Go Back   HeliFreak > R/C Helicopter Support > SAB Goblin 630/700/770
SAB Goblin 630/700/770 SAB Heli Division 630/700/770 - Goblin Helicopters Factory Support
Old 05-28-2015, 10:11 PM   #41 (permalink)
I plan on it
Specter 700 x 2--Diabolo UL--Compass 6hvu--Logo 600--oxy5+, oxy5, Oxy3, oxy2, SAB Mini Comet
Cajun Aircraft
B.Ewing is offline        Reply With Quote Quick reply to this message
Old 05-29-2015, 01:37 PM   #42 (permalink)
...i already have on my 770 competition tri-blade
--> Pyro 800 Competition, Kosmik 200, Zeal Blades 750mm + Zeal Blades 115mm
Headspeeds: 1150rpm, 1500rpm and 1850rpm - i LOVE it !!!
Goblin 770, Logo 700 @ VBar Touch
tc1975 is offline        Reply With Quote Quick reply to this message
Old 05-30-2015, 11:00 AM   #43 (permalink)
I'll answer my own question. I emailed SAB and they said not to worry it's not a limited edition so it will be around for awhile.
Originally Posted by kbzx35 View Post
Does anyone know if this is a limited run or a new part of the SAB lineup? Want one but blew my heli budget for a few months and then some
Jeti DS-14 [] Spirit FBL [] Kontronik [] XNova
Oxy 3 [] Goblin 380 [] Goblin 700 KSE
RCHN Citizen #348
kbzx35 is offline        Reply With Quote Quick reply to this message
Old 05-30-2015, 02:56 PM   #44 (permalink)
How is the Sound from the blades compared with the original 2-blades?
Will flight time increase with the same setup after you changed to 3-blades?
Goblin 700C Red Carbon, Kosmik 200 Cool, Pyro 800-48, MKS X8 HBL 950/980, Spirit-Pro, Jlog2.6, GPS-Logger2
Jeti DS-16 Red Carbon + REX7
buell47 is offline        Reply With Quote Quick reply to this message
Old 05-31-2015, 11:37 AM   #45 (permalink)
Default Spartan VX1n and trioblin
If anyone is flying with the tri head and tail with the vortex id sure appreciate a starting point for gains. Also I noticed Kyle suggested moving the tail servo ball closer to the inside but this will put the tail numbers in the vortex way over 200 so a suggestion there would be great too. Im planning to use the stock 21t motor pulley and run about 1900-1950 on an edge 160. Should i go lower with the pulley for an Xnova 4530 525kv?
Thanks in advance
Hobbywing US factory team pilot BK Servo Spartan RCTeam LynxTeam OXY Team Xnova I get high by getting LOW!!
DarkSyd3D is offline        Reply With Quote Quick reply to this message
Old 06-06-2015, 04:29 AM   #46 (permalink)
Thanks in advance
I dont have 3 blades on my G700CO but i do have on my G570 CO and with SAB blades,i set cyclic gain at 35,and if flies great!
huanbuihd is offline        Reply With Quote Quick reply to this message
Old 06-06-2015, 07:55 AM   #47 (permalink)
Thanks in advance
I'm going with the xnova 480 kv, 14s, and I ordered the 19t pulley. I'm looking to top out in the 1900s. Not sure what gov you'll be using but if I was using 525kv and 12s I would use the 20t
Do we actually know what pulleys in this kit version?
Cajun Aircraft
Old 06-15-2015, 01:31 AM   #48 (permalink)
Have you preordered or are you thinking about purchasing the new Goblin 700 Kyle Stacy Edition? Check out what you can expect to when you open the box!
SAB Goblin 700 Kyle Stacy Edition Unboxing Video (4 min 15 sec)
Chris Reibert is offline        Reply With Quote Quick reply to this message
Old 07-10-2015, 12:02 PM   #49 (permalink)
Default KSE Manual available
Manual is available
Will get My KSE on monday
Henseleit TDR 2011 | JR Vibe 50 | Goblin 380 KSE | Goblin Speed P850-50 4+4x1.6 DD 500KV | Goblin Urukay HK4530 5+4x1.5YY 540KV | Goblin 700 KSE | Jeti DS16 | VX1e | VX1 pro
http://www.helifleet.com/SJo1
SJo1 is offline        Reply With Quote Quick reply to this message
Old 07-11-2015, 11:35 PM   #50 (permalink)
Great looking heli and amazing piloting skills!!
Question regarding flight times.
I am currently flying a Trex 550 with 606mm blades doing low rpm stuff (1500 rpm). 8 minutes of flight time yeilds a 3.9v per cell pack after landing.
The Goblin has caught my eye and I am pondering purchasing one.
I believe Kyle mentioned 3 min flight times which is to be expected with his flying style. If I wanted to drop the rpm down and putz around the field, what kind of flight times could I expect. Is running the system using a single 6s pack feasable for low rpm stuff with a motor change if needed?
Thanks,
Shawn
sawacs is offline        Reply With Quote Quick reply to this message
Old 07-12-2015, 10:01 AM   #51 (permalink)
If u want to do 6s low headspeed stuff I'd say find the lightest airframe u can like a logo 690 or synergy e5ss. I'm sure the kse will do it but it's more suited for higher headspeeds
Cajun Aircraft
Old 07-12-2015, 10:02 AM   #52 (permalink)
I have a hps3 on a g700 I'm not a smack 3D at ~1800 and I'm getting 5min on a 12s 5000mAh but I have a high demanding motor and setup, with a smaller motor or less KV probably you could add 1-2 min
Diabolo 550 / Diabolo 700BE /Triabolo 700 / Srimok 90N
Goblin-700/700C/KSE/BlackNitro/380/Logo700/Trex600NSP
Jeti DS-14 Edition
Grittner is offline        Reply With Quote Quick reply to this message
Old 07-12-2015, 01:06 PM   #53 (permalink)
Ok here is my setup and flight times
Goblin 700 KSE
FBL System: NEO
Motor: Scorpion HK4525-520KV
Pinion: 21T
Headspeeds: 1600, 1700, 1800
ESC: Castle Edge HV160
BEC: Castle BEC Pro
Cyclic Servos: MKS HBL599 X6s
Tail Servo: MKS HBL880 X8
Battery: Pulse 12s 5000mAh 45C lipo
Flight Times: 5-8 minutes
At 1600rpm I get 6min sport/soft 3D flights and come down at 3.77volts on all my cells.
My big air flying banks 2 and 3 I stick to 4-5min 3D flights.
Old 07-12-2015, 06:39 PM   #54 (permalink)
Thank you gents for the information. Even though the Sab might be a little heavier, it sure is hard to look at any other heli
Cheers,
Shawn
Old 07-13-2015, 08:47 AM   #55 (permalink)
I was running circa 1800 head-speed when I first got it, after a bit of getting used to the feel as it really is different I really liked the increased "locked in" feel the 3 blade head gives you...
It all depends on preferred flight style but for me though at the lower head speed I thought it could do with a bit more zip in flight, so I have since upped the pinion and got closer to 2000 rpm and it is now much more what I was hoping it would be like....
That being said I get less than 4min flight times since doing that so it is a bit of a trade off pushing it a bit more but I think its worth it....
john-yates is offline        Reply With Quote Quick reply to this message
Old 07-28-2015, 08:57 AM   #56 (permalink)
Hello Guys
I'm finishing mine with following setup :
-Goblin 700 KSE
-FBL System: Brain
-Motor: Scorpion HK4525-520KV
-Pinion: 18T (instead of 20T included)
-Headspeeds: 1450, 1600, 1750
-ESC: Castle Edge HV160
-BEC: None, 2S lipo
-Cyclic Servos: TORQ 9280
-Tail Servo: TORQ 9288
-Battery: Gens 12s 5000mAh 45C/60C lipo
-Flight Times: 5-6 minutes
Question, when you post a RPM, do you mean real RPM ? I've been said that tri blades RPM = 2 blades RPM divided by 1.22
When I read some people are flying 2000 RPM, that means same as 2440 RPM for 2 blades one.
KatoSan is offline        Reply With Quote Quick reply to this message
Old 08-01-2015, 10:34 PM   #57 (permalink)
I maidened my KSE Goblin today. 😆😆😆
My setup is:
Jeti R3/RSW
Bavarian Demon 3SX
Kontronik Kosmik 160A
Pyro 750-45
Stock 20T pinion
MKS HBL950 BLS HV cyclics
MJS HBL980 BLS HV tail
JLog 2.6 GW
I'm waiting for my 7S packs to arrive, but did the maiden on 12S.
Cyclic is super smooth.
I like it. 😁😁
allen james is offline        Reply With Quote Quick reply to this message
Old 08-04-2015, 06:56 AM   #58 (permalink)
Hello guys
I have nine flights with my KSE. It's flawless in the Sky. I Fly It at 1600 and 1800 rpm with 18t pinion.
I have one issue. Whatever the rpm, went i enter a huge funnel i have a tic tac clac sound that Is only in this maneuver.
Any of you have experienced that and solve It ?
Thanks.
Old 08-06-2015, 11:19 AM   #59 (permalink)
Nobody have this issue ?
Old 08-06-2015, 08:15 PM   #60 (permalink)
Maybe it's the same click sound some have had on the 700, caused by the lower mainshaft collar.
Synergy 516 | Oxy 3 | V Control Host of Full Pitch RC Heli Podcast
jimmy77611 is offline        Reply With Quote Quick reply to this message
