Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 500X
Blade 500X Blade 500X Helicopters Information and Help
Old 12-21-2015, 05:22 AM   #1 (permalink)
Default 500x tilts right sereverly on take off
Was flying fine and on the next flight it decided to tilt abruptly to the right on take off.
I did notice on the last flight a slight tilt to right( before that it would take off perfectly straight) but it flew fine.
Flying in sport mode on bx.
Any ideas.
Thanks Jim
jmurray74 is offline        Reply With Quote Quick reply to this message
Old 12-21-2015, 05:40 AM   #2 (permalink)
Uncommanded roll to the right is the classic BeastX response to vibration. A good first step is to remove the main blades and spool the heli up, while watching the swash to see if it deviates to the right.
Goblins - Mini Comet, 380, 500, 700
BK Servos, Spartan vx1e FBL units, Switch Blades
Jeti DS-16
TORCHS member, AMA 64878, Citizen 690
Mattinfla is offline        Reply With Quote Quick reply to this message
Old 12-21-2015, 09:09 AM   #3 (permalink)
its called the RROD . right roll of death..its due to vibrations to the fbl unit..try different mounting tape under the fbl like 3m. then look for bad bearings or out of balance blades..its pretty common on the 500x. ground the boom to the motor mount too. the search feature here is pretty good too..
tonys-heli is online now        Reply With Quote Quick reply to this message
Old 12-25-2015, 03:15 PM   #4 (permalink)
I have tried everything and still roll right. Could it be the bx.
This was a good flyer,but now is a piece of s???.
Jim
Old 12-28-2015, 05:02 AM   #5 (permalink)
Tail was problem . Bent blade hub and out of balance blades.
Flies good now.
Old 12-28-2015, 07:52 AM   #6 (permalink)
how did the hub get bent..glad you got it sorted out..
Old 12-28-2015, 10:22 AM   #7 (permalink)
I guess in crash
Old 12-28-2015, 11:09 AM   #8 (permalink)
Any ideas.
Thanks Jim
you said it was flying fine. you didn't say you crashed and then It was flying tilted..
Old 01-02-2016, 07:51 AM   #9 (permalink)
Nice to hear your up and running again: make sure you don't have any noise or fuzz (buzz) in your tail.
Also if you crashed you should change your feathering shift and probably your main shaft.
Good luck..
MCX2, RF7.5, Phoenix, Nano CPX BL, 500X {AR7200BX}, Goblin 770 {AR7300BX}, DX6i, DX9
EBrom is offline        Reply With Quote Quick reply to this message
Old 01-04-2016, 04:57 AM   #10 (permalink)
Thanks for all the info.
Jim
Old 03-08-2016, 02:10 PM   #11 (permalink)
im glad I ran across this post..........my 500x started doing the same thing.............i"ve been going crazy trying to figure it out...........thanks.....also the servos seen to be trouble some......I have had to replace two due to jerky type movement and also the tail servo just stopped working..............what is a in expensive metal gear servo you would recommend.........thanks.............pault
pault is offline        Reply With Quote Quick reply to this message
Old 03-08-2016, 02:28 PM   #12 (permalink)
Sure you're running the servos at the right pulse/frequency so it could be a problem with the beastx unit. One that came on my 300cfx killed servos left and right with no rhyme or reason. Just a thought
Mini Protos 6s stretch/XK K110/Trex 450sport v2 fbl/Rochobby Nemesis NXT/RareBear funfighter620mm
~Problem Child~
learnedthehardway is offline        Reply With Quote Quick reply to this message
