Old 10-18-2012, 04:08 AM   #1 (permalink)
Default What is the difference between step G and Parameter A?
I am bit confuse what is the difference between step G and parameter A. Can someone explain it? They both seem to do the samething but why?
czynot is offline        Reply With Quote Quick reply to this message
Old 10-18-2012, 04:21 AM   #2 (permalink)
Step G does one servo at a time, while Parameter A is like a cyclic adjustment.
Heli's I have:
Goblin 500 (Vbar Neo), Gaui X5(Vbar Neo), X7(Vbar Neo), Innova 600 Night heli (Vbar Neo Vbar Vcontrol
I'm the not so newbheliusr as I have been here a while. But I like this name.
newbheliusr is offline        Reply With Quote Quick reply to this message
Old 10-18-2012, 06:59 AM   #3 (permalink)
Member
G is where you do your mechanical setup. A is to use traditional "trim" if necessary. If G is done correctly and you set your CG properly, no adjustment should be needed in A.
Sent from my phone
Old 10-18-2012, 09:46 AM   #4 (permalink)
My Step G is setup and level. The heli still have a little bit of left and back drift that i want to get rid of. Should I go back into step G or just trim it out on parameter A?
Old 10-18-2012, 10:08 AM   #5 (permalink)
Member
If step G is done correctly (level swash and zero degrees of pitch at the blades while the servos are in their adjusted center positions) there shouldn't be any drifting.
If setup was done correctly, two things come to mind.
1. You have sub trim or trim in the transmitter on aileron and/or elevator. Make sure they are zero in all flight modes and rebind. If you had trim, you'll need to re-do the setup.
2. You have vibes that are causing the drift. Make sure you're not using the stock mounting tape. Try the 3M 411 or 4011 tape........one layer for e-birds, two layers for n-birds.
Old 10-19-2012, 04:45 PM   #6 (permalink)
If you make a adjustment in Parameter A.
Afterwards you adjust in Step G,
Will the adjustments you made in Parameter A be negated?
450X | 450 3DX | 300X | 130X | Mcpx BL | Mcpx | SR | 350QX | Mqx | Nano Cpx | Nano Qx | 120 SR | And one DX8 to rule them all.
Blackanthem is offline        Reply With Quote Quick reply to this message
Old 10-19-2012, 07:32 PM   #7 (permalink)
Yes, if you adjust A, then all your careful efforts at G will be for nought, as they are essentially the same thing, but just applied differently, or vice versa.
Parameter A applies them as though they were trim, applied across all servos at once, and step G applies it to one servo at a time. Additionally parameter A allows quick access whilst at the flight line, whilst step G is not so easy to access, or adjust.
Cheers
Sutty
Regards, Sutty
sutty is offline        Reply With Quote Quick reply to this message
Old 10-19-2012, 07:52 PM   #8 (permalink)
Thanks. Another mystery solved... for me anyway.
Old 10-26-2012, 10:51 PM   #9 (permalink)
I am glad to see this thread because my current understanding of Setup Step G and Parameter A is correct, well after hours of scratching my head. I use Setup Step G to center the servos, then mechanically level the swashplate but since my 300X doesn't have true turnbuckles you can only get it within 1 turn. What I found is you can just tap the servo adjustment to get the swashplate perfectly level. Now the 300X comes straight up and no drifting while in the air.
rc18 is offline        Reply With Quote Quick reply to this message
Old 10-28-2012, 05:16 AM   #10 (permalink)
The weird thing I have noticed with parameter A, the one time I did use it to correct a left drift during punchout, I needed to feed left cyclic while in the parameter to correct the left drift. I first tried to adjust with right cyclic, but that just made the drift worse.
Trex 250se 3gx
Trex 500 Beastx, Ice 75 9650's & 9257 500mx, Edge main & Kbdd tail blades
Mini Titan e325 Beastx Airtronics 94809 cyclic, 9257 tail, Ice lite 50/scorp 2221-8 Edge mains, Kbdd tail blades
Jr Vibe 50, Beastx, all Futaba servos OS55hz, Hatori sab 50, Radix
Punkin71 is offline        Reply With Quote Quick reply to this message
