just send playback log to Georgi through email ,including here is my vib log , it was ok (I think ) ,it was recorded 30 min before playback log ...
Old 07-31-2016, 06:51 AM   #17 (permalink)
=] ok, and lets keep level headed while we go through this!
There is a known bug where sometimes the error code will go to "0xFFFF" which means all of the errors wrongly fire all at once. Try "send setup" and it should clear it. So nothing there is nothing to worry about.
EEPROM It is a bad error if it is real. It means the chip that stores all of
the important data (such as calibration, etc) has failed. I have come across 3 of these now. If real the gyro wouldn't allow flight mode, and would remain in a red LED error state.
So again, dismiss it. You are able to fly and don't report any calibration issues. The vibes are amazing! you either got a good kit, or are a true anal balance type guy??!
I think what does need looking at is your power supply? Do you have 2 sources going to the unit? and if so into which ports? the servo's are hungry and you are working them fairly hard,,,,,, await your thoughts,,,,,,
Old 07-31-2016, 07:57 AM   #18 (permalink)
Default Found the problem:it is me
Thanks Georgi ! My heli vib was good , thanks to you who was the one point out : gear mesh perhaps, and now : power supply, I don't know how did I miss this one , I use CC beck pro taking power from 6 cell Lipo , 1 wire go into jeti receiver then go into 720 be though ppm (dummy) the other wire use for skookum green and blue light ( really dummy) . I used skookum power buss before and still have it but don't know how to do the wiring for : skookum-jeti- power buss , I am sure you can help me out with this one ....I can the light at the end the tunnel ...Thanks again heli Guru
Old 07-31-2016, 08:21 AM   #19 (permalink)
Default It got worse
Just took all wiring apart , 1 power wire just sit there doings nothing , have to go back on all my heli , must be old age lol
Old 07-31-2016, 08:58 AM   #20 (permalink)
=] I think on this size $$$$ machine, you really need to fit a dedicated 2S pack. For two reasons, it will supply you with 2 independent power sources, And,,,,,,,,,,,, if the CC esc lets go the on-board electronics will see the full pack fizz voltage,,,,,,,,,
