Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > 330X
330X Discussion and support of the Gaui Hurricane 330X QuadCopter
Old 08-06-2010, 07:23 AM   #201 (permalink)
Originally Posted by Tahoe Ed View Post
Here is mine with FPV camera and an FY-21A II stabilization unit. I tried flying with out the FY-21A and the oscillation was unflyable no matter what I did to the gain either on the GY 344 or on the transmitter. I will see if the FY-21A can take over. When I fly tomorrow.
Tahoe Ed,
Are you using an GPS equipment on your FPV? Or just camera and video Tx?
If you are I found you will need to seperate the Video Tx and the GPS about 14-16 inches apart from one another. Or the GPS signal will be masked by the video Tx.
Look forward to your video posting!
yakflyer is offline        Reply With Quote Quick reply to this message
Old 08-06-2010, 09:12 AM   #202 (permalink)
No GPS. There is not enough room on this platform. I may try it on one of my CP Helis.
AMA #844172 DJI S1000 Lightbridge Zen for 5D, S900 LB Zen for BMPCC, DJI Phantom 2 Vision +, P2Z2 with Data Link, P2Z3 with LB DJI Forum Support
Tahoe Ed is offline        Reply With Quote Quick reply to this message
Old 08-06-2010, 12:49 PM   #203 (permalink)
Originally Posted by yakflyer View Post
John,
I found this in my email today. I thought about you. Not to shabby of a price.
Don't know if they are what they claim to be but check it out. You might like it?
http://www.skytallhobby.com/index.ph...oduct_id=35115
Hey i have one of those flymentor for sale
tomrinkevich is offline        Reply With Quote Quick reply to this message
Old 08-08-2010, 03:16 PM   #204 (permalink)
Well I got the 330X-S and have been flying it all day. Its doing very well; I can hover very still and make fast, high-G turns and its flying like it's on rails.
I am having a problem though.
It likes to flip over if I bang the sticks around and get it at a high angle of attack.
Another issue that made it flip over; I was pretty high up and decided to see how fast I could descend. As I was falling with the props spinning at maybe 1/4 throttle, it turned over and fell in.
It seems like if Im pushing the quad as far as yanking and banking quickly, it runs the chance of flipping.
My gain is set at 26% on the gear channel on a futaba 10C. Mode is cruise.
Battery is a 3S 2200 pack.
All ESC's are calibrated one-by-one.
Any help would be appreciated.
Matt
webdr is offline        Reply With Quote Quick reply to this message
Old 08-09-2010, 02:22 PM   #205 (permalink)
The brain in my quad has died.
I contacted All e rc where I purchased it and explained my problem.
This is out of warranty but Bob told me to send it back and I will get a replacement.
What great service and totally unexpected.
Customer service in this day and age, amazing but true.
John
in sunny Clyde, Ca.
Time flies like an arrow, fruit flys like a banana
john339 is offline        Reply With Quote Quick reply to this message
Old 08-09-2010, 09:02 PM   #206 (permalink)
Mine arrived defective and after fighting with it for 10 days, I contacted RC Hover and Empire. They are replacing it under warranty. I hope you get yours up and flying soon.
Old 08-10-2010, 07:58 PM   #207 (permalink)
Hello friends. Need some advice please.
I have the orginal 330x (the first shipment)
2 weeks of some great flying #1 ESC went out.
I ordered, received and installed the Gau 10amp Escs.No instructions provided with the new ESCs.
All motors are turning the correct direction but it seems like they are not all running up to speed.
When I test hover, it will either flip over forward, backward, left or right. Very random on the direction it flips over.
I would set the trim a little to counter the last flip and same thing again, but a different direction???
I was very careful to make sure each ESC was swapped out perfectly with the old ESC. I have verified each motor is turning correctly.
I have calibrated and calibrated over and over, reduced my end point on my throtle to 80% after I unplug the battery. Then plug in the battery with the Tx set at 80% End Point and the same results??? I hate this! It was flying so good before this.
What is this calibrating each ESC seperately?
Thanks in advance!
Old 08-10-2010, 08:44 PM   #208 (permalink)
Did you unplug the gain on your receiver and turn the pot switch down all the way when you did the ESC programing? You must when it go's into the programing mode move the throttle to the bottom to teach the ESC your throttle curve. I had the same problem.
The Gaui site has a updated manual that says to do it. After I did it it flew fine.
But if I use a 3S I have to do the throttle curve to the ESC's every time I change from 2S to a 3S. Now I stick to 2S unless I'm lifting something.
J
jmsask is offline        Reply With Quote Quick reply to this message
Old 08-11-2010, 07:40 AM   #209 (permalink)
J
That is something i did not know. Thanks!
BTW, where is the updated manual? I looked at flying hobby.com web site and don't seem to see it???? Maybe you can point me out is a good direction?
Thank you
PS. I think I found it on page 16 at this location. Is this the same information you are talking about?
http://eng.gaui.com.tw/d981119/html/...ew.asp?sn=1028
PDF located at the bottom of this page
Old 08-11-2010, 10:24 AM   #210 (permalink)
That is it. Remember to take off the wire and set the gain counterclockwise to zero.
Then re-set your throttle to 100%
After setting the ESC's turn the gain back to about where it was, reinsert the gain wire if you are using your transmitter to set the gain.
Lower your throttle to 80% or so and you are all set.
John
in sunny Clyde, Ca.
Old 08-11-2010, 10:57 AM   #211 (permalink)
Thanks John.
Can't wait to get home tonight and try these steps!
BTW, I am not using the Green Gain wire. I leave it unplugged and use the pot on the brain. Been working fine for me so far.
Old 08-11-2010, 02:09 PM   #212 (permalink)
http://eng.gaui.com.tw/d981119/html/download.asp
You can find it here.
John
Old 08-15-2010, 08:28 AM   #213 (permalink)
That was it! Thank you for the help. I am back in the air now!
Wahoo!
Old 09-27-2010, 10:24 PM   #214 (permalink)
Ok guy's been gone for awhile, but back at it again, on one of my last post I had ordered 4 12A Turginy ESC from Hobby King, well I have not been able to get my quad back in the air
And with the new S version - I should probably just buy a new one, but before doing that - has anyone had any luck with aftermarket ESC
Thanks,
FCA
PS: It's a bitch when something goes wrong, and your in risk mgmt, been busy for the last 3 months working on a project
My fantasies of flying a Heli, is better than the reality.
JR X9503.FunJet Ultra, Scimitar, Stryker F27C and Q, DogFighter, mCPx
FLAME747 is offline        Reply With Quote Quick reply to this message
Old 09-29-2010, 09:23 PM   #215 (permalink)
ok had some free time today, got the guad back up into the air, the 12A Turginy ESC from Hobby King are working well, I have a small issue
In the tail in position, the quad slowly rotates to the right, how can I fix this.
Thanks,
FCA
Old 09-29-2010, 09:34 PM   #216 (permalink)
Trim. Mine does the same thing. You have to be very careful to the the battery balanced right as well. If mine is off even a little bit, it makes it very difficult to fly.
