600 Class Nitro Helicopters 600 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
02-08-2012, 06:41 AM | #1 (permalink) |
DFC head on my 600 NSP
Now it looks a lot better with a lower disc, it's how it should be from the start...
For who uses the standard mainshaft H60159: - chop 20mm off the top, then drill a hole 10mm down from the top With the HN6118 shaft, this one is 9mm shorter than std so - take off 11mm form the top, and then a hole 10mm down from the top. So however you measure it, it comes to a distance of 155.5 mm between top and bottom hole! Height of the disc is about the same as the 600E Pro with a DFC head, give or take a few millimeters. Didn't have adjust anything to swash or radio-setup. Just zero'ed the blades at mid-stick, went through the Beast setup. Red at 6 degrees at step J, Blue at 6.7 so not any different then my previous head
KDS Chase 360 | Align Trex 600NSP | Align Trex 700E | Align Trex 700X |
02-08-2012, 08:59 AM | #2 (permalink) |
Member
Where did you buy the head parts? A friend of mine wants to use this head on his 550E.
Is there not a main shaft that will work without cutting and drilling? BTW, it looks super nice!!!
02-08-2012, 09:14 AM | #3 (permalink) |
I bought the DFC kit # H60239. I snatched one of the first ones from eBay.
The bladegrips seperatly. As it states on the box "for T-REX 550E V2/600E PRO" So i guess a drop-in fit for the 550.
02-08-2012, 02:13 PM | #4 (permalink) |
looks bad ass man.... I wanna put a fbl head on mine but i have not a clue to where to start or what to get ........
02-08-2012, 04:28 PM | #5 (permalink) |
Get the V2 FBL Align head and the 6118 mainshaft.
This way you can always upgrade to the DFC if you want to (if Align ever comes up with a mainshaft for the nitro versio)
02-08-2012, 07:00 PM | #6 (permalink) |
looks awesome Sirolf. My head is supposed to arrive on Friday. Can't wait! Thanks for the info! Have you done a test flight yet?
IF IT DOESN'T SMOKE IT'S BROKE!!! TREX 600N LE, OS 55, ALIGN DFC HEAD WITH AR7200BX THUNDER TIGER RAPTOR 30, OS 37 TREX 450 PRO |
02-08-2012, 10:27 PM | #7 (permalink) |
Man that looks awesome I put it on my 550 and I really love the way it performs now.
I really hope Align will make it in blue, my 600N FBL it's blue and I really would like to keep it blue. Any way buddy great job Roger P
Align T-Rex Family Owner - MicrobeastX - 7200BX 450 Dominator, 500 Dominator, 500(Airwolf) Four Blades, 550 DFC, 600N DFC OS55HZ, 700N DFC 105HZ-R, 700 DFC HK4525-520LE |
02-09-2012, 01:49 AM | #8 (permalink) | |
First thing i noticed an improved cyclic response..
02-09-2012, 04:25 AM | #9 (permalink) |
Nice, nice, nice!!!!!!
BTW Sirolf what p/n is that carbon tail rod? |
02-09-2012, 05:12 AM | #10 (permalink) |
wow so cute .....? can not wait to try it hopefully coming soon DFC 600 in my country
02-09-2012, 06:40 AM | #11 (permalink) |
Quick UK carbon tailrod http://www.readyheli.com/TXT231-Quic...d_p_37345.html
You'll need these as ball-links http://www.readyheli.com/TXT-242BK-Q...k_p_37346.html Cut the rod to a lenght of 60cm or 23.6" glue the pushrod-ends with JB Weld or similar.
02-10-2012, 03:52 PM | #12 (permalink) |
Got mine all assembled on my nitro. Did the main shaft mod. Anyone want to trade the stock DFC shaft for a new nitro shaft?
Blade MCP-X Brushless, 300CFX, , Trex 450 Pro v2, Trex 600 ESP 6s 3GX v.3.1 and KDE head, Rotormast V-22, Futaba 12Z controle!! |
02-10-2012, 08:51 PM | #14 (permalink) |
I'm not going to use the mainshaft that came with my DFC kit. I'd trade it for a stock 600 nitro main shaft.
02-11-2012, 11:53 AM | #15 (permalink) | |
How did you like the DFC? Did you fly it yet?
02-11-2012, 12:55 PM | #16 (permalink) |
Will it fit the nitro or is it jjust for the electric
02-11-2012, 02:03 PM | #17 (permalink) |
Haven't flown it yet. I'm still trying to decide on the Futaba GY750 or BeastX. Can't wait to give it a go though!!
Alignnitro, The DFC shaft will only fit the electric version.
02-12-2012, 05:58 AM | #18 (permalink) |
Only te new 600E Pro, not the ESP
