Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > 120 SR
120 SR Blade (eFlite) 120 SR Helicopters Information and Help
Old 04-04-2011, 06:01 PM   #461 (permalink)
Question
Xtreme Trex 250 landing gears:
Im just thinking about the fitting...I plan to use 5mm height plastic spacer and M2/M2.5/M3 - 12-14 screws with nuts.
BUT Im affraid the screw set would be "very" heavy... ? or is there other solution for the fitting??
...maybe using titanium screws?
bulesz is offline        Reply With Quote Quick reply to this message
Old 04-04-2011, 11:52 PM   #462 (permalink)
Nylon screws ...
bandit.r is offline        Reply With Quote Quick reply to this message
Old 04-05-2011, 02:18 PM   #463 (permalink)
Exclamation
I have found a really good battery offer:
http://cgi.ebay.com/3x-3-7V-900mah-2...#ht_2447wt_905
900mah 25C AND you get a 3x balance cable! so you can the three batts on your CX2 balance charger at the same time!
Old 04-06-2011, 04:17 PM   #464 (permalink)
Will they fit into the stock holder. Also with the balance cable does it mean you can charge all 3 batteries at once?
koiboy is offline        Reply With Quote Quick reply to this message
Old 04-07-2011, 01:22 AM   #465 (permalink)
They wont fit to the stock holder, and Yes you can charger at the same time with a balanced charger!
Old 04-07-2011, 03:45 AM   #466 (permalink)
forgive my noob question but... a balanced charger being something other then the stock blade 120 sr charger ?
I have also been looking for after market batterys on ebay and so forth, are the tiger 3.7v 600mah any good http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT ? does anyone run them or know of any other batt's that will fit the stock batt mount ?
Have also found these http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT anyone tried them ?
o_Opt is offline        Reply With Quote Quick reply to this message
Old 04-07-2011, 09:24 AM   #467 (permalink)
Yes, the ballanced chargers are for 2-3cell LiPos...the 120SR charger is for 1S - 1 cell LiPos...so you CANT use my link , but you can use the Tigers cable for the stock 120SR charger. (the batteries will be charged at 0.7mA / 5 so it will be veeery slooow, but you can charge 5 batts multiple. With the pack I have found is great, because those 3 batts can connect to a ballanced charger and the charger will "think" that hey its a 3S 11,1V battery
(called "balanced" because it charges the cells separately)
So I would choose for custome batt mod that 900mAh 25C triple pack with balanced cable and the balanced charger (you can charge them SEPARATELY with the stock charger of coz!)
OR
for the stock battery holder I would get the Intellect 550mAh 25C for around 5GBP + shipment.
Old 04-08-2011, 12:58 AM   #468 (permalink)
Blues: Have you got any pics of the batt mount mod? what sort of flight times are you getting with the 900mah 25c batt's ?
Old 04-08-2011, 11:02 PM   #469 (permalink)
Default 10 Minute Battery 120SR
I have the same batteries. Max flying time in my 120sr is about 10 minutes but I reduce it to 7 or 8 minutes to extend battery life. Mine are $39.99 plus $10 shipping for 10 batteries. $5 bucks each total is a good price for 25c 900mah batteries. From Ebay the link is: http://cgi.ebay.com/ws/eBayISAPI.dll...STRK:MEWAX:VRI
Here is the battery holder I made by cutting off the bottom half of an extra battery holder and gluing a strip of basswood to it. I had to drill a hole in the wood to access the mounting screw and I rolled a small log of electrical tape and attached to the top rear of the wood so just one set of rubber bands would hold the battery to the mount. The front of the battery is supported by the canopy. Here are some pictures:
IndyThreeWheel is offline        Reply With Quote Quick reply to this message
Old 04-09-2011, 05:49 AM   #470 (permalink)
Wow! Great! If you rewire the chopter (replacing the motor and battery cables) you would get more power!
Glad to hear that you using them with satisfaction! Im very curious about mine! I hope that next week I can finish my mods (Xtreme Trex 250 landing, tail support, batteries... )
Old 04-09-2011, 12:35 PM   #471 (permalink)
Default Mods so far
Being new to the heli r/c world, I have spent twice as much time on the internet as flight times lol. Although I have been running the 1/8 scale nitro trucks for nearly fice years, the heli is a different beast to say the least.
So far on my 120sr I have:
-Trimmed landing gear to avoid servo contact
-Dollar store door hanger foam cut to make a blade holder
-Power switch( no more racing to get the battery plugged in and heli stable b4 the gyro cal.)
Thats it so far, next will be a parallel y harness for two stock batteries. maybe a zip tie support tray under the main gear...I'll have pics.
Cheers
ID:	220767   Click image for larger version
ID:	220768   Click image for larger version
ID:	220769   Click image for larger version
TheRooster is offline        Reply With Quote Quick reply to this message
Old 04-10-2011, 02:19 PM   #472 (permalink)
How does the weight compare with all these skid "improvements"?
whirlEbyrd is offline        Reply With Quote Quick reply to this message
Old 04-11-2011, 04:54 PM   #473 (permalink)
Ca you please tell me what thickness lexan to use for the battery mod on blade 120
mhick is offline        Reply With Quote Quick reply to this message
Old 04-11-2011, 10:23 PM   #474 (permalink)
Cheers
When using 2 stock batteries in parallel I found you can use two stock battery holders glued side to side turned around backwards on the front body mount. You have to clearance the battery mounts to clear the body mount holder. The batteries fit a little tight inside the body but will fit. I do this but i also have a 1mm piece of plastic under my gaui 200 skids. With 2-56 allen bolts through the plate and the LG a 1mm thick nut on the bolts makes it perfect height to glue the battery holder to, and still get the body mount through the factory "eye" of the battery holder. I had to clearance the battery holder to be able to get to get the bolts in and had to grind the heads down to stop the batteries from dragging on them but it works perfect. If you need/want pics ill be happy to take them and post in high res to show you what I'm talking about.
squish099 is offline        Reply With Quote Quick reply to this message
Old 04-13-2011, 05:42 PM   #475 (permalink)
I'd like to see the pictures of the mod.
Blade 230s
esa3 is offline        Reply With Quote Quick reply to this message
Old 04-14-2011, 05:46 PM   #476 (permalink)
Finished the tail boom brace with the parts that "liftbag" provided on another thread.
My Favorite: TREX 250SE FBL w/SK-720/DS410M/DS95i, JR 11X
Fun to Fly: TREX 450 Sport FBL w/SK-720
Retired/Sold: Blade mCX2, mSR, 120 SR, mCP X
BigART71 is offline        Reply With Quote Quick reply to this message
Old 04-15-2011, 06:10 AM   #477 (permalink)
Nice Verry Nice! Clean look. What Canopy is that?
3171scott is offline        Reply With Quote Quick reply to this message
Old 04-15-2011, 07:16 AM   #478 (permalink)
Just a guess but id say its a Century Evolution 180
My question is how much does it weigh?
If brute force doesn't work your just not using enough of it.
Blade mSR, 120 SR, cX 250 paperweight, cX 450 v2
unknowncitizen is offline        Reply With Quote Quick reply to this message
Old 04-15-2011, 10:01 AM   #479 (permalink)
Yes, it's a Century Evolution 180. I think it's on the heavy side at 3.1 grams heavier then stock. The plastic is much thicker then stock. For $6 bucks painted I couldn't resist. I could trim more off of it as well, so don't let the extra weight full you. With guys putting cameras and everything else on here the canopy is pretty light in comparison to some other mods I've seen.
I extended the tail boom 20mm with solid rod. It actually is tail heavy so the little bit of extra weight on the front doesn't hurt.
Oh yeah, forgot to mention. I didn't have a drill bit small enough to drill into the frame. I used a sewing needle heated up with a lighter. Went through like butter! No mess and it was the perfect size to start the screw into.
Old 04-15-2011, 12:26 PM   #480 (permalink)
Wham you say you extended the boom with solid rod what do mean exactly? How could you use solid rod? I don't see a splice or anything.. What about the motor wires..?
evilb is offline        Reply With Quote Quick reply to this message
