Go Back   HeliFreak > Multi Rotor Support > General Multirotor Support
General Multirotor Support General Multirotor Support
Old 05-26-2013, 01:29 PM   #121
mrob73
Default Naza M v2 3.10 new firmware avaliable for V1
No you do not have to rebind, but it doesn't hurt to do so. Just as a precaution and to recheck your settings.
GAUI USA Field Rep.
mrob73 is offline        Reply With Quote
Old 05-26-2013, 02:16 PM   #122
1275mini
Originally Posted by iceman320 View Post
do you have to re bind your tx and rx after you do a firmware update?
No mate you are not touching the radio side of things
Barry
1275mini is offline        Reply With Quote
Old 05-26-2013, 02:45 PM   #123
iceman320
okay thanks guys I didn't think that i would have to but, Just wanted to make sure.
iceman320 is offline        Reply With Quote
Old 05-26-2013, 11:17 PM   #124
iceman320
Think that I might switch my naza back to the old version firmware. I liked it better and I think my f450 flew better also.
Old 05-27-2013, 07:03 AM   #125
Olivier06
I could not get the new version to calibrate correctly.
I kept getting the message error[27] "GPS not calibrated, or magnetic field interferance. Please calibrate GPS again in good condition."
I removed the compass, rotated a magnet around it, tried to recalibrate in an open park... and I keep getting the same message. The yellow and red lights blink and I get no gps lock. So, I swithced back to the old firmware which seems to be working fine!
Anyone got a clue as to what to do?
Olivier06 is offline        Reply With Quote
Old 05-27-2013, 11:25 AM   #126
daneger21
Originally Posted by mrob73 View Post
I still can't figure out how I made it RTH when I turned off the TX when I initially set it up. After the firmware upgrade it doesn't do it anymore.
Find your bind plug and redo your rx failsafe. And im assuming you use spektrum...
1. Set tx switchs/buttons/settings or whatever in the failsafe position then power off tx.
2. Insert bind plug into rx
3. Power on rx
4. Remove bind plug from rx after 2-3secs
5. Power on tx while holding bind switch
6. Release bind switch after 2-3secs
7. tx and rx should bind together while also setting rx failsafe
8. Power off rx.
9. Replace switchs/buttons/settings on tx back to "normal" then power off tx.
10. Plug naza into computer
11. Power on tx
12. Power on rx/naza
13. Open naza assistant
14. Verify that failsafe works in two ways...
- Forcing the failsafe via a switch/button
- Naza/RX enabling failsafe via signal loss(turning off tx)
No I didn't misspell Daneger, my name is Dane..get it?
"Flyin' high again..." -Ozzy Osbourne
daneger21 is offline        Reply With Quote
Old 05-27-2013, 06:08 PM   #127
mrob73
Are there any hardware differences between v1 and v2? If I purchase the new PMU will it be the same?
GAUI USA Field Rep.
