Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > X5
X5 Discussion and support of the Gaui X5
Old 09-16-2014, 01:30 PM   #21 (permalink)
Originally Posted by ReadyToCrash View Post
Hello guys,
I wonder if this esc has a setting that determines how smooth the transition between modes (normal/idle1/idle2) will occur.
A softer transition is good to the gears.
I couldn’t find anything about this on the manual, so I’m assuming this esc doesn’t have such feature.
Am I right?
Thanks.
I run the gov on my X5 (on the GE-610). Run a 6S configuration. Gov needs to be high rate.
There is no soft transition in the ESC between speeds (dependent on TX, could do this in the transmitter though).
If the gov is enabled, there is really no "normal" mode. Once you get over the gov threshold, the go is enabled. This is fine for me as I do not ever fly in "normal" mode.
Was pleasantly surprised last time I started to throw it around trying tic-tocs (don't do them much). The gov held the head speed quite well despite the heavy variable loading. (I tend to run a head speed near 95% of max speed on the 6S setup at 22.2v rating, so not much head room).
I have found the gov works well for my mild 3D type flying, but other hard smackers here on HF have been less satisfied with the results. Stock GUEC GE 100 A ESC Gov Question
Old 09-16-2014, 01:43 PM   #22 (permalink)
Agreed. I ran teh gov on the same esc but the HV version. The ESC controller board is exact same but the mosfets are diff.. It was good but not comparable to the proactive vbar gov. I love the sound of the governor, and with the proactive it kicks in much earlier in manuevers it feels like. If you can hook up a proactive, I suggest doing it.
bgymr is offline        Reply With Quote Quick reply to this message
Old 09-16-2014, 03:51 PM   #23 (permalink)
thanks a lot!
ReadyToCrash is offline        Reply With Quote Quick reply to this message
Old 09-14-2015, 08:30 AM   #24 (permalink)
Sorry to dig out a old thread but just got a 2nd hand X5and has this esc on it and curious how to easily program this speedy? Should I just buy a hobbywing 3 in 1 program box?
whatson is offline        Reply With Quote Quick reply to this message
Old 09-14-2015, 09:00 AM   #25 (permalink)
I haven't used the program box but I find it fast enough to program. I've never felt that it's particularly slow, but I'm sure it's slower than the program box as for the most part you're listening out for a specific sequence of beeps which identifies the particular feature you want to change.
If you're constantly tweaking ESC settings then it would become frustrating, but for the few times a year I need to change something it's no big deal. Also I exclusively use HW ESCs, not just on the X5.
FOR NO FREE APE DIES
Gaui X3/Gaui X5/Goblin 570 KSE/Goblin 630C/Thunder Tiger Raptor 50
Citizen 717
ian.newson is offline        Reply With Quote Quick reply to this message
Old 09-14-2015, 09:00 AM   #26 (permalink)
It can be programmed fine by the motor beeps.
Fairly easy to program (but programming is limited).
Old 09-15-2015, 07:49 AM   #27 (permalink)
Cheers guys, I had a good read of the manual tonight and will have a go programming tomorrow night. The helis I've built have all but one had castle esc's so just plug into comp and away you go.
Old 09-16-2015, 11:13 AM   #28 (permalink)
This one works exactly the same - you just need to get the programming box rather than the Castle link cable go connect to your computer
Old 09-17-2015, 07:49 AM   #29 (permalink)
At least for the newer 100A HW Platinum (the newer black ESC) there is also a simple and cheap USB connection cable to run the HW software from a PC or laptop. Many people don't know about this alternative which is super easy and cheap for the occasional setup change at home.
Don't think the old golden GE-610 has this option though. I sold mine new from the combo and bought the black Platinum plus USB cable for the money - never regretted.
- GAUI X5 (Mini VBar, stock servos, Scorpion 910kV motor, HW Platinum v3 100A)
- TRex 450 Sport DFC
(Microbeast, TGY-306G, Y40A, BL450M)
- DJI F450 pro
(NazaV2/GPS, SunnySky 2212, MWC Light, GoPro 2 BL gimbal)
- Blade mCPX,
Futaba T8FGs, Heli-X Sim
Rebel10 is offline        Reply With Quote Quick reply to this message
Old 09-23-2015, 03:08 PM   #30 (permalink)
Since in put the platinum 100 on, I'm getting 30sec more flight time. Programmer is worth the investment.
Diabolo 700, Oxy 5 Nitro, OMP M2, Futaba
DanMcN is offline        Reply With Quote Quick reply to this message
