Old 07-15-2012, 10:45 AM   #1
lespaulrob
Default Shuddering with negative collective
So I noticed a large bit of vibration when I would give some negative collective when trying to bring my 130x down (no 3d, just standard circuit flying). Any thoughts on this? I didn't see any wear on the gear after a 4 minute flight and was wondering if this was something that I could easily resolve.
lespaulrob is offline        Reply With Quote
Old 07-15-2012, 10:46 AM   #2
lespaulrob
Note, this isn't the tail that's shuddering, it's the whole body.
Old 07-15-2012, 10:49 AM   #3
GSPI
Have you changed the O-rings on the swash and head assembly with the canopy grommets?
OXY Heli and Lynx Heli Innovations Team Pilot
SilentDRC.net -The Order of Brushless Witnesses
GSPI is offline        Reply With Quote
Old 07-15-2012, 11:34 AM   #4
d12bn
Default Hey
I find the canopy grommets are too thick. I cut some fuel line tubing and no more shakes.
Team MicroHeli - Team Scorpion - Team HeliProz
Check out my Youtube channel JJ Inverted Production
d12bn is offline        Reply With Quote
Old 07-15-2012, 12:55 PM   #5
lovespicyfood
This absolutely cured my shudders from hell.
lovespicyfood is offline        Reply With Quote
Old 07-15-2012, 12:56 PM   #6
lovespicyfood
Canopy grommets worked for me, but thanks for your post. Fuel tubing makes sense, is cheap and I would think last longer (less brittle) than the grommets...
Old 07-15-2012, 01:35 PM   #7
lespaulrob
Yep, that fixed it! Man this thing flies sweet! I'm 4 flights in and it's really starting to break in (or more it's me relaxing with it!). I'm going to take it out to a field later today and open it up.
Old 07-15-2012, 02:26 PM   #8
Merse
the canopy grommets are a must to cure the shudders. flyies amazing after!!!
SAB Goblin 500 Quantum 4020-1200 CCEdge 100 Silverline VBAR
SAB Goblin 570 XNova 4025-560 YGE 90HV JR 8917HV Silverline VBAR
DX18. THERE IS NO SPOON
Merse is offline        Reply With Quote
Old 07-15-2012, 10:18 PM   #9
RapTH44
I added half a canopy grommet to the existing rubber bushing on each blade grip and it cured half my shudder, the other half was due to the umbrella gear not being pushed all the way up on the main shaft, there was about 1/16" of play on there snd it made for an aweful shudder, even managed to pull the ball end off a blade grip partially during flight so check this often as it appears the umbrella gear can sink down the shaft a little.
Also noticed a small air bubble in the plastic for the ball on the main blade grip. So that probably contributed too.
RapTH44 is offline        Reply With Quote
