Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > X5
X5 Discussion and support of the Gaui X5
Old 07-04-2012, 04:12 AM   #1
crf69
Default vent holes in canopy.
anybody do this?
my shit gets hot as ****.
gainzzz-r-us
crf69 is offline        Reply With Quote
Old 07-04-2012, 05:37 PM   #2
mamartin
Do you have an external BEC? If not get a CC 20amp BEC pro. You will notice a drastic change in operating temps on your equipment.
It's only about a 30$ investment and helps a lot
Mike Martin, MSH BRAIN USA Team Manager
MSH USA FLIGHT TEAM,
CYCLONE BLADES, XNOVA MOTORS,
JETI USA
www.MSHUSA.com, www.MSheli.com
mamartin is offline        Reply With Quote
Old 07-04-2012, 05:46 PM   #3
crf69
i'm scard to mess withmy stock setup.....it has been flawless!!!!
but that is the reason for everything to be so hot....dont help its 100 here either.
gainzzz-r-us
Old 07-04-2012, 06:43 PM   #4
mamartin
It's the same here dude. 100 to 105 degrees, hot as hell with zero wind.
My heli was the same as far as worried about goofing my setup up but once you get it and do it you will see cooler temps on your stuff with better efficiency on your batts because it's a switching BEC and should an unfortunate incident occur such as your ESC taking a crap you will then still be able to auto your X5 down to the ground.
With as good as your getting you will definitly notice a temp improvement and it doesn't wiegh anything hardly at all.
If you do it you won't regret it.
Please keep those sick videos coming
Mike
JETI USA
Old 07-04-2012, 06:51 PM   #5
gbidwell
the only way an external BEC will mess with your setup is via interference, which will be obvious. Get yourself a CC BEC Pro. Cheap and reliable.
In respect to cooling holes...why not? If your flying when its 40 C outside then it would be a good idea to provide more air flow. I have done this with all of my nitro and electric rc cars, since they dont go as fast and dont have prop wash to cool the components.
You will weaken the canopy...so choose wisely. I would suggest one 20-30mm hole either side of the canopy, inline with the ESC, similiar to how thunder tiger vents their canopies.
gbidwell is offline        Reply With Quote
Old 07-04-2012, 07:26 PM   #6
mamartin
You could always fly nude too
That way you save about 50$ if you crash
JETI USA
Old 07-04-2012, 10:01 PM   #7
crf69
haha yeah never thought of that!!
gainzzz-r-us
Old 07-04-2012, 11:24 PM   #8
gbidwell
although you do reduce the lipo protection by doing so and also limit visibility.
Old 07-05-2012, 04:21 PM   #9
helidude71
My motor goes up to 50C (122F)
BEC, ESC and lipo around 45C (113F)
Outside temps around 26C (79F)
No problem at all.
TSH Gaui X5 FES, Spirit, S.Bus, HW100A V3
TSH Gaui X3, Spirit, 6S, S.Bus, HW50A V3
Futaba T7C (I admit, also a Spektrum DX8 and some planks.) ;-)
Phoenix R/C v5
helidude71 is offline        Reply With Quote
Old 07-05-2012, 04:25 PM   #10
crf69
i just need to buy a cheapo battery operted fan.....to cool my shit so i can fly quicker.....i have 7 batteries and waiting 15 minutes sucks between flights
gainzzz-r-us
Old 07-05-2012, 06:54 PM   #11
gbidwell
Definitely a good idea. I forgot to mention this us exactly what I do with me electric RC truggy. Castle creations mamba monster has an inbuilt fan and the motor has a castle fan shroud. Works a treat.
Get some 5v fans and run them straight from your RX. Are you running 6v on the RX ?
