Go Back   HeliFreak > R/C Electronics Support > YGE
YGE YGE ESC Support and Discussion
Old 05-30-2012, 08:49 PM   #21 (permalink)
Originally Posted by fusionsx00 View Post
yeah human error, i agree
the human that made the esc, and the human that flys the heli this was in is still flying on a
cheap hobbywing ,
Notice he said a lot, not all of them, the one you had was a part failure, but there are lots of people who have problems that are related to incorrect setup.
-DX8
desertstalker is offline        Reply With Quote Quick reply to this message
Old 06-02-2012, 03:21 AM   #22 (permalink)
Exactly. I didnt say this incident was one. Nr1 reasons for esc failure are to long screws that touch the wires inside
-TT E700 V2-vbar-mks950-980-Kosmik 160HV-Pyro 700 rewound by PD / Voodoo 600 -PD-MX700-470kv--BLS255hv-VBAR 5.3+- Gaui X3+Spirit Pro
velocity90 is offline        Reply With Quote Quick reply to this message
Old 06-21-2012, 06:50 PM   #23 (permalink)
That would burn any esc connected to the "motor" in question
which now has a castle ice 100 tested on the exact same setup, all was fine again
So no response from retailer or yge about the warranty, does anyone here know what the actual warranty is in the USA?
fusionsx00 is offline        Reply With Quote Quick reply to this message
Old 06-23-2012, 01:20 AM   #24 (permalink)
Well I emailed nankin who now sells yge and they said:
Warranty:
We give 6 months warranty on this speed regulator.
Old 06-23-2012, 07:17 AM   #25 (permalink)
Yes, 6 months from the factory as listed in the manual that came with your ESC:
"Warranty:
We give 6 months warranty on this speed regulator. Any other requirements are excluded."
I had to send mine back to the factory for the warranty repair, just like I did with the CC ESC's that I ran. It sucks that they are in Germany, but that's what you gotta do.
Please remember that elektrorc is not a distributor like RH is for Kontronik. Pete is only a retailer, and he buys units from YGE and resells them. This means he does not handle the support directly, and any repairs need to be sent back to the factory as explained here: http://elektrorc.com/article_info.php?articles_id=22
Ecaf is offline        Reply With Quote Quick reply to this message
Old 07-01-2012, 05:01 PM   #26 (permalink)
I've had my 100LVVB for 8 months and hundreds of flights. Last flight one motor cable got loose (bad solder). So it died no beep, only flash a code "startup failure". So I've contacted YGE and will send it in for repair. Have two other YGE and a really satisfied with the units and support. Last time I sent it in took about two weeks in total.
550E, X3 | BeastX, YGE, DX8
http://dannesholk.se/rc.shtml
Danny_Swe is offline        Reply With Quote Quick reply to this message
Old 07-02-2012, 05:06 PM   #27 (permalink)
My YGE 60 also just has the error "start up failed"
How do you contact YGE?
[B]TT E820 - Kosmik 200, Scorp 5035 TT G4.1(x2) - OS 91 3D Speed, Hatori
MSH Brains + JETI DS-16
rossk is offline        Reply With Quote Quick reply to this message
Old 07-02-2012, 05:11 PM   #28 (permalink)
try a hard reset first (full stick power off, power on to arm, some beep (?), remain full stick when power off)
try their contact form: http://yge.de/tinc?key=TDGnIMP2
Old 07-02-2012, 06:05 PM   #29 (permalink)
I tried the full stick reset, also with the prog card.
Its damaged after a crash, I have also submitted that contact form, but have not heard anything back.
More here: https://www.helifreak.com/showthread.php?t=430081
Old 07-10-2012, 11:32 PM   #30 (permalink)
Yeah your in Sweden, I will be happy to post pictures of my shipping labels And corrisponding
Emails, it was months.
And really the yge 100lv bar I got from electro RC should have been warranty repaired
But the place of original purchase and yge have failed to reply to my emails, even to at least say no were not fixing it.
Does that sound like a reputable company?
So I guess I'm left out in the cold , maybe Nankin will help me out if I buy a new one from them
But who knows yge might still black list me for anything
Old 07-13-2012, 01:21 AM   #31 (permalink)
Ahh I know what to do, I'll have my freind in new mexico send it in for me.
Then when he gets it back he will send it to me smells like a win to me.
Old 05-21-2014, 10:28 PM   #32 (permalink)
I just installed a yge 100 on my goblin 570 went to spoil maiden flight blades started then stoped now esc smells burnt
Donnyv22 is offline        Reply With Quote Quick reply to this message
Old 06-02-2014, 04:09 PM   #33 (permalink)
Anyone experienced that you can't reset the three-beep with radio? (100% and then disconnect, like manual says).
I haven't had time to try attaching the prog card yet but I have a bad feeling
Old 06-04-2014, 09:55 AM   #34 (permalink)
Default Re: new yge 100lv shut down in flight and burned
You can reset every beep with full stick. However for instance you are running vbar gov it won't sent the needed signal as a safety measure.
Old 06-04-2014, 12:22 PM   #35 (permalink)
ok, I'm running vbar gov I guess I'll have to try detach my throtthle-cable and try with the prog card then. Thanks
Old 06-04-2014, 01:39 PM   #36 (permalink)
Clearly YGE has not done there part to properly instruct those using YGE for the first time.
At best there esc instruction is clearly confusing and not very clear.
Have look at the GOV store thread you have half dozen different methods and opinions to setup gov store or vbar.
even mr.mel video does not clear explain one need to dis-engage freewheel and gov store when re-calibrating the stick ! as example
DIABOLO: PYRO 800 Kv510 YY (built by HeliFX),MKS, Vbar 5.3 + YGE160HV, JR 11X DMS || GOBLIN 570: HKIII4025 1.5mm YY Kv 620 12S(built by HeliFX),JR 8917HV, Vbar 5.3, Heli JIVE v13 || Mikado LOGO550SX v2 https://sites.google.com/site/helifxmotors/
HeliFX is offline        Reply With Quote Quick reply to this message
Old 09-14-2014, 05:41 PM   #37 (permalink)
I was under the impression that this was a high end ESC. I purchased a 120lvk, programmed it with the card. Everything ran flawlessly the first flight. The second flight POP during spool up. Smells like it got my FBL too, I have no idea until i can test it.
It says in the cheap printout you get with the ESC that it has a 6 month warranty? how the hell do you even get in touch with these guys?
doluseb is offline        Reply With Quote Quick reply to this message
Old 09-14-2014, 06:14 PM   #38 (permalink)
6 months warranty in North America 2 years in Europe.
don't ask why but that f***ked up.
Best bet bring back to the shop you bought at ask refund or new esc.
that what I did.
if no dice.
you need to send to YGE.
YGE
Heino Jung
Vechtaer Hof 30
49088 Osnabrueck
Germany
Phone 0541/160099442
On the customs form, put a value of $20 and state damaged merchandise.
Please include a note with your name, return shipping address, email contact address, purchase
date, reseller, and issue with the item.
Repairs and updates are typically between 20 and 35 Euros, unless there is some other
mitigating circumstance. They accept payments via paypal.
