Go Back   HeliFreak > R/C Helicopters > Rotor Blades
Rotor Blades R/C Helicopter Rotor Blade Discussions
Old 03-24-2014, 09:13 AM   #21 (permalink)
OP... Those are FINE, if the holes bother you then just fill them in with some epoxy, then use an Xacto knife to shave the excess epoxy and lightly wetsand with some 600 grit... or just don't do anything at all.
I've ranked up HUNDREDS of flights on blades that had nicks from me cutting the grass.
Only time I would be worried if the nicks were clear holes and the size of peas... but that has never happened.
~SAB~ Goblin 700 ~Compass~ Warp 360 ~Blade~ mCP X (BL)
AMA# 977012
**Team BOCA Bearings**
BaconRaygun is offline        Reply With Quote Quick reply to this message
Old 03-24-2014, 09:21 AM   #22 (permalink)
Don't use CA. If there is a path it will wick it's way in and eat the foam core, that can't be good.
I'm sure they are fine for service but if you aren't 100% comfortable save em for chopping hay or blade scraping till they are trashed.
GimpyGolden is offline        Reply With Quote Quick reply to this message
Old 03-24-2014, 10:17 AM   #23 (permalink)
Those appears to be ok. I would just fill it in with expoxy and let it set.
777ER is offline        Reply With Quote Quick reply to this message
Old 03-24-2014, 10:22 AM   #24 (permalink)
iv had blades that have taken a hit from a bolt and kept flying till i crashed months later
Team Synergy and Rail
helienv is offline        Reply With Quote Quick reply to this message
Old 03-24-2014, 10:58 AM   #25 (permalink)
I would fly those. They are just nicks in the clear cote, doesn't look like anything structural at all. I have had nicks in the roots on my 450 blades and filled with epoxy and kept flying. They were align blades, wouldn't ever do that on cheaper blades.
Team Synergy
Dylan Hudock is offline        Reply With Quote Quick reply to this message
Old 03-24-2014, 04:04 PM   #26 (permalink)
I've used epoxy on my 710's. Your fine. Fill'em, fly'em.
Trex700N2E
Trex500ESP (Belted)
HC500SE ....GO TEAM FLYBAR!
Blayd is offline        Reply With Quote Quick reply to this message
Old 03-24-2014, 08:19 PM   #27 (permalink)
Default Cutting grass hurt my big blades :(
That's the plan thanks guys
TS3D#1
NanoCPXBL,TREX550PRODFC,
TREX700PRODFCHV, DX8
TREX 700 Pro, TREX 700LTop, GauiX3, Futaba 14SGH
Excalibur3 is offline        Reply With Quote Quick reply to this message
Old 03-24-2014, 08:38 PM   #28 (permalink)
You promised the video.
We need the video.
XL Power 520 / Spektrum DX6
PcChip is offline        Reply With Quote Quick reply to this message
Old 03-24-2014, 09:06 PM   #29 (permalink)
I've used epoxy that I thinned with alcohol this allowed the epoxy to get into the smaller pockets easier and still make a tight bond. Granted this wasn't on a main blade but worked great for the purpose, the epoxy didn't make a thick coat so I didn't have as much to sand off.
~Jim~
Goblin700 Gasser TRM-300, BD Axon,
Align700E w/HC3SX, and a Goblin 380 w/BD3SX, using Futaba 14SGH
KSHeli is offline        Reply With Quote Quick reply to this message
Old 03-25-2014, 08:44 AM   #30 (permalink)
^All you have to do is lightly heat it with a heat gun, that will have the same effect (also gets all the bubbles out). That is what I do when I re-drill skis and have to fill the old holes or need to fix a de-laminated ski.
AMA# 977012
Old 03-25-2014, 09:48 AM   #31 (permalink)
+1. Unless you see CF, it's just the paint coat that was busted up.
Over a summer of grass and soy cutting, I realized that the layer is fragile regardless of blades.
Fill it, make sure it matches the blade profile, and be done with it.
I learned my lesson about dry stuff when I went after some old soy and took a nice chunk out of the leading edge on a REALLY old(as in no brass inserts old) curtiss blade. That went into the CF lamination which meant game over for those. Shame too, I like those blades and it was fun showing people blades that were so old they had damn near turned yellow from sun aging.
"You need more rockets. Everything is better with rockets"
Mike Dipalo--Synergy RC, MKS Electronics
Commodore8888 is offline        Reply With Quote Quick reply to this message
Old 03-25-2014, 05:06 PM   #32 (permalink)
It sucks my friend can't down load the video he has no wifi
TS3D#1
Old 03-25-2014, 05:08 PM   #33 (permalink)
Why did they move this thread? It was to notify all people that fly all sizes what might happen. If this isn't main Heli forum material than I don't know what is ?
TS3D#1
Old 03-31-2014, 08:07 PM   #34 (permalink)
Here is the video as promised
[ame]http://youtu.be/0b2gZBDxN2I[/ame]
TS3D#1
Old 06-25-2014, 10:19 PM   #35 (permalink)
Default awesome
I can't beleave you did that lmao....I like the way you just laughing about it I'd be nervous as hell doing that......great vid....
gaurdian101 is offline        Reply With Quote Quick reply to this message
Old 07-22-2014, 12:01 AM   #36 (permalink)
Wow Ive never seen that happen!
Patric_H is offline        Reply With Quote Quick reply to this message
Old 07-22-2014, 04:12 PM   #37 (permalink)
Well looking back I was actually cutting heavy brush not grass. Lol and I'm many flights later and those blades are still going strong
Old 08-05-2014, 01:31 PM   #38 (permalink)
The local Bass Pro Shop has epoxy in multiple colors, esp. black and white, to fill nicks in boat hulls. I works great to fix blades.
Four Stroker is offline        Reply With Quote Quick reply to this message
Old 08-05-2014, 01:32 PM   #39 (permalink)
The local Bass Pro Shop has epoxy in multiple colors, esp. black and white, to fill nicks in boat hulls. It works great to fix blades.
