Go Back   HeliFreak > R/C Electronics Support > R/C Related Electronics DIY
R/C Related Electronics DIY DIY R/C Electronics for tinkerers and the budget minded
Old 03-20-2012, 03:16 PM   #41 (permalink)
Originally Posted by CaliRCflyer View Post
Thanks for the info, a picture is worth a thousand words
I am looking for a 2K pot. What power or watts should I get? I have found 1/4watt up to 2watts. All of the ones I found are 3 wire hook up. I am not by any means a Sparky Pro could you help out with the wiring on the potentiometers.
To set up current sharing do you wire the green pins from each ps together?
Thanks again
I would think the 1/4 watt pot would be fine, it is not really doing much but you could always play it safe and get a larger one...
On the 3 pin pots, basically the middle terminal is usually the wiper. So the resistance between it and either outside terminal will be proportional to the turning of the shaft.
Maybe someone else can chime in on the current sharing, because I do not know about that...
DJI F550 E300 w/ Naza-M v2 - Build in Progress
Tarot 450 Pro V2 FBL - Still Learning
Blade mCP X (BL w/HP-05 S) - My "Sim"
Syma S107G - Yellow Toy
TaterTot is offline        Reply With Quote Quick reply to this message
Old 03-25-2012, 03:08 PM   #42 (permalink)
Anyone know if a Powerlabs 8 will fit inside the Kobalt toolbox?
Thursday is offline        Reply With Quote Quick reply to this message
Old 03-26-2012, 08:30 PM   #43 (permalink)
Sure does,
ID:	302367   Click image for larger version
Its all about having fun
ShaneJourdan is offline        Reply With Quote Quick reply to this message
Old 03-27-2012, 12:09 AM   #44 (permalink)
Originally Posted by DoctorJ View Post
Sure does,
But does the lid close?
I'm doing a mock up of my insert tray now and got to thinking the PL8 I ordered might not fit with out some sort of step down in the tray.
We're going to be twins!
Old 03-27-2012, 10:41 AM   #45 (permalink)
Yes, is closes nicely.
Nice job my freind!!
Old 03-30-2012, 07:00 PM   #46 (permalink)
Duel PL8 linked together charging 30amps each so Sweet!!
I like this much better, charges much faster and you can see each cell voltage, resistance etc.
Old 04-07-2012, 12:46 PM   #47 (permalink)
Hey DJ,
Just got done building this for a friend, should look a little familiar. Great mod idea for connecting the PSUs together by the way. The tool tray that comes with the box actually makes a great tray for the charger. The handle was pretty easy to remove.
Paul
Agile 5.5 - Q 4125-1100, YEP 120, Brain2 HD FBL / Outrage 550 - HK4020-1390, Edge 120, Brain2 HD
Rave Ballistic FSO - Q 4530-500, Edge 160HV, Brain2 HD / Protos Max V2 - MSH 4530-500, Edge 160HV, Brain2 HD
pctomlin is offline        Reply With Quote Quick reply to this message
Old 04-07-2012, 01:48 PM   #48 (permalink)
Very nice PCtomlin. I thought about using the tool tray as well, but I decided to just go with plexi-glass and keep the tray for some heli tools.
Old 04-09-2012, 06:21 PM   #49 (permalink)
I think I'm finally finished with mine. Painted the 6650 exhaust fan grill and removed the stickers on the fans. It's hard to capture the true look of the LED voltage meters.
I'll post a how to video in time. Thanks PCtomlin, and DoctorJ for pioneering this setup.
Old 04-09-2012, 06:25 PM   #50 (permalink)
That was my box right above that looks like yours.. but where did you get those LEDs.. thats awesome.. I may want to rewire mine to allow 2 PL6s like above. thats really sweet
CeeveeSiN is offline        Reply With Quote Quick reply to this message
Old 04-09-2012, 07:11 PM   #51 (permalink)
You dog... nice freeken job, where did you get the led volt meters?
Old 04-09-2012, 07:16 PM   #52 (permalink)
Originally Posted by pctomlin View Post
Hey DJ,
Paul, why didn't I think of that... awesome, its so cool how thing evolve with all this brain matter around here!!
Old 04-09-2012, 09:04 PM   #53 (permalink)
That is what is great about these forums. The collective brain power of many come up with some great ideas that build off of others. Pick and choose what works for you and make it your own.
Paul
Old 04-11-2012, 01:30 AM   #54 (permalink)
Thanks. I got the voltage meters on eBay, they're from China and took over a month to ship.
Old 04-29-2012, 04:01 PM   #55 (permalink)
Default Charge Box
Its always a work in progress, been working on making mine better since summer of last year. The power source is two Hewlett and Packard 575Watt 47Amp PC PS. wired in series for 24.30 volts. they have been working for a full year, Ebay as well $30. Best Power source for the money.
Ive gone through all different kinds of boxes.. from suitcase, tool boxes and others, but I found this one to be the best one yet. Its a SaltWater TackleBox, made in the USA by PLANO.
I put the batteries in the side slots (holds up to three each side for parallel charging), when the batts are done I flip them around so I know they are charged and I'm not grabbing a DC'd pack.
Power source in the middle on a piece of plexiglass so it slides in and out for easy access, large cooling fan on the outside circulates air,
Great thing about this box is its soft plastic than can be cut with an exacto knife, no power tools needed, you can cut anything to your liking.
This summer should be GREAT...Glad Im not the only DIY guy out there, those others look better than any of the ones I first did..
ID:	312433   Click image for larger version
ID:	312434   Click image for larger version
ID:	312435   Click image for larger version
ID:	312436   Click image for larger version
ID:	312438   Click image for larger version
ID:	312439   Click image for larger version
Just Keep on Flying
Rotoritis is offline        Reply With Quote Quick reply to this message
Old 04-29-2012, 09:35 PM   #56 (permalink)
No such thing as others look better. It is all about your ideas and what works for you. Very cool take for a charging box using the Plano tackle box. Well thought out and love the battery storage compartments on the sides.
Paul
Old 11-17-2013, 03:30 PM   #57 (permalink)
Are you guys buying the psu's new or used? Everything I find on eBay is used or refurbished. Not sure if they would be okay or not....
ckflyer is offline        Reply With Quote Quick reply to this message
Old 11-17-2013, 07:56 PM   #58 (permalink)
All but one of the psus that I have used were refurbished off ebay. Occasionally you will come across a good deal on a new one.
Paul
Old 11-17-2013, 11:44 PM   #59 (permalink)
Default Dell 6650 Field Power Supply Box
The two I bought off eBay were used. They have been running strong for over two years now and they definitely get a work out. I usually pull about 40 to 60 amps. I fly a lot, so they run about 20 - 30 hrs a month.
Hope this helps with your decision. I have been very pleased with mine. You just can't beat this kind of power for the price and a little time.
JesseRigg is offline        Reply With Quote Quick reply to this message
Old 11-18-2013, 09:28 PM   #60 (permalink)
Thanks a ton for the replies guys, I appreciate it! Going this route is a lot easier on the slush fund. Plus there's just something about building something on your own that makes stuff like this more fun (IMO anyways).
