Go Back   HeliFreak > R/C Helicopter Support > Henseleit
Henseleit Henseleit Helicopters
Old 02-23-2012, 04:59 AM   #1 (permalink)
Default Jan's frame stiffeners
I contacted Jan with questions about frame stiffeners and here there are:
http://www.henseleit-helicopters.de/...oducts_id=1313
Part number RI-0203. These was added to Jan's shop today, i dont know how these looks, but i ordered one set. When Jan's stiffeners arrive i will post photos.
swalko is offline        Reply With Quote Quick reply to this message
Old 02-23-2012, 05:34 AM   #2 (permalink)
Jan said he was going to start adding a few things to support more powerful powerplants.
I expect we will see a new high temperature main gear at some point too.
I wonder if he will evern go so far as to start offering "bling"
Mark
Dusty Shelf queens: TDR2, TDR, Protos Max, Logo 550SX, Protos 500, Jeti DS-16, etc....
mkovalcson is online now        Reply With Quote Quick reply to this message
Old 02-23-2012, 05:41 AM   #3 (permalink)
If they are the carbon side ones i dont think they work too well
helicraze is offline        Reply With Quote Quick reply to this message
Old 02-23-2012, 06:49 AM   #4 (permalink)
Yea, not the easiest thing in the world to install or adjust the mesh afterwards.
I replaced the double washers with those metal shims most tail blades come with, bit easier to install as they're one-piece.
They do seem to work though, not a single mark on any of the 45xx since I tried them on.
With great power comes great voltage times great current !
zmooth is offline        Reply With Quote Quick reply to this message
Old 02-23-2012, 07:07 AM   #5 (permalink)
I replaced the double washers with those metal shims most tail blades come with, bit easier to install as its one-piece.
At first you may install motor and adjust mesh without stiffeners. After that you unscrew screws on one side and install one stiffener. Repeat same process for second stiffener.
Great.
Old 02-23-2012, 08:01 AM   #6 (permalink)
I received Jan's stiffeners in my kit but decided to go with Mick's frame brace instead. Well I was going to use both but the holes for the brace would have been blocked by the washers for the Henseleit stiffeners . Mick's brace works great, no marks on my 4530.
Logo 600se
Redlight11 is offline        Reply With Quote Quick reply to this message
Old 02-23-2012, 08:01 AM   #7 (permalink)
Hmm, no picture. I think I need these though, thanks for the info.
TDR/VBar
Logo 600SX 12s VBar
MSH MINI PROTOS/CGY750
AcidDrink is offline        Reply With Quote Quick reply to this message
Old 02-23-2012, 08:04 AM   #8 (permalink)
Originally Posted by Redlight11 View Post
I received Jan's stiffeners in my kit but decided to go with Mick's frame brace instead. Well I was going to use both but the holes for the brace would have been blocked by the Henseleit stiffeners washer. Mick's brace works great, no marks on my 4530.
C'mon Rdlight, we need pics. . .
Kind Regards ZT - TDR,
No problem can be solved from the same level of consciousness that created it.(AE)
ZuvieleTeile is offline        Reply With Quote Quick reply to this message
Old 02-23-2012, 08:10 AM   #9 (permalink)
Pictures are from other thread / s.
ID:	292570   Click image for larger version
ID:	292571   Click image for larger version
Old 02-23-2012, 08:23 AM   #10 (permalink)
Hhmm,
I think, from a constructional standpoint, the crossbrace from Mick or something like it in general is a better solution imho.
Old 02-23-2012, 08:46 AM   #11 (permalink)
Heli-innovations.de sells a CF X-brace "kit". Never ordered from them, so I dont know their shipping policy...
http://www.heli-innovations.de/
minicopter Diabolo, Henseleit TDR, X50e, X50n, Raptor 50
Futaba 2.4 GHz
DT75 is offline        Reply With Quote Quick reply to this message
Old 02-23-2012, 08:49 AM   #12 (permalink)
Sorry but Im at work. I will snap some pics this afternoon.
Logo 600se
Old 02-23-2012, 09:03 AM   #13 (permalink)
[QUOTE=Dumbthumb75;3683825]Heli-innovations.de sells a CF X-brace "kit". Never ordered from them, so I dont know their shipping policy... [QUOTE]
I looked at those. Not bad, but lots of work. Gluing the stuff together, gluing in the nuts.
Too imprecise for my taste.
If we could "wake up" Mick, that would be great. . .
Old 02-23-2012, 10:17 AM   #14 (permalink)
I have some extra 700E? standoffs that were about a mm or so too long for the upper frames that I just dremeled down and used. Doesnt look as fancy but gets the job done without taking up much room.
Chris_M is offline        Reply With Quote Quick reply to this message
Old 02-23-2012, 10:36 AM   #15 (permalink)
It seems to me that the stiffeners made by Jan are not bad actually.
They are alike to the ones on the xxtreme.
The idea being in that when you have 2 carbon sheets which are pressed together and held eith bolts but with a spacer In between , the whole construction is not liable to bending .
So it stiffens the side while adding little weight.
The ones in alu cnc are for keeping the frame from slanting, they look nice yes, but add weight.
For a pure race Heli like Rigid TDR 90 the carbon ones (the ones from JAN) I like very much.
No Pitch...No Fun!!!
Egroeg is offline        Reply With Quote Quick reply to this message
Old 02-23-2012, 11:11 AM   #16 (permalink)
I don't know the weight difference but it can't be much. Im not gonna take out the brace to weigh it but the carbon stiffeners are quite large and have a quite a few thick washers. I would not be surprised if Jan's weighed a bit more than the brace. This is just a guess though.
EDIT: I am not throwing off on Jan's stiffeners. They look great and Im sure they function as intended . After all it is a genuine Henseleit part, so you know it is top notch quality.
EDIT 2: Jans stiffeners do in fact weigh more than Micks brace. But we are talking grams here so no big deal.
Logo 600se
Old 02-23-2012, 12:03 PM   #17 (permalink)
Not much added weight by the Micktech brace, I think...
Name:	Frame brace.jpg
Futaba 2.4 GHz
Old 02-23-2012, 12:26 PM   #18 (permalink)
Thanks for posting that!I will put Jan's stiffners on the scale when I get home for comparison.
Logo 600se
Old 02-23-2012, 12:53 PM   #19 (permalink)
I have been using Jan´s stiffeners successfully since August last year on my second TDR with Scorpion 4525LE
I must admit that I have increased the distance between the main upper carbon frame and Jan´s stiffeners up to 5 mm using aluminium bushings. In this way the stiffness of the ¨sandwhich construction¨ is increased significantly
Grtz
Belgoheli
belgoheli is offline        Reply With Quote Quick reply to this message
Old 02-23-2012, 01:08 PM   #20 (permalink)
Grtz
Belgoheli
That's a great idea. The closer the two are together, the more they act like a single sheet. A little more distance between them adds rigidity through the geometry without requiring much additional weight. I'm curious what the rigidity multiplier would be for that modification.
Mark
