Go Back   HeliFreak > R/C Electronics Support > Castle Creations ESC and Software
Castle Creations ESC and Software Castle Creations ESC Software and Hardware Support
Old 10-02-2016, 11:02 PM   #21 (permalink)
Originally Posted by crashcopterman View Post
Super BEC Pro Mini!!!
Steve
I saw that it has two silicone wires so I guess you need to solder multiple servo leads so that the 16 amps current can be delivered to the Rx. I think to me, that's an overkill. I plan to buy the Super BEC Mini G2, which supports up to 8s - that's more than enough in my setup as I will only feed 6S to it.
neosunrise is offline        Reply With Quote Quick reply to this message
Old 10-03-2016, 01:44 AM   #22 (permalink)
It's never overkill to supply your electronics system, cheap out here and a brownout or shutdown may be in your near future. That G2 you mentioned is very good, I have the exact unit on my 550 running @6v and it has given me two seasons of perfect service.
Steve
Nano CPX || 130X || 230S II 450 3D converted to 450X || 360CFX || 480 Fusion II 550X || Oxy 5 MEG || ALeeS Rush 700 Evolution || Goblin 770 Sport 'My flight style, determines my crash style"
crashcopterman is offline        Reply With Quote Quick reply to this message
Old 10-03-2016, 09:58 AM   #23 (permalink)
Steve
I agree with the point that cheaping out here is not quite a good decision and that's why I decided to go for the WR Hercules BEC. They are much more expensive but that's peace of mind. So you are also running a mini G2 and have no problem at all?
Old 10-03-2016, 05:52 PM   #24 (permalink)
The two wires are for the incoming power. The receiver/FBL leads go to the SB Pro and then out to the servo so all servos are being fed directly at the SB Pro with power. The servo leads from the SB Pro also power the FBL unit.
Sorry, saw you are talking about the mini.
Paul
Agile 5.5 - Q 4125-1100, YEP 120, Brain2 HD FBL / Outrage 550 - HK4020-1390, Edge 120, Brain2 HD
Rave Ballistic FSO - Q 4530-500, Edge 160HV, Brain2 HD / Protos Max V2 - MSH 4530-500, Edge 160HV, Brain2 HD
pctomlin is offline        Reply With Quote Quick reply to this message
Old 11-14-2016, 04:24 PM   #25 (permalink)
Default going back to the main topic... How reliable is the CC BEC Pro?
Going back to the main topic...Anyone happen to know the MTBF for the CC BEC Pro?
Is it measured in seconds, minutes, flights?
Seriously, though... like any electronics in the hobby, too many variables, too many different applications, users abilities, etc. etc... Unfortunately I just witnessed a CC BEC Pro eat Four (4) like new MKS 960 / 990 servos in an instant on a member's heli. Servos are dead, the BEC is charred black mess. Just fried at initial plug into a 6s pack. He had multiple BEC pro's and some with 2-3 seasons use, this was the first and last failure.
WR or RX packs only in the future.
Logo 600, Soxos Strike 7
Spirit GTR, Spirit2 RS, Jeti DS12
KC8CYF is offline        Reply With Quote Quick reply to this message
Old 11-14-2016, 08:21 PM   #26 (permalink)
It's easy to put the blame on a product without knowing/sharing the whole scenario.
Castle Bec Pro allows users to set output voltage from 4.8V to 12.5V with its software; it could very well be wrongly set above the servo's maximum working voltage which could easily fry them instantly.
Carlos
CZorzella is offline        Reply With Quote Quick reply to this message
Old 11-14-2016, 10:26 PM   #27 (permalink)
Carlos
7.2 volts since January 2016. Around 50 flights or so with BEC pro and MKS servos. My brothers heli so I don't have all the details of his setup. The BEC pro circuit board is charred, the positive lead desoldered itself from the circuit board. Full 6s battery voltage passed through to servos for a few milliseconds before the power lead desoldered.
We all have different experiences, some are lucky some are not. Lesson learned here was not trust a BEC with out over voltage/ cut through protection... especially with high end servos.
Old 11-14-2016, 10:53 PM   #28 (permalink)
I am still running an original BEC Pro V1 on one of my helis, must be every bit of five years old now. All my 550 size and up helis are powered by BEC Pros and have never had an issue.
Paul
Old 11-14-2016, 11:11 PM   #29 (permalink)
Carlos
I've had several BEC pros over the last 4 years. Never an issue on 12s or 6s, although once I heard about 12s problems I converted over to 6s.
I've heard the complaints from others and the carnage that could occur but I figured not me, I've got a solid setup, well protected wire, clean builds. I should've heeded the warning.
Here's the deal. Previous night logged about 50 minutes of bench time resetting the head after a minor crash (tip over). All was well. Two days later went out to the field to fly, connected the BEC supply jumper 6s, and instantly a small pop. Felt the ec3 had arced slightly. Disconnected, tried to reconnect, but nothing. Pulled the BEC from the model and noticed immediately the positive lead had desoldered from the pcb. Cracked it open and discovered the charred mess. The realization of what happened got me thinking and concerned. I borrowed a RX pack from a fellow modeler and my worst fears were realized
Later, I was lucky to find that my 3digi FBL, Optguard, Jeti RX, and Jeti Mezon 135 ESC all survived the voltage spike. Unfortunately the MKS HBL960/990 combo did not. So $527 in servos for a $40 bec.
I'll let you draw your own conclusion. As for me, I'll never use a BEC pro again.
Team Only Fine Helis
Flown on Jeti DS-16, Brain2, RCHN #222
MKS Servos, Scorpion Tribunus, MSH P700, Synergy e5s, N5cTT
Dmaxison is offline        Reply With Quote Quick reply to this message
Old 11-15-2016, 03:52 AM   #30 (permalink)
Default How reliable are CC BEC Pro's?
Having one of the two input wires break off inside the case is possibly the number complaint. The fact of the matter is that most of the BECs are made without any strain relief to the cables.
IMO, this is not a brand specific issue. I have Castle BEC Pro in most of my models, and never had an issue in years, but as a preventive measure, I always make sure there is adequate strain relief on the wires and I firmly zip-tie the nearby wire to the frame, to act as a strain relief.
Here is a word of advice: If you don't strain-relief your cable and plug on your BEC, no matter the brand you use, the same misfortune may happen at some point. Cable management seems to be the key in this case.
Carlos
Old 11-15-2016, 05:22 AM   #31 (permalink)
Carlos
I know the difference between a desoldered connection and a broken wire. Sorry the pic doesn't do it justice.
Thanks for your insight and good luck with yours.
Old 11-15-2016, 11:26 AM   #32 (permalink)
I Love the Castle bec pro on 6S. 7 years with no issues.
cortez jenkins sr is offline        Reply With Quote Quick reply to this message
Old 11-18-2016, 03:55 PM   #33 (permalink)
Have had them in 5 of my helicopters all gobs and 0 issues.
Mikado Logo 700/Synergy 516\Vbar Vcontrol Touch/Neo/RCHN #612 IRCHA#5289
Iskareot is offline        Reply With Quote Quick reply to this message
