Go Back   HeliFreak > R/C Helicopters > Low Head Speed Helicopters
Low Head Speed Helicopters Low Head Speed Helicopter Setups and Flying info
Old 06-13-2016, 03:46 PM   #1 (permalink)
Default How to go about changing?
I have a T Rex 700 that runs on two 6s batteries. I am wondering how I would go about just running 1 6s battery and change the motor to a low speed config. Any advice?
thanks
hrefab is offline        Reply With Quote Quick reply to this message
Old 06-13-2016, 03:56 PM   #2 (permalink)
Make a jumper to complete one side, plug battery in other side go fly.
If you want both 6 s battery's on for super long flights make a 3 way.
But the heli is going to be heavy so I would go first route.
James Roberts
The ground doesn't care how pretty it is.
James Roberts is offline        Reply With Quote Quick reply to this message
Old 06-13-2016, 04:28 PM   #3 (permalink)
No need to change esc settings?
Old 06-13-2016, 06:53 PM   #4 (permalink)
You will almost certainly need to increase your esc throttle percentage, assuming you are running a governed head-speed, probably to 100% initially and take your chances that this gives a high enough head-speed. Your esc may well complain about this setting, depending on your model.
Obviously, drop one of the 6S packs to save weight!
This will prove hard work for the battery packs, and the higher 'C' rated packs will cope far better. You may well need to change your head and tail gains to accommodate this change. Bear in mind, if you are running a DFC head, that it may not like the lower head-speed, and start behaving less than smoothly, head-bobble, etc..
You may well need to drop your pinion size and increase your pitch range slightly.
Anyway, just go experiment!
Andy
sales@jetiaustralia.com
AndrewJHawes is offline        Reply With Quote Quick reply to this message
Old 08-09-2016, 11:10 AM   #5 (permalink)
a friend flying a goblin 700 and im flying a logo 690 , just made a jumper and use one 6s pack , fly in iu 2 , no changes to programing or settings ...i get about 1200 hs , not sure what the goblin is ...
Dennis Everett is offline        Reply With Quote Quick reply to this message
Old 08-09-2016, 01:00 PM   #6 (permalink)
So where I have my second 6S pack connected, I would run a jumper to complete that circuit and eliminate the second Battery If I understand you yes?
Old 08-09-2016, 02:14 PM   #7 (permalink)
Yes that is what I do on my e5 when I want to run a single 6s instead of my 12s setup. Jumper one plug
Sent from my SGH-M919V using Tapatalk
B400(retired),Mini Titan V1(Retired),Radikal G20 (scrapped),Align T-Rex 500pro DFC,Synergy E5s
Digger1973 is offline        Reply With Quote Quick reply to this message
Old 08-09-2016, 02:47 PM   #8 (permalink)
If you leave everything as is.
Just plug in one 6S pack.
Your ESC, if you have a GOV set on it will run at 100% to try to reach the GOV setting.
JR9303 / JR9503 / Futaba10CHP
Old 08-09-2016, 05:59 PM   #9 (permalink)
No I don't have a governor set up in the ESC so I can just plug and play.. I'ms surprised that I don't have to change the cell setting in the esc... Worth a try..I"d really like to fly my big bird, but wiht the old hammered packs I have for it, I'd rather just lug around at low headspeed...
then you know what happens right? Ohhhh I gotta have MORE SPEED.... So typical
